Thank you for the information about mode switching. Meanwhile I’ve been trying to find answers to my other questions myself and found out that my modem is in fact in QMI mode, and the reason MM’s location support is not working even though in QMI mode is because the MC7455 is using a newer QMI protocol (LOC) instead of the older PDS service, which MM/libqmi doesn’t support yet. (I can still start MM in debug mode and issue AT-commands by hand using mmcli to get location data, but it would have been so much nicer and possibly more reliable to get these information from MM. I’ll investigate if I can supply a patch to MM.)
Hello, I am the OP that needed help setting up my router and modem to work with Sprint. When Verizon brought back the unlimited plan, I added a line to my Verizon plan (using an old Note 3) and then switched the sim card in the Linksys router from the Sprint card to the Verizon card and changed the bands. Everything was going fine since I switched this last February. Then, when my most recent billing period began, my setup is now considered a “hotspot” according to Verizon. I have unlimited data, but only a max of 15GB of hotspot data to use each month. Well, I went through the entire 15GB the first day and Verizon has now slowed that connection down to 600kbps for the rest of the billing period. I installed the sim card back into my Note 3 and using 4G on that works fine, no slow down. I put the sim card back into the MC7455, and it immediately went back to 600kbps. Am I now screwed? Is there any way to stop Verizon from thinking this is a hotspot? Can I change the mac address in the modem or do I have to buy a new modem? I don’t want all this time and money spent to be all for nothing.
Your phone uses a TTL of 64. Many carriers look for this and if it’s over then it will show up as a hotspot. Computers show yp as a ttl of 128 normaly and this is a red flag. To set a ttl on your router go to network then firewall then custom rules. Add this line after all the hashed lines and save. This will force all ttl to show up as 64 after it goes through the mc7455. This might or might not work.
I will try that, but, isn’t the “modem” between the tower and my router? It was my understanding that Verizon does not see my router, only the modem which receives the 4G signal. Can the TTL be changed on the modem?
Your client is what determines the ttl. The script I gave you makes all devices use the ttl that Verizon wants to see. It’s the same ttl that would be on the phone by itself.
Should I still change it to 65 even though it worked?
My speeds were 0.6 before the change and 30 after, at least on my PC. My iMAC is a different story. Both computers are connected to the same ethernet cable via a switch so there shouldn’t be any difference in the signal. Speedtest on the iMAC, however, still won’t go above 0.6. It follows the same route as my PC…through the Linksys router running OpenWRT connected to the MC7455 modem. Any ideas why this might be happening?
I tested the speeds on my phone connected to the Linksys router and got 30 download also.
I have a Mikrotik 912UAG-5HPnD-OUT running LEDE 17.01.4… I have a mPCIe Sierra MC7455 card in the slot on the router board with an ATT SIM installed as well. I’ve been searching, reading and trying all steps I could find, but I’ve not been able to figure out how to configure this card. So far, here is what I see:
oot@LEDE:/dev# dmesg | grep usb
[ 4.019693] usbcore: registered new interface driver usbfs
[ 4.025357] usbcore: registered new interface driver hub
[ 4.030931] usbcore: registered new device driver usb
[ 10.727496] usbcore: registered new interface driver cdc_wdm
[ 10.873640] usbcore: registered new interface driver usbserial
[ 10.879752] usbcore: registered new interface driver usbserial_generic
[ 10.886481] usbserial: USB Serial support registered for generic
[ 10.962841] usbcore: registered new interface driver cdc_ncm
[ 11.115515] usbcore: registered new interface driver qmi_wwan
[ 11.123880] usbcore: registered new interface driver sierra
[ 11.129736] usbserial: USB Serial support registered for Sierra USB modem
[ 11.139485] usbcore: registered new interface driver sierra_net
[ 11.174805] usbcore: registered new interface driver cdc_mbim
[ 11.187634] usbcore: registered new interface driver option
[ 11.193487] usbserial: USB Serial support registered for GSM modem (1-port)
[ 11.206390] usbcore: registered new interface driver qcserial
[ 11.212422] usbserial: USB Serial support registered for Qualcomm USB modem
Thank you for your notice. We will try it out a bit later, at the moment we are debugging a different problem that is unrelated to MM. I will let you know of the results how well the new LOC support is working.
My apologies if this is the wrong section for this but i recent got a WG3526 router that supports the linux-based OpenWRT firmware. I also installed a MC7455 module which allows one to get internet access from a SIM card. Although I have gotten it to work and i can access and adjust settings within openwrt i notice the internet is unstable. When i jump to different sites it will work just fine but then suddenly at random whe i revisit some of those visited sites again, after not visiting them for a while, then the sites will either return 404 or return back partial. For example, if i visit some visit some investment sites like say this questrade review or even cnn when i start my 3526 from a cold boot then both will come down perfectly …but then lets say i begin playing videos on Youtube for a while, but then i return to the review or cnn…when i do that those pages will either return 404 or come down partially. I could then quickly jump to any other site (that i haven’t visited before) and it will work just fine. So it’s not that the router is experiencing some hiccup at that exact moment since if it was, that page should come down as a 404 or garbled too but they don’t.
for ore information about jobs visit here careerjobs360
So, after 2 years of using a Verizon sim card with my Linksys WRT1900ACS and Sierra Wireless MC7455 modem, it will no longer connect/register to the 4g network and I get an email from Verizon with this message:
“Someone on your account has switched from the Samsung to the by moving SIM cards. This change, however, will not work because the SIM is on an unlimited plan and incompatible with . We recommend replacing the SIM in the original or other compatible device.”
Does this mean my journey to have a 4G router on my Verizon unlimited plan has come to an end? I’ve tried everything I know to get it to work again (which actually isn’t much). Has Verizon cracked down this much and I won’t be able to get it to connect anymore? Not sure where to go from here except to cancel this line of service and sell the equipment. Has anyone else run into this?
In an attempt to get my Sierra MC7455 to make friends with my TP-Link Archer c2600 in QMI mode.
There has only been on irregular thing for this setup:
Kmod-usb-net-qmi-wwan package is for a later kernel I believe than what the Archer Lede Firmware has… so I had to force install it.
if anyone interested in game visit Arafura games 2019
I’m a bit offtopic, but I wanted to use this thread cause I don’t think my question is worthy of its own.
Do you guys know if I can configure an MC7455 as a Wi-Fi transmitter instead of receiver. I’d like to use it as an access point, so to speak, but I don’t know if it’s even possible.
