Help with MC7455 in OpenWRT router
Would switching to qmi mode work better than mbim mode?
I am still getting disconnects when using verizon.
So far my att is solid in the home internet.
But i cannot get my verizon one to stay connected
Hi, thanks to westrem I got my lede router working with mc7455, but connection speed is very low (~6mpbs) compared to ~60mbps on my phone.
Thats gstatus:
at!gstatus?
!GSTATUS:
Current Time:  908              Temperature: 41
Reset Counter: 1                Mode:        ONLINE
System mode:   LTE              PS state:    Attached
LTE band:      B7               LTE bw:      20 MHz
LTE Rx chan:   2850             LTE Tx chan: 20850
LTE CA state:  INACTIVE                 LTE Scell band:B7
LTE Scell bw:20 MHz             LTE Scell chan:3048
EMM state:     Registered       Normal Service
RRC state:     RRC Connected
IMS reg state: No Srv
PCC RxM RSSI:  -76              RSRP (dBm):  -98
PCC RxD RSSI:  -74              RSRP (dBm):  -96
SCC RxM RSSI:  -84              RSRP (dBm):  -105
SCC RxD RSSI:  -77              RSRP (dBm):  -105
Tx Power:      15               TAC:         1E9C (7836)
RSRQ (dB):     -7.9
SINR (dB):     19.6
Is band 7 the same band you were using on your phone? Have you tried other bands?
That is actually not totally right :slight_smile: It is true that the MBIM support in ModemManager is less powerful than the QMI support in ModemManager; but…
libqmi/qmicli supports “QMI over MBIM” for these devices; which means you can run any qmicli command directly over the /dev/cdc-wdm port exposed by the MBIM kernel driver; at the same time as ModemManager is running (with the “mbim-proxy” setup). E.g. while MM is running in MBIM mode (or in QMI mode) you could run:
$ qmicli -d /dev/cdc-wdm0 --device-open-proxy --nas-get-cell-location-info
Note: the ‘auto-detection’ of the underlying kernel driver is only available since libqmi 1.17.901. For versions before that one you need to explicitly pass “–device-open-mbim” additionally if the modem is running in MBIM mode.
Here looks the most active place to ask my EM7455 question.
Big Thanks in front.
Here is the scenario:
I am trying to get em7455 with usb adapter working with ASUS ac68u(have latest LEDE on it)
My EM7455 is dell version, I was able to change it to generic with help of a post from ipxon
Postby ipxon » Thu Dec 01, 2016 7:26 pm
1- Download driver from dell website.
2- Uncompress .exe (with 7zip).
3- enter to folder and edit Configuration.ini and set USBCOMP=8 (change 0 to 8 ).
4- execute .exe (It is in the same folder as the file Configuration.ini).
5- plug card em7455 and open Device administrator. You should see the DELL modem, open a find COM port.
6- Open AT Port (with Putty or other program) and excute this commands:
AT!ENTERCND="A710"
AT!USBPID=9071,9070
AT!USBVID=1199
AT!USBPRODUCT="EM7455"
AT!PRIID="9904802","001.001","Generic-Laptop"
AT!RESET
7- Install Sierra Wireless drivers.
8- Done :D
Credits: baodo.
Good Luck!
Then I followed westrem’s guide from beginning of this post. Now I can see EM7455 is connected
root@LEDE:~# lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 003: ID 1199:9071 Sierra Wireless, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Here is the dmesg
root@LEDE:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.4.50 (buildbot@builds-02.infra.lede-project.org) (gcc version 5.4.0 (LEDE GCC 5.4.0 r3103-1b51a49) ) #0 SMP Mon Feb 20 17:13:44 2017
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Asus RT-AC68U (BCM4708)
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Hit pending asynchronous external abort (FSR=0x00001c06) during first unmask, this is most likely caused by a firmware/bootloader bug.
[    0.000000] On node 0 totalpages: 65536
[    0.000000] free_area_init_node: node 0, pgdat c03f8e00, node_mem_map c6df8000
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000]   HighMem zone: 32768 pages, LIFO batch:7
[    0.000000] PERCPU: Embedded 11 pages/cpu @c6dce000 s12928 r8192 d23936 u45056
[    0.000000] pcpu-alloc: s12928 r8192 d23936 u45056 alloc=11*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65280
[    0.000000] Kernel command line: console=ttyS0,115200
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Memory: 255352K/262144K available (3310K kernel code, 109K rwdata, 480K rodata, 224K init, 285K bss, 6792K reserved, 0K cma-reserved, 131072K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xc8800000 - 0xff800000   ( 880 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc03bbe44   (3792 kB)
[    0.000000]       .init : 0xc03bc000 - 0xc03f4000   ( 224 kB)
[    0.000000]       .data : 0xc03f4000 - 0xc040f688   ( 110 kB)
[    0.000000]        .bss : 0xc040f688 - 0xc0456df8   ( 286 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] L2C: DT/platform modifies aux control register: 0x0a130000 -> 0x0a530000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x7e530001
[    0.000011] sched_clock: 64 bits at 500MHz, resolution 2ns, wraps every 4398046511103ns
[    0.000028] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xe6a171a037, max_idle_ns: 881590485102 ns
[    0.000197] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
[    0.060107] pid_max: default: 32768 minimum: 301
[    0.060178] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060187] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060600] CPU: Testing write buffer coherency: ok
[    0.060811] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.060859] Setting up static identity map for 0x82a0 - 0x82d4
[    0.120135] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.120200] Brought up 2 CPUs
[    0.120215] SMP: Total of 2 processors activated (3981.31 BogoMIPS).
[    0.120222] CPU: All CPU(s) started in SVC mode.
[    0.121935] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.121977] pinctrl core: initialized pinctrl subsystem
[    0.122508] NET: Registered protocol family 16
[    0.123064] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.151664] clocksource: Switched to clocksource arm_global_timer
[    0.152310] NET: Registered protocol family 2
[    0.152798] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.152820] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.152841] TCP: Hash tables configured (established 1024 bind 1024)
[    0.152894] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.152920] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.153054] NET: Registered protocol family 1
[    0.153083] PCI: CLS 0 bytes, default 64
[    0.153663] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.153757] Crashlog allocated RAM at address 0x3f00000
[    0.158717] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.158733] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.160476] bounce: pool size: 64 pages
[    0.160489] io scheduler noop registered
[    0.160496] io scheduler deadline registered (default)
[    0.160850] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.162742] console [ttyS0] disabled
[    0.162793] 18000300.serial: ttyS0 at MMIO 0x18000300 (irq = 18, base_baud = 7812500) is a 16550
[    0.602858] console [ttyS0] enabled
[    0.607725] nand: Could not find valid ONFI parameter page; aborting
[    0.614145] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xf1
[    0.620524] nand: AMD/Spansion NAND 128MiB 3,3V 8-bit
[    0.625589] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    0.633208] iproc_nand 18028000.nand: detected 128MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, BCH-8
[    0.643163] Scanning device for bad blocks
[    1.270310] random: nonblocking pool is initialized
[    1.931590] 5 bcm47xxpart partitions found on MTD device brcmnand.0
[    1.937872] Creating 5 MTD partitions on "brcmnand.0":
[    1.943039] 0x000000000000-0x000000080000 : "boot"
[    1.948575] 0x000000080000-0x000000200000 : "nvram"
[    1.954170] 0x000000200000-0x000008000000 : "firmware"
[    1.960513] 0x00000020001c-0x000000600000 : "linux"
[    1.966104] 0x000000600000-0x000008000000 : "ubi"
[    1.972270] libphy: Fixed MDIO Bus: probed
[    1.976432] bgmac_bcma: Broadcom 47xx GBit MAC driver loaded
[    1.982296] bcma: bus0: Found chip with id 53010, rev 0x00 and package 0x00
[    1.989331] bcma: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2A, class 0x0)
[    1.998034] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    1.998047] bcma: bus0: Core 1 found: Chipcommon B (manuf 0x4BF, id 0x50B, rev 0x01, class 0x0)
[    2.006888] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.006899] bcma: bus0: Core 2 found: DMA (manuf 0x4BF, id 0x502, rev 0x01, class 0x0)
[    2.014958] bcma: bus0: Core 3 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
[    2.023447] bcma: bus0: Core 4 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
[    2.031935] bcma: bus0: Core 5 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
[    2.040428] bcma: bus0: Core 6 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
[    2.048862] bcma: bus0: Core 7 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0)
[    2.057485] bcma: bus0: Core 8 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0)
[    2.066139] bcma: bus0: Core 9 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0)
[    2.074803] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.074814] bcma: bus0: Core 10 found: ARM Cortex A9 core (ihost) (manuf 0x4BF, id 0x510, rev 0x01, class 0x0)
[    2.084940] bcma: bus0: Core 11 found: USB 2.0 (manuf 0x4BF, id 0x504, rev 0x01, class 0x0)
[    2.093418] bcma: bus0: Core 12 found: USB 3.0 (manuf 0x4BF, id 0x505, rev 0x01, class 0x0)
[    2.101906] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.101917] bcma: bus0: Core 13 found: SDIO3 (manuf 0x4BF, id 0x503, rev 0x01, class 0x0)
[    2.110235] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.110246] bcma: bus0: Core 14 found: I2S (manuf 0x4BF, id 0x834, rev 0x03, class 0x0)
[    2.118372] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.118383] bcma: bus0: Core 15 found: ARM Cortex A9 JTAG (manuf 0x4BF, id 0x506, rev 0x01, class 0x0)
[    2.127826] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.127836] bcma: bus0: Core 16 found: Denali DDR2/DDR3 memory controller (manuf 0x4BF, id 0x507, rev 0x01, class 0x0)
[    2.138669] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.138679] bcma: bus0: Core 17 found: ROM (manuf 0x4BF, id 0x508, rev 0x01, class 0x0)
[    2.146822] bcma: bus0: Core 18 found: NAND flash controller (manuf 0x4BF, id 0x509, rev 0x01, class 0x0)
[    2.156516] bcma: bus0: bcma_of_get_irq() failed with rc=-22
[    2.156530] bcma: bus0: Core 19 found: SPI flash controller (manuf 0x4BF, id 0x50A, rev 0x01, class 0x0)
[    2.166055] bcma: bus0: Flash type not supported
[    2.181353] bcma: bus0: Using SPROM revision 8 provided by platform.
[    2.181629] bgmac_bcma bcma0:3: Found PHY addr: 30 (NOREGS)
[    2.187229] bgmac_bcma bcma0:3: Support for Roboswitch not implemented
[    2.195466] b53_common: found switch: BCM53012, rev 5
[    2.201219] bgmac_bcma bcma0:4: Found PHY addr: 0
[    2.205942] bgmac_bcma bcma0:4: Support for Roboswitch not implemented
[    2.212514] bgmac_bcma bcma0:4: Invalid MAC addr: 00:00:00:00:00:00
[    2.218809] bgmac_bcma bcma0:4: Using random MAC: ce:e3:54:bd:d5:71
[    2.226209] bgmac_bcma bcma0:5: Found PHY addr: 0
[    2.230978] bgmac_bcma bcma0:5: Support for Roboswitch not implemented
[    2.237529] bgmac_bcma bcma0:5: Invalid MAC addr: 00:00:00:00:00:00
[    2.243849] bgmac_bcma bcma0:5: Using random MAC: 0a:a9:c2:f4:3a:c6
[    2.251239] bgmac_bcma bcma0:6: Unsupported core_unit 3
[    2.256505] bgmac_bcma: probe of bcma0:6 failed with error -524
[    2.370221] pcie_iproc_bcma bcma0:7: PCI host bridge to bus 0000:00
[    2.376518] pci_bus 0000:00: root bus resource [mem 0x08000000-0x0fffffff]
[    2.383432] pcie_iproc_bcma bcma0:7: link: UP
[    2.387820] pci 0000:00:00.0: [14e4:8012] type 01 class 0x060400
[    2.387883] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[    2.388027] PCI: bus0: Fast back to back transfers disabled
[    2.393635] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.401761] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
[    2.401796] pci 0000:01:00.0: [14e4:4360] type 00 class 0x028000
[    2.401838] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[    2.401932] pci 0000:01:00.0: supports D1 D2
[    2.402069] PCI: bus1: Fast back to back transfers disabled
[    2.407661] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.407675] pci_bus 0000:01: busn_res: can not insert [bus 01] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
[    2.407706] pci 0000:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
[    2.414536] pci 0000:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
[    2.421878] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.426861] pci 0000:00:00.0:   bridge window [mem 0x08000000-0x080fffff]
[    2.540207] pcie_iproc_bcma bcma0:8: PCI host bridge to bus 0001:00
[    2.546499] pci_bus 0001:00: root bus resource [mem 0x40000000-0x47ffffff]
[    2.553409] pcie_iproc_bcma bcma0:8: link: UP
[    2.557798] pci 0001:00:00.0: [14e4:8012] type 01 class 0x060400
[    2.557855] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[    2.558005] PCI: bus0: Fast back to back transfers disabled
[    2.563617] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.571737] pci_bus 0001:01: busn_res: can not insert [bus 01-ff] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
[    2.571772] pci 0001:01:00.0: [14e4:4360] type 00 class 0x028000
[    2.571815] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
[    2.571910] pci 0001:01:00.0: supports D1 D2
[    2.572051] PCI: bus1: Fast back to back transfers disabled
[    2.577649] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[    2.577663] pci_bus 0001:01: busn_res: can not insert [bus 01] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
[    2.577693] pci 0001:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
[    2.584516] pci 0001:01:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
[    2.591859] pci 0001:00:00.0: PCI bridge to [bus 01]
[    2.596839] pci 0001:00:00.0:   bridge window [mem 0x40000000-0x400fffff]
[    2.710207] pcie_iproc_bcma bcma0:9: PCI host bridge to bus 0002:00
[    2.716495] pci_bus 0002:00: root bus resource [mem 0x48000000-0x4fffffff]
[    2.723402] pcie_iproc_bcma bcma0:9: PHY or data link is INACTIVE!
[    2.729599] pcie_iproc_bcma bcma0:9: no PCIe EP device detected
[    2.735602] pcie_iproc_bcma bcma0:9: PCIe controller setup failed
[    2.742707] bcm47xx-wdt bcm47xx-wdt.0: BCM47xx Watchdog Timer enabled (30 seconds, Software Timer)
[    2.751736] bcma: bus0: Bus registered
[    2.755608] pci 0000:00:00.0: enabling device (0140 -> 0142)
[    2.761308] bcma-pci-bridge 0000:01:00.0: enabling device (0140 -> 0142)
[    2.768054] bcma: bus1: Found chip with id 0x4360, rev 0x03 and package 0x01
[    2.775155] bcma: bus1: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
[    2.783724] bcma: bus1: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
[    2.792392] bcma: bus1: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
[    2.800704] bcma: bus1: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
[    2.809174] bcma: bus1: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
[    2.818124] bcma: bus1: Found rev 17 PMU (capabilities 0x10A22B11)
[    2.818172] bcma: bus1: SPROM offset 0x800
[    2.849577] bcma: bus1: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
[    2.860030] bcma: bus1: Using SPROM revision 11 provided by platform.
[    2.860043] bcma: bus1: PMU resource config unknown or not needed for device 0x4360
[    2.862055] bcma: bus1: Workarounds unknown or not needed for device 0x4360
[    2.862065] bcma: bus1: Switched to core: 0x83C
[    2.862336] bcma: bus1: Bus registered
[    2.866150] pci 0001:00:00.0: enabling device (0140 -> 0142)
[    2.871858] bcma-pci-bridge 0001:01:00.0: enabling device (0140 -> 0142)
[    2.878600] bcma: bus2: Found chip with id 0x4360, rev 0x03 and package 0x01
[    2.885695] bcma: bus2: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
[    2.894265] bcma: bus2: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
[    2.902924] bcma: bus2: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
[    2.911234] bcma: bus2: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
[    2.919705] bcma: bus2: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
[    2.928655] bcma: bus2: Found rev 17 PMU (capabilities 0x10A22B11)
[    2.928699] bcma: bus2: SPROM offset 0x800
[    2.960099] bcma: bus2: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
[    2.970525] bcma: bus2: Using SPROM revision 11 provided by platform.
[    2.970538] bcma: bus2: PMU resource config unknown or not needed for device 0x4360
[    2.972539] bcma: bus2: Workarounds unknown or not needed for device 0x4360
[    2.972548] bcma: bus2: Switched to core: 0x83C
[    2.972830] bcma: bus2: Bus registered
[    2.977392] NET: Registered protocol family 10
[    2.982842] NET: Registered protocol family 17
[    2.987343] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.000013] 8021q: 802.1Q VLAN Support v1.8
[    3.004274] Registering SWP/SWPB emulation handler
[    3.010751] UBI: auto-attach mtd4
[    3.013910] ubi0: attaching mtd4
[    3.667392] ubi0: scanning is finished
[    3.680543] ubi0: attached mtd4 (name "ubi", size 122 MiB)
[    3.686046] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    3.692960] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    3.699763] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    3.706751] ubi0: good PEBs: 976, bad PEBs: 0, corrupted PEBs: 0
[    3.712782] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
[    3.720018] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 1804325218
[    3.729181] ubi0: available PEBs: 0, total reserved PEBs: 976, PEBs reserved for bad PEB handling: 20
[    3.738458] ubi0: background thread "ubi_bgt0d" started, PID 349
[    3.745463] block ubiblock0_0: created from ubi0:0(rootfs)
[    3.751003] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
[    3.761765] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[    3.769139] Freeing unused kernel memory: 224K (c03bc000 - c03f4000)
[    4.152669] init: Console is alive
[    4.156209] init: - watchdog -
[    4.346178] usbcore: registered new interface driver usbfs
[    4.351763] usbcore: registered new interface driver hub
[    4.357194] usbcore: registered new device driver usb
[    4.364542] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.371542] ehci-platform: EHCI generic platform driver
[    4.377930] ehci-platform 18021000.ehci: EHCI Host Controller
[    4.378390] bcm_ns_usb3 18105000.usb3-phy: Registered Broadcom Northstar USB 3.0 PHY driver
[    4.379309] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.379730] ohci-platform: OHCI generic platform driver
[    4.379879] ohci-platform 18022000.ohci: Generic Platform OHCI controller
[    4.379904] ohci-platform 18022000.ohci: new USB bus registered, assigned bus number 1
[    4.380014] ohci-platform 18022000.ohci: irq 29, io mem 0x18022000
[    4.424539] ehci-platform 18021000.ehci: new USB bus registered, assigned bus number 2
[    4.432608] ehci-platform 18021000.ehci: irq 29, io mem 0x18021000
[    4.446707] hub 1-0:1.0: USB hub found
[    4.450223] ehci-platform 18021000.ehci: USB 2.0 started, EHCI 1.00
[    4.456809] hub 1-0:1.0: 2 ports detected
[    4.461915] hub 2-0:1.0: USB hub found
[    4.464066] xhci-hcd 18023000.xhci: xHCI Host Controller
[    4.471419] hub 2-0:1.0: 2 ports detected
[    4.475741] xhci-hcd 18023000.xhci: new USB bus registered, assigned bus number 3
[    4.483516] xhci-hcd 18023000.xhci: hcc params 0x02501164 hci version 0x100 quirks 0x02010010
[    4.492134] xhci-hcd 18023000.xhci: irq 30, io mem 0x18023000
[    4.498475] hub 3-0:1.0: USB hub found
[    4.502293] hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    4.509590] xhci-hcd 18023000.xhci: xHCI Host Controller
[    4.514973] xhci-hcd 18023000.xhci: new USB bus registered, assigned bus number 4
[    4.532105] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.540718] hub 4-0:1.0: USB hub found
[    4.544538] hub 4-0:1.0: 1 port detected
[    4.550323] init: - preinit -
[    4.810166] usb 2-2: new high-speed USB device number 2 using ehci-platform
[    4.961087] usb 2-2: config 1 has an invalid interface number: 12 but max is 3
[    4.968349] usb 2-2: config 1 has an invalid interface number: 13 but max is 3
[    4.975624] usb 2-2: config 1 has an invalid interface number: 13 but max is 3
[    4.982878] usb 2-2: config 1 has no interface number 1
[    4.988120] usb 2-2: config 1 has no interface number 2
[    6.336949] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    6.342943] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[    8.190141] bgmac_bcma bcma0:3 eth0: Link is Up - 1Gbps/Full - flow control off
[    8.197497] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    8.204005] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.1: link becomes ready
[    9.474285] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 516
[    9.523550] UBIFS (ubi0:1): recovery needed
[    9.639741] UBIFS (ubi0:1): recovery completed
[    9.644302] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "rootfs_data"
[    9.652174] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    9.662119] UBIFS (ubi0:1): FS size: 117579776 bytes (112 MiB, 926 LEBs), journal size 5840896 bytes (5 MiB, 46 LEBs)
[    9.672760] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
[    9.679390] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 9746F4BB-678E-482A-859D-17FA39239C6D, small LPT model
[    9.699669] mount_root: switching to ubifs overlay
[    9.711576] urandom-seed: Seeding with /etc/urandom.seed
[    9.815805] procd: - early -
[    9.818754] procd: - watchdog -
[   10.460487] procd: - ubus -
[   10.633147] procd: - init -
[   10.818624] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   10.833413] usbcore: registered new interface driver cdc_wdm
[   10.840595] ip_tables: (C) 2000-2006 Netfilter Core Team
[   10.849405] nf_conntrack version 0.5.0 (3993 buckets, 15972 max)
[   10.952115] usbcore: registered new interface driver usbserial
[   10.958017] usbcore: registered new interface driver usbserial_generic
[   10.964633] usbserial: USB Serial support registered for generic
[   10.978935] xt_time: kernel timezone is -0000
[   10.986441] usbcore: registered new interface driver cdc_ncm
[   10.997469] PPP generic driver version 2.4.2
[   11.002916] NET: Registered protocol family 24
[   11.008208] usbcore: registered new interface driver sierra
[   11.013923] usbserial: USB Serial support registered for Sierra USB modem
[   11.021794] usbcore: registered new interface driver sierra_net
[   11.050807] cdc_mbim 2-2:1.12: cdc-wdm0: USB WDM device
[   11.056851] cdc_mbim 2-2:1.12 wwan0: register 'cdc_mbim' at usb-18021000.ehci-2, CDC MBIM, ee:1d:ef:73:b0:19
[   11.066946] usbcore: registered new interface driver cdc_mbim
[   11.075318] usbcore: registered new interface driver qcserial
[   11.081309] usbserial: USB Serial support registered for Qualcomm USB modem
[   11.088754] qcserial 2-2:1.0: Qualcomm USB modem converter detected
[   11.095452] usb 2-2: Qualcomm USB modem converter now attached to ttyUSB0
[   11.102758] qcserial 2-2:1.3: Qualcomm USB modem converter detected
[   11.109315] usb 2-2: Qualcomm USB modem converter now attached to ttyUSB1
[   13.612638] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.629984] device eth0.1 entered promiscuous mode
[   13.634920] device eth0 entered promiscuous mode
[   13.642705] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   13.662776] 8021q: adding VLAN 0 to HW filter on device wwan0
[   13.681442] device wwan0 entered promiscuous mode
[   13.686293] br-lan: port 2(wwan0) entered forwarding state
[   13.691928] br-lan: port 2(wwan0) entered forwarding state
[   13.697650] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   13.743587] IPv6: ADDRCONF(NETDEV_UP): eth0.2: link is not ready
[   14.200143] bgmac_bcma bcma0:3 eth0: Link is Up - 1Gbps/Full - flow control off
[   14.207567] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   14.214158] br-lan: port 1(eth0.1) entered forwarding state
[   14.219806] br-lan: port 1(eth0.1) entered forwarding state
[   14.225610] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.2: link becomes ready
[   15.690108] br-lan: port 2(wwan0) entered forwarding state
[   16.210112] br-lan: port 1(eth0.1) entered forwarding state
[  366.421018] usb 2-2: USB disconnect, device number 2
[  366.426341] qcserial ttyUSB0: Qualcomm USB modem converter now disconnected from ttyUSB0
[  366.434656] qcserial 2-2:1.0: device disconnected
[  366.440397] qcserial ttyUSB1: Qualcomm USB modem converter now disconnected from ttyUSB1
[  366.448632] qcserial 2-2:1.3: device disconnected
[  366.453620] cdc_mbim 2-2:1.12 wwan0: unregister 'cdc_mbim' usb-18021000.ehci-2, CDC MBIM
[  366.462645] br-lan: port 2(wwan0) entered disabled state
[  366.470061] device wwan0 left promiscuous mode
[  366.474630] br-lan: port 2(wwan0) entered disabled state
[  394.390197] usb 2-2: new high-speed USB device number 3 using ehci-platform
[  394.541078] usb 2-2: config 1 has an invalid interface number: 12 but max is 3
[  394.548367] usb 2-2: config 1 has an invalid interface number: 13 but max is 3
[  394.555650] usb 2-2: config 1 has an invalid interface number: 13 but max is 3
[  394.562943] usb 2-2: config 1 has no interface number 1
[  394.568191] usb 2-2: config 1 has no interface number 2
[  394.575476] qcserial 2-2:1.0: Qualcomm USB modem converter detected
[  394.582172] usb 2-2: Qualcomm USB modem converter now attached to ttyUSB0
[  394.589874] qcserial 2-2:1.3: Qualcomm USB modem converter detected
[  394.596498] usb 2-2: Qualcomm USB modem converter now attached to ttyUSB1
[  394.620937] cdc_mbim 2-2:1.12: cdc-wdm0: USB WDM device
[  394.627085] cdc_mbim 2-2:1.12 wwan0: register 'cdc_mbim' at usb-18021000.ehci-2, CDC MBIM, ee:1d:ef:73:b0:19
Usually when I use at!gstatus? I always get tx power 0, but when I post this it’s not 0
at!gstatus?
!GSTATUS:
Current Time:  160              Temperature: 26
LTE band:      B25              LTE bw:      5 MHz
LTE Rx chan:   8665             LTE Tx chan: 26665
LTE CA state:  NOT ASSIGNED
PCC RxM RSSI:  -74              RSRP (dBm):  -100
PCC RxD RSSI:  -74              RSRP (dBm):  -100
Tx Power:      23               TAC:         1809 (6153)
RSRQ (dB):     -9.4             Cell ID:     03018003 (50429955)
SINR (dB):     13.0
at!gstatus?
!GSTATUS:
Current Time:  304              Temperature: 27
RRC state:     RRC Idle
PCC RxM RSSI:  -76              RSRP (dBm):  -102
PCC RxD RSSI:  -73              RSRP (dBm):  -101
Tx Power:      0                TAC:         1809 (6153)
RSRQ (dB):     -10.9            Cell ID:     03018003 (50429955)
SINR (dB):     13.2
I googled the issue and found this topic “Topic: Sierra EM7455: MBIM problems”
schoerg said this is working for him :
umbim -n -d /dev/cdc-wdm0 caps
umbim -n -t 1 -d /dev/cdc-wdm0 subscriber
umbim -n -t 2 -d /dev/cdc-wdm0 attach
umbim -v -n -t 3 -d /dev/cdc-wdm0 connect “r.ispsn”
umbim -v -n -t 4 -d /dev/cdc-wdm0 config
Here’s what I got:
root@LEDE:~# umbim -n -d /dev/cdc-wdm0 caps
  devicetype: 0003 - remote
  cellularclass: 0001
  voiceclass: 0001 - no-voice
  simclass: 0002
  dataclass: 003C
  smscaps: 0003
  controlcaps: 0001
  maxsessions: 0008
  deviceid: 353990070991463
  firmwareinfo: SWI9X30C_02.20.03.00
  hardwareinfo: EM7455
root@LEDE:~# umbim -n -t 1 -d /dev/cdc-wdm0 subscriber
  readystate: 0001 - initialized
  simiccid: 89011201002225290349
  subscriberid: 310120222529034
root@LEDE:~# umbim -n -t 2 -d /dev/cdc-wdm0 attach
  nwerror: 0000 - unknown
  packetservicestate: 0002 - attached
  uplinkspeed: 50000000
  downlinkspeed: 300000000
root@LEDE:~# umbim -v -n -t 3 -d /dev/cdc-wdm0 connect "r.ispsn"
sending (124): 03 00 00 00 7c 00 00 00 03 00 00 00 01 00 00 00 00 00 00 00 a2 89 cc 33 bc bb 8b 4f b6 b0 13 3e c2 aa e6 df 0c 00 00 00 01 00 00 00 4c 00 00 00 00 00 00 00 01 00 00 00 3c 00 00 00 0e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7e 5e 2a 7e 4e 6f 72 72 73 6b 65 6e 7e 5e 2a 7e 72 00 2e 00 69 00 73 00 70 00 73 00 6e 00 00 00
  header_type: 0003
  header_length: 007C
  header_transaction: 0003
reading (80): 07 00 00 80 50 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 a2 89 cc 33 bc bb 8b 4f b6 b0 13 3e c2 aa e6 df 0c 00 00 00 24 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 01 00 00 00 7e 5e 2a 7e 4e 6f 72 72 73 6b 65 6e 7e 5e 2a 7e 00 00 00 00
  header_type: 80000007
  header_length: 0050
  header_transaction: 0000
reading (84): 03 00 00 80 54 00 00 00 03 00 00 00 01 00 00 00 00 00 00 00 a2 89 cc 33 bc bb 8b 4f b6 b0 13 3e c2 aa e6 df 0c 00 00 00 00 00 00 00 24 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 7e 5e 2a 7e 4e 6f 72 72 73 6b 65 6e 7e 5e 2a 7e 00 00 00 00
  header_type: 80000003
  header_length: 0054
  command_id: 000C
  status_code: 0000
  sessionid: 0
  activationstate: 0001 - activated
  voicecallstate: 0000 - none
  iptype: 0001 - ipv4
root@LEDE:~# umbim -v -n -t 4 -d /dev/cdc-wdm0 config
sending (108): 03 00 00 00 6c 00 00 00 04 00 00 00 01 00 00 00 00 00 00 00 a2 89 cc 33 bc bb 8b 4f b6 b0 13 3e c2 aa e6 df 0f 00 00 00 00 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  header_type: 0003
  header_length: 006C
  header_transaction: 0004
reading (128): 03 00 00 80 80 00 00 00 04 00 00 00 01 00 00 00 00 00 00 00 a2 89 cc 33 bc bb 8b 4f b6 b0 13 3e c2 aa e6 df 0f 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 0f 00 00 00 00 00 00 00 01 00 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 02 00 00 00 48 00 00 00 00 00 00 00 00 00 00 00 dc 05 00 00 00 00 00 00 1d 00 00 00 ad 99 d8 f4 ad 99 d8 f5 44 1c 1f 1e 44 1c 1f 1f
  header_length: 0080
  command_id: 000F
  status_code: 0000
  ipv4address: 173.153.216.244/29
  ipv4gateway: 173.153.216.245
  ipv4mtu: 1500
  ipv4dnsserver: 68.28.31.30
  ipv4dnsserver: 68.28.31.31
I got the ip but still no internet.
Here is LEDE interface in attachment.
Please help :slight_smile:
The “WAN” part in LEDE is grayed out can’t edit.
It said Unsupported protocol type.
Install protocol extensions…
got Luci proto for mc7455 on mbim router
from westrem
still no internet.
if I connect it to my computer it get internet by itself
What does your ‘/lib/netifd/proto/mbim.sh’ file look like? The LEDE build I am on didn’t have some pieces required for FCC AUTH (still needed for Dell/Lenovo EM7455 that are ‘changed’ into vanilla EM7455 by way of pid/vid changes). Also, not sure if out-of-the-box mbim.sh contains all necessary pieces to set gateway/dns/ip of your WAN interface set since EM7455 is using direct IP. Anyways, here’s the mbim.sh I’m using from a post I found on lteforum.at (all credit to Gicht), hope it is helpful (sorry if you’ve already seen it):
#!/bin/sh
[ -n "$INCLUDE_ONLY" ] || {
    . /lib/functions.sh
    . ../netifd-proto.sh
    init_proto "$@"
#DBG=-v
proto_mbim_init_config() {
    available=1
    no_device=1
    proto_config_add_string "device:device"
    proto_config_add_string apn
    proto_config_add_string pincode
    proto_config_add_string delay
    proto_config_add_string auth
    proto_config_add_string username
    proto_config_add_string password
_proto_mbim_setup() {
    local interface="$1"
    local tid=2
    local ret
    local device apn pincode delay
    json_get_vars device apn pincode delay auth username password
    [ -n "$ctl_device" ] && device=$ctl_device
    [ -n "$device" ] || {
        echo "mbim[$$]" "No control device specified"
        proto_notify_error "$interface" NO_DEVICE
        proto_set_available "$interface" 0
        return 1
    [ -c "$device" ] || {
        echo "mbim[$$]" "The specified control device does not exist"
        return 1
    devname="$(basename "$device")"
    devpath="$(readlink -f /sys/class/usbmisc/$devname/device/)"
    ifname="$( ls "$devpath"/net )"
    [ -n "$ifname" ] || {
        echo "mbim[$$]" "Failed to find matching interface"
        proto_notify_error "$interface" NO_IFNAME
        return 1
    [ -n "$apn" ] || {
        echo "mbim[$$]" "No APN specified"
        proto_notify_error "$interface" NO_APN
        return 1
    [ -n "$delay" ] && sleep "$delay"
    echo "mbim[$$]" "Query radio state"
    umbim $DBG -d $device -n radio| grep "off"
    STATUS=$?
    [ "$STATUS" -ne 0 ] || {
        sleep 1
        echo "mbim[$$]" "Setting FCC Auth"
        uqmi $DBG -m -d $device --fcc-auth
        sleep 1
    echo "mbim[$$]" "Reading capabilities"
    umbim $DBG -d $device -n -t $tid caps || {
        echo "mbim[$$]" "Failed to read modem caps"
        proto_notify_error "$interface" PIN_FAILED
        return 1
    tid=$((tid + 1))
    echo "mbim[$$]" "Checking subscriber"
    umbim $DBG -d $device -n -t $tid subscriber || {
        echo "mbim[$$]" "Subscriber init failed"
        proto_notify_error "$interface" NO_SUBSCRIBER
        return 1
    tid=$((tid + 1))
    echo "mbim[$$]" "Register with network"
      umbim $DBG -d $device -n -t $tid registration || {
        echo "mbim[$$]" "Subscriber registration failed"
        proto_notify_error "$interface" NO_REGISTRATION
        return 1
    tid=$((tid + 1))
    echo "mbim[$$]" "Attach to network"
      umbim $DBG -d $device -n -t $tid attach || {
        echo "mbim[$$]" "Failed to attach to network"
        proto_notify_error "$interface" ATTACH_FAILED
        return 1
    tid=$((tid + 1))
    echo "mbim[$$]" "Connect to network"
    while ! umbim $DBG -d $device -n -t $tid connect "$apn" "$auth" "$username" "$password"; do
        tid=$((tid + 1))
        sleep 1;
    done
    tid=$((tid + 1))
    echo "mbim[$$]" "Get IP config"
    CONFIG=$(umbim $DBG -d $device -n -t $tid config) || {
        echo "mbim[$$]" "config failed"
        return 1
    IP=$(echo -e "$CONFIG"|grep "ipv4address"|grep -E -o "(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)")
    DNS=$(echo -e "$CONFIG"|grep "ipv4dnsserver"|grep -E -o "(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)" |sed -n 1p)
    DNS2=$(echo -e "$CONFIG"|grep "ipv4dnsserver"|grep -E -o "(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)\.(25[0-5]|2[0-4][0-9]|[01]?[0-9][0-9]?)" |sed -n 2p)
    echo "IP: $IP"
    echo "DNS1: $DNS"
    echo "DNS2: $DNS2"
    uci_set_state network $interface tid "$tid"
    echo "mbim[$$]" "Connected, setting IP"
    proto_init_update "$ifname" 1
    proto_add_ipv4_address $IP "255.255.255.255"
    proto_add_ipv4_route "0.0.0.0" 0
    proto_send_update "$interface"
    json_init
    json_add_string name "${interface}_4"
    json_add_string ifname "@$interface"
    json_add_string proto "static"
    echo "nameserver $DNS" >> /tmp/resolv.conf.auto
    echo "nameserver $DNS" >> /etc/resolv.conf
    echo "nameserver $DNS2" >> /tmp/resolv.conf.auto
    echo "nameserver $DNS2" >> /etc/resolv.conf
    return 0
    local ret
    _proto_mbim_setup $@
    ret=$?
    [ "$ret" = 0 ] || {
        logger "mbim bringup failed, retry in 15s"
        sleep 15
    return $rt
proto_mbim_teardown() {
    local device
    local tid=$(uci_get_state network $interface tid)
    echo "mbim[$$]" "Stopping network"
    [ -n "$tid" ] && {
        umbim $DBG -t$tid -d "$device" disconnect
        uci_revert_state network $interface tid
    proto_init_update "*" 0
[ -n "$INCLUDE_ONLY" ] || add_protocol mbim
hazarjast, I tried with no luck. ( installed uqmi and kmod-usb-net-qmi-wwan)
I used at!image=0
and then redo westrem’s procedure sever times from scratch. It was working for 20 minutes(40mbps down, 0.01up wierd), after few 4k videos it quite working no matter what I do.
But when plug in my computer, it’s still working.
here is the system log
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.060598] CPU: Testing write buffer coherency: ok
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.060810] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.060859] Setting up static identity map for 0x82a0 - 0x82d4
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.120133] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.120199] Brought up 2 CPUs
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.120214] SMP: Total of 2 processors activated (3981.31 BogoMIPS).
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    0.120221] CPU: WARNING: CPU(s) started in wrong/inconsistent modes (primary CPU mode 0x13)
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    0.120226] CPU: This may indicate a broken bootloader or firmware.
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.121923] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.121966] pinctrl core: initialized pinctrl subsystem
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.122490] NET: Registered protocol family 16
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.123045] DMA: preallocated 256 KiB pool for atomic coherent allocations
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.151683] clocksource: Switched to clocksource arm_global_timer
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.152325] NET: Registered protocol family 2
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.152816] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.152838] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.152858] TCP: Hash tables configured (established 1024 bind 1024)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.152911] UDP hash table entries: 256 (order: 1, 8192 bytes)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.152936] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.153072] NET: Registered protocol family 1
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    0.153102] PCI: CLS 0 bytes, default 64
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.153682] futex hash table entries: 512 (order: 3, 32768 bytes)
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    0.153775] Crashlog allocated RAM at address 0x3f00000
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.158724] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.158740] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.160520] bounce: pool size: 64 pages
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.160534] io scheduler noop registered
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.160540] io scheduler deadline registered (default)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.160891] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.162767] console [ttyS0] disabled
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.162819] 18000300.serial: ttyS0 at MMIO 0x18000300 (irq = 18, base_baud = 7812500) is a 16550
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.613001] console [ttyS0] enabled
Tue Mar  7 06:36:02 2017 kern.err kernel: [    0.617872] nand: Could not find valid ONFI parameter page; aborting
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.624289] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xf1
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.630667] nand: AMD/Spansion NAND 128MiB 3,3V 8-bit
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.635734] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.643353] iproc_nand 18028000.nand: detected 128MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, BCH-8
Tue Mar  7 06:36:02 2017 kern.info kernel: [    0.653309] Scanning device for bad blocks
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.280151] random: nonblocking pool is initialized
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.941015] 5 bcm47xxpart partitions found on MTD device brcmnand.0
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.947295] Creating 5 MTD partitions on "brcmnand.0":
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.952455] 0x000000000000-0x000000080000 : "boot"
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.957995] 0x000000080000-0x000000200000 : "nvram"
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.963592] 0x000000200000-0x000008000000 : "firmware"
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.969912] 0x00000020001c-0x000000600000 : "linux"
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    1.975546] 0x000000600000-0x000008000000 : "ubi"
Tue Mar  7 06:36:02 2017 kern.info kernel: [    1.981696] libphy: Fixed MDIO Bus: probed
Tue Mar  7 06:36:02 2017 kern.info kernel: [    1.985855] bgmac_bcma: Broadcom 47xx GBit MAC driver loaded
Tue Mar  7 06:36:02 2017 kern.info kernel: [    1.991709] bcma: bus0: Found chip with id 53010, rev 0x00 and package 0x00
Tue Mar  7 06:36:02 2017 kern.info kernel: [    1.998744] bcma: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2A, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.007453] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.007465] bcma: bus0: Core 1 found: Chipcommon B (manuf 0x4BF, id 0x50B, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.016305] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.016315] bcma: bus0: Core 2 found: DMA (manuf 0x4BF, id 0x502, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.024372] bcma: bus0: Core 3 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.032868] bcma: bus0: Core 4 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.041355] bcma: bus0: Core 5 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.049843] bcma: bus0: Core 6 found: GBit MAC (manuf 0x4BF, id 0x82D, rev 0x05, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.058287] bcma: bus0: Core 7 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.066907] bcma: bus0: Core 8 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.075559] bcma: bus0: Core 9 found: PCIe Gen 2 (manuf 0x4BF, id 0x501, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.084224] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.084235] bcma: bus0: Core 10 found: ARM Cortex A9 core (ihost) (manuf 0x4BF, id 0x510, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.094356] bcma: bus0: Core 11 found: USB 2.0 (manuf 0x4BF, id 0x504, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.102840] bcma: bus0: Core 12 found: USB 3.0 (manuf 0x4BF, id 0x505, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.111327] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.111337] bcma: bus0: Core 13 found: SDIO3 (manuf 0x4BF, id 0x503, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.119638] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.119649] bcma: bus0: Core 14 found: I2S (manuf 0x4BF, id 0x834, rev 0x03, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.127787] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.127798] bcma: bus0: Core 15 found: ARM Cortex A9 JTAG (manuf 0x4BF, id 0x506, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.137238] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.137248] bcma: bus0: Core 16 found: Denali DDR2/DDR3 memory controller (manuf 0x4BF, id 0x507, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.148082] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.148092] bcma: bus0: Core 17 found: ROM (manuf 0x4BF, id 0x508, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.156234] bcma: bus0: Core 18 found: NAND flash controller (manuf 0x4BF, id 0x509, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.165931] bcma: bus0: bcma_of_get_irq() failed with rc=-22
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.165945] bcma: bus0: Core 19 found: SPI flash controller (manuf 0x4BF, id 0x50A, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.err kernel: [    2.175467] bcma: bus0: Flash type not supported
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.190783] bcma: bus0: Using SPROM revision 8 provided by platform.
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.191064] bgmac_bcma bcma0:3: Found PHY addr: 30 (NOREGS)
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.196660] bgmac_bcma bcma0:3: Support for Roboswitch not implemented
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.204894] b53_common: found switch: BCM53012, rev 5
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.210644] bgmac_bcma bcma0:4: Found PHY addr: 0
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.215374] bgmac_bcma bcma0:4: Support for Roboswitch not implemented
Tue Mar  7 06:36:02 2017 kern.err kernel: [    2.221947] bgmac_bcma bcma0:4: Invalid MAC addr: 00:00:00:00:00:00
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.228240] bgmac_bcma bcma0:4: Using random MAC: fa:9e:e2:67:5d:fe
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.235640] bgmac_bcma bcma0:5: Found PHY addr: 0
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.240413] bgmac_bcma bcma0:5: Support for Roboswitch not implemented
Tue Mar  7 06:36:02 2017 kern.err kernel: [    2.246960] bgmac_bcma bcma0:5: Invalid MAC addr: 00:00:00:00:00:00
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.253281] bgmac_bcma bcma0:5: Using random MAC: ee:69:58:6e:89:4f
Tue Mar  7 06:36:02 2017 kern.err kernel: [    2.260709] bgmac_bcma bcma0:6: Unsupported core_unit 3
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.265977] bgmac_bcma: probe of bcma0:6 failed with error -524
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.380220] pcie_iproc_bcma bcma0:7: PCI host bridge to bus 0000:00
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.386515] pci_bus 0000:00: root bus resource [mem 0x08000000-0x0fffffff]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.393429] pcie_iproc_bcma bcma0:7: link: UP
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.397816] pci 0000:00:00.0: [14e4:8012] type 01 class 0x060400
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.397877] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.398017] PCI: bus0: Fast back to back transfers disabled
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.403626] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.411746] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.411784] pci 0000:01:00.0: [14e4:4360] type 00 class 0x028000
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.411827] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.411919] pci 0000:01:00.0: supports D1 D2
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.412057] PCI: bus1: Fast back to back transfers disabled
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.417648] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.417662] pci_bus 0000:01: busn_res: can not insert [bus 01] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.417693] pci 0000:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.424516] pci 0000:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.431858] pci 0000:00:00.0: PCI bridge to [bus 01]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.436840] pci 0000:00:00.0:   bridge window [mem 0x08000000-0x080fffff]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.550208] pcie_iproc_bcma bcma0:8: PCI host bridge to bus 0001:00
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.556503] pci_bus 0001:00: root bus resource [mem 0x40000000-0x47ffffff]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.563415] pcie_iproc_bcma bcma0:8: link: UP
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.567804] pci 0001:00:00.0: [14e4:8012] type 01 class 0x060400
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.567861] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.568010] PCI: bus0: Fast back to back transfers disabled
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.573622] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.581743] pci_bus 0001:01: busn_res: can not insert [bus 01-ff] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.581779] pci 0001:01:00.0: [14e4:4360] type 00 class 0x028000
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.581822] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00007fff 64bit]
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.581924] pci 0001:01:00.0: supports D1 D2
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.582055] PCI: bus1: Fast back to back transfers disabled
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.587645] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.587659] pci_bus 0001:01: busn_res: can not insert [bus 01] under [??? 0x00000000 flags 0x0] (conflicts with (null) [??? 0x00000000 flags 0x0])
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.587689] pci 0001:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.594514] pci 0001:01:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.601856] pci 0001:00:00.0: PCI bridge to [bus 01]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.606837] pci 0001:00:00.0:   bridge window [mem 0x40000000-0x400fffff]
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.720206] pcie_iproc_bcma bcma0:9: PCI host bridge to bus 0002:00
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.726501] pci_bus 0002:00: root bus resource [mem 0x48000000-0x4fffffff]
Tue Mar  7 06:36:02 2017 kern.err kernel: [    2.733410] pcie_iproc_bcma bcma0:9: PHY or data link is INACTIVE!
Tue Mar  7 06:36:02 2017 kern.err kernel: [    2.739604] pcie_iproc_bcma bcma0:9: no PCIe EP device detected
Tue Mar  7 06:36:02 2017 kern.err kernel: [    2.745611] pcie_iproc_bcma bcma0:9: PCIe controller setup failed
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.752723] bcm47xx-wdt bcm47xx-wdt.0: BCM47xx Watchdog Timer enabled (30 seconds, Software Timer)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.761751] bcma: bus0: Bus registered
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.765626] pci 0000:00:00.0: enabling device (0140 -> 0142)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.771334] bcma-pci-bridge 0000:01:00.0: enabling device (0140 -> 0142)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.778077] bcma: bus1: Found chip with id 0x4360, rev 0x03 and package 0x01
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.785180] bcma: bus1: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.793746] bcma: bus1: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.802415] bcma: bus1: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.810727] bcma: bus1: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.819196] bcma: bus1: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.828147] bcma: bus1: Found rev 17 PMU (capabilities 0x10A22B11)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.828195] bcma: bus1: SPROM offset 0x800
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.859595] bcma: bus1: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.870048] bcma: bus1: Using SPROM revision 11 provided by platform.
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.870062] bcma: bus1: PMU resource config unknown or not needed for device 0x4360
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.872073] bcma: bus1: Workarounds unknown or not needed for device 0x4360
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.872084] bcma: bus1: Switched to core: 0x83C
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.872362] bcma: bus1: Bus registered
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.876175] pci 0001:00:00.0: enabling device (0140 -> 0142)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.881890] bcma-pci-bridge 0001:01:00.0: enabling device (0140 -> 0142)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.888633] bcma: bus2: Found chip with id 0x4360, rev 0x03 and package 0x01
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.895735] bcma: bus2: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x2B, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.904306] bcma: bus2: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x2A, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.912975] bcma: bus2: Core 2 found: ARM CR4 (manuf 0x4BF, id 0x83E, rev 0x02, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.921286] bcma: bus2: Core 3 found: PCIe Gen2 (manuf 0x4BF, id 0x83C, rev 0x01, class 0x0)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.929754] bcma: bus2: Core 4 found: USB 2.0 Device (manuf 0x4BF, id 0x81A, rev 0x11, class 0x0)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.938704] bcma: bus2: Found rev 17 PMU (capabilities 0x10A22B11)
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.938749] bcma: bus2: SPROM offset 0x800
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    2.970153] bcma: bus2: Invalid SPROM read from the PCIe card, trying to use fallback SPROM
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.980583] bcma: bus2: Using SPROM revision 11 provided by platform.
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.980597] bcma: bus2: PMU resource config unknown or not needed for device 0x4360
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.982598] bcma: bus2: Workarounds unknown or not needed for device 0x4360
Tue Mar  7 06:36:02 2017 kern.debug kernel: [    2.982608] bcma: bus2: Switched to core: 0x83C
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.982883] bcma: bus2: Bus registered
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.987444] NET: Registered protocol family 10
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.992902] NET: Registered protocol family 17
Tue Mar  7 06:36:02 2017 kern.info kernel: [    2.997402] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
Tue Mar  7 06:36:02 2017 kern.info kernel: [    3.010072] 8021q: 802.1Q VLAN Support v1.8
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.014333] Registering SWP/SWPB emulation handler
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.020778] UBI: auto-attach mtd4
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.023934] ubi0: attaching mtd4
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.677169] ubi0: scanning is finished
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.690240] ubi0: attached mtd4 (name "ubi", size 122 MiB)
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.695748] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.702656] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.709464] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.716452] ubi0: good PEBs: 976, bad PEBs: 0, corrupted PEBs: 0
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.722474] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.729711] ubi0: max/mean erase counter: 3/2, WL threshold: 4096, image sequence number: 153103624
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.738787] ubi0: available PEBs: 0, total reserved PEBs: 976, PEBs reserved for bad PEB handling: 20
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.748062] ubi0: background thread "ubi_bgt0d" started, PID 349
Tue Mar  7 06:36:02 2017 kern.info kernel: [    3.755073] block ubiblock0_0: created from ubi0:0(rootfs)
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    3.760607] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
Tue Mar  7 06:36:02 2017 kern.info kernel: [    3.771374] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Tue Mar  7 06:36:02 2017 kern.info kernel: [    3.778740] Freeing unused kernel memory: 224K (c03bc000 - c03f4000)
Tue Mar  7 06:36:02 2017 user.info kernel: [    4.161961] init: Console is alive
Tue Mar  7 06:36:02 2017 user.info kernel: [    4.165504] init: - watchdog -
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.356230] usbcore: registered new interface driver usbfs
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.361810] usbcore: registered new interface driver hub
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.367244] usbcore: registered new device driver usb
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.374556] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.381567] ehci-platform: EHCI generic platform driver
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.387959] ehci-platform 18021000.ehci: EHCI Host Controller
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.388425] bcm_ns_usb3 18105000.usb3-phy: Registered Broadcom Northstar USB 3.0 PHY driver
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.389353] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.389787] ohci-platform: OHCI generic platform driver
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.389943] ohci-platform 18022000.ohci: Generic Platform OHCI controller
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.389966] ohci-platform 18022000.ohci: new USB bus registered, assigned bus number 1
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.390079] ohci-platform 18022000.ohci: irq 29, io mem 0x18022000
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.434560] ehci-platform 18021000.ehci: new USB bus registered, assigned bus number 2
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.442637] ehci-platform 18021000.ehci: irq 29, io mem 0x18021000
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.456701] hub 1-0:1.0: USB hub found
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.460215] ehci-platform 18021000.ehci: USB 2.0 started, EHCI 1.00
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.466801] hub 1-0:1.0: 2 ports detected
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.471914] hub 2-0:1.0: USB hub found
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.474071] xhci-hcd 18023000.xhci: xHCI Host Controller
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.481393] hub 2-0:1.0: 2 ports detected
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.485713] xhci-hcd 18023000.xhci: new USB bus registered, assigned bus number 3
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.493491] xhci-hcd 18023000.xhci: hcc params 0x02501164 hci version 0x100 quirks 0x02010010
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.502116] xhci-hcd 18023000.xhci: irq 30, io mem 0x18023000
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.508457] hub 3-0:1.0: USB hub found
Tue Mar  7 06:36:02 2017 kern.err kernel: [    4.512274] hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.519570] xhci-hcd 18023000.xhci: xHCI Host Controller
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.524951] xhci-hcd 18023000.xhci: new USB bus registered, assigned bus number 4
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.542102] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.550720] hub 4-0:1.0: USB hub found
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.554547] hub 4-0:1.0: 1 port detected
Tue Mar  7 06:36:02 2017 user.info kernel: [    4.560349] init: - preinit -
Tue Mar  7 06:36:02 2017 kern.info kernel: [    4.817760] usb 2-2: new high-speed USB device number 2 using ehci-platform
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    4.972745] usb 2-2: config 1 has an invalid interface number: 12 but max is 3
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    4.980005] usb 2-2: config 1 has an invalid interface number: 13 but max is 3
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    4.987277] usb 2-2: config 1 has an invalid interface number: 13 but max is 3
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    4.994534] usb 2-2: config 1 has no interface number 1
Tue Mar  7 06:36:02 2017 kern.warn kernel: [    4.999782] usb 2-2: config 1 has no interface number 2
Tue Mar  7 06:36:02 2017 kern.info kernel: [    6.346849] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Tue Mar  7 06:36:02 2017 kern.info kernel: [    6.352841] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
Tue Mar  7 06:36:02 2017 kern.info kernel: [    8.200140] bgmac_bcma bcma0:3 eth0: Link is Up - 1Gbps/Full - flow control off
Tue Mar  7 06:36:02 2017 kern.info kernel: [    8.207494] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Mar  7 06:36:02 2017 kern.info kernel: [    8.213999] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.1: link becomes ready
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.486073] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 516
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.535459] UBIFS (ubi0:1): recovery needed
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.634800] UBIFS (ubi0:1): recovery completed
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.639337] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "rootfs_data"
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.647201] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.657151] UBIFS (ubi0:1): FS size: 117579776 bytes (112 MiB, 926 LEBs), journal size 5840896 bytes (5 MiB, 46 LEBs)
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.667793] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
Tue Mar  7 06:36:02 2017 kern.notice kernel: [    9.674430] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 648425AC-7A1A-4C59-B18C-FFB11DC7F8BB, small LPT model
Tue Mar  7 06:36:02 2017 user.info kernel: [    9.692755] mount_root: switching to ubifs overlay
Tue Mar  7 06:36:02 2017 user.warn kernel: [    9.704554] urandom-seed: Seeding with /etc/urandom.seed
Tue Mar  7 06:36:02 2017 user.info kernel: [    9.807638] procd: - early -
Tue Mar  7 06:36:02 2017 user.info kernel: [    9.810593] procd: - watchdog -
Tue Mar  7 06:36:02 2017 user.info kernel: [   10.452285] procd: - ubus -
Tue Mar  7 06:36:02 2017 user.info kernel: [   10.633126] procd: - init -
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.815301] ip6_tables: (C) 2000-2006 Netfilter Core Team
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.829013] usbcore: registered new interface driver cdc_wdm
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.835826] ip_tables: (C) 2000-2006 Netfilter Core Team
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.844255] nf_conntrack version 0.5.0 (3993 buckets, 15972 max)
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.951445] usbcore: registered new interface driver usbserial
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.957416] usbcore: registered new interface driver usbserial_generic
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.964040] usbserial: USB Serial support registered for generic
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.976055] xt_time: kernel timezone is -0000
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.983374] usbcore: registered new interface driver cdc_ncm
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.993536] PPP generic driver version 2.4.2
Tue Mar  7 06:36:02 2017 kern.info kernel: [   10.998578] NET: Registered protocol family 24
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.004000] usbcore: registered new interface driver sierra
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.009673] usbserial: USB Serial support registered for Sierra USB modem
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.017502] usbcore: registered new interface driver sierra_net
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.042976] cdc_mbim 2-2:1.12: cdc-wdm0: USB WDM device
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.049049] cdc_mbim 2-2:1.12 wwan0: register 'cdc_mbim' at usb-18021000.ehci-2, CDC MBIM, 42:b6:7e:00:90:f9
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.059116] usbcore: registered new interface driver cdc_mbim
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.067515] usbcore: registered new interface driver qcserial
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.073443] usbserial: USB Serial support registered for Qualcomm USB modem
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.080927] qcserial 2-2:1.0: Qualcomm USB modem converter detected
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.087527] usb 2-2: Qualcomm USB modem converter now attached to ttyUSB0
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.094806] qcserial 2-2:1.3: Qualcomm USB modem converter detected
Tue Mar  7 06:36:02 2017 kern.info kernel: [   11.101365] usb 2-2: Qualcomm USB modem converter now attached to ttyUSB1
Tue Mar  7 06:36:03 2017 user.notice : Added device handler type: tunnel
Tue Mar  7 06:36:03 2017 user.notice : Added device handler type: Network device
Tue Mar  7 06:36:03 2017 user.notice : Added device handler type: bridge
Tue Mar  7 06:36:03 2017 user.notice : Added device handler type: macvlan
Tue Mar  7 06:36:03 2017 user.notice : Added device handler type: 8021ad
Tue Mar  7 06:36:03 2017 user.notice : Added device handler type: 8021q
Tue Mar  7 06:36:03 2017 authpriv.info dropbear[964]: Not backgrounding
Tue Mar  7 06:36:03 2017 kern.info kernel: [   13.395699] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Tue Mar  7 06:36:03 2017 kern.info kernel: [   13.409080] device eth0.1 entered promiscuous mode
Tue Mar  7 06:36:03 2017 kern.info kernel: [   13.413971] device eth0 entered promiscuous mode
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'lan' is enabled
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'lan' is setting up now
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'lan' is now up
Tue Mar  7 06:36:03 2017 kern.info kernel: [   13.424749] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'loopback' is enabled
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'loopback' is setting up now
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'loopback' is now up
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'wan' is setting up now
Tue Mar  7 06:36:03 2017 kern.info kernel: [   13.459243] IPv6: ADDRCONF(NETDEV_UP): eth0.2: link is not ready
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'wan6' is enabled
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Network device 'lo' link is up
Tue Mar  7 06:36:03 2017 daemon.info odhcpd[930]: Raising SIGUSR1 due to address change on br-lan
Tue Mar  7 06:36:03 2017 daemon.notice netifd: Interface 'loopback' has link connectivity
Tue Mar  7 06:36:03 2017 daemon.notice netifd: wan (1051): mbim[1051] Reading capabilities
Tue Mar  7 06:36:03 2017 daemon.info procd: - init complete -
Tue Mar  7 06:36:04 2017 kern.info kernel: [   14.200141] bgmac_bcma bcma0:3 eth0: Link is Up - 1Gbps/Full - flow control off
Tue Mar  7 06:36:04 2017 kern.info kernel: [   14.207606] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Tue Mar  7 06:36:04 2017 kern.info kernel: [   14.214190] br-lan: port 1(eth0.1) entered forwarding state
Tue Mar  7 06:36:04 2017 daemon.notice netifd: VLAN 'eth0.1' link is up
Tue Mar  7 06:36:04 2017 daemon.notice netifd: VLAN 'eth0.2' link is up
Tue Mar  7 06:36:04 2017 daemon.notice netifd: Interface 'wan6' has link connectivity
Tue Mar  7 06:36:04 2017 daemon.notice netifd: Interface 'wan6' is setting up now
Tue Mar  7 06:36:04 2017 daemon.notice netifd: Network device 'eth0' link is up
Tue Mar  7 06:36:04 2017 kern.info kernel: [   14.219841] br-lan: port 1(eth0.1) entered forwarding state
Tue Mar  7 06:36:04 2017 kern.info kernel: [   14.225612] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.2: link becomes ready
Tue Mar  7 06:36:04 2017 daemon.notice netifd: bridge 'br-lan' link is up
Tue Mar  7 06:36:04 2017 daemon.notice netifd: Interface 'lan' has link connectivity
Tue Mar  7 06:36:04 2017 kern.info kernel: [   14.232451] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Tue Mar  7 06:36:04 2017 daemon.err odhcp6c[1143]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
Tue Mar  7 06:36:05 2017 daemon.info odhcpd[930]: Initial RA router lifetime 0, 1 address(es) available on br-lan
Tue Mar  7 06:36:05 2017 daemon.notice odhcpd[930]: Failed to send to ff02::1%br-lan (Address not available)
Tue Mar  7 06:36:05 2017 daemon.err odhcp6c[1143]: Failed to send DHCPV6 message to ff02::1:2 (Address not available)
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   devicetype: 0003 - remote
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   cellularclass: 0001
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   voiceclass: 0001 - no-voice
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   simclass: 0002
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   dataclass: 003C
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   smscaps: 0003
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   controlcaps: 0001
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   maxsessions: 0008
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   deviceid: 353990070991463
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   firmwareinfo: SWI9X30C_02.20.03.00
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051):   hardwareinfo: EM7455
Tue Mar  7 06:36:05 2017 daemon.notice netifd: wan (1051): mbim[1051] Checking subscriber
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   readystate: 0001 - initialized
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   simiccid: 89011201002225290349
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   subscriberid: 310120222529034
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): mbim[1051] Register with network
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   nwerror: 0000 - unknown
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   registerstate: 0003 - home
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   registermode: 0001 - automatic
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   availabledataclasses: 0020 - lte
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   currentcellularclass: 0001 - gsm
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   provider_id: 310120
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   provider_name: Sprint
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   roamingtext: (null)
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): mbim[1051] Attach to network
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   packetservicestate: 0002 - attached
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   uplinkspeed: 50000000
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   downlinkspeed: 300000000
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): mbim[1051] Connect to network
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   sessionid: 0
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   activationstate: 0001 - activated
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   voicecallstate: 0000 - none
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051):   iptype: 0003 - ipv4v6
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): mbim[1051] Get IP config
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): IP: 173.153.140.124
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): MASK: 255.255.255.248
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): GW: 173.153.140.125
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): DNS: 68.28.31.30
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): mbim[1051] Connected, setting IP
Tue Mar  7 06:36:06 2017 daemon.notice netifd: Interface 'wan' is now up
Tue Mar  7 06:36:06 2017 kern.info kernel: [   16.147956] 8021q: adding VLAN 0 to HW filter on device wwan0
Tue Mar  7 06:36:06 2017 daemon.notice netifd: Network device 'wwan0' link is up
Tue Mar  7 06:36:06 2017 kern.info kernel: [   16.210176] br-lan: port 1(eth0.1) entered forwarding state
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): iptables: No chain/target/match by that name.
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): Loopback created for IP: 173.153.140.124
Tue Mar  7 06:36:06 2017 daemon.notice netifd: wan (1051): LTE-Watchdog started
Tue Mar  7 06:36:07 2017 daemon.info odhcpd[930]: Initial RA router lifetime 0, 1 address(es) available on br-lan
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: started, version 2.76 cachesize 150
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID loop-detect inotify
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: DNS service limited to local subnets
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq-dhcp[1300]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: using local addresses only for domain lan
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: reading /tmp/resolv.conf.auto
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: using nameserver 68.28.31.30#53
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: read /etc/hosts - 4 addresses
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: read /tmp/hosts/odhcpd - 0 addresses
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq[1300]: read /tmp/hosts/dhcp.cfg02411c - 2 addresses
Tue Mar  7 06:36:11 2017 daemon.info dnsmasq-dhcp[1300]: read /etc/ethers - 0 addresses
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq-dhcp[1300]: DHCPDISCOVER(br-lan) 192.168.1.182 ec:f4:bb:22:98:8f
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq-dhcp[1300]: DHCPOFFER(br-lan) 192.168.1.182 ec:f4:bb:22:98:8f
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq-dhcp[1300]: DHCPREQUEST(br-lan) 192.168.1.182 ec:f4:bb:22:98:8f
Tue Mar  7 06:36:46 2017 daemon.warn dnsmasq-dhcp[1300]: Ignoring domain oclad.oncourselearning.com for DHCP host name GHG-VA-8R3VXZ1
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq-dhcp[1300]: DHCPACK(br-lan) 192.168.1.182 ec:f4:bb:22:98:8f GHG-VA-8R3VXZ1
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq[1300]: read /etc/hosts - 4 addresses
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq[1300]: read /tmp/hosts/odhcpd - 0 addresses
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq[1300]: read /tmp/hosts/dhcp.cfg02411c - 2 addresses
Tue Mar  7 06:36:46 2017 daemon.info dnsmasq-dhcp[1300]: read /etc/ethers - 0 addresses
Tue Mar  7 06:37:12 2017 daemon.info dnsmasq-dhcp[1300]: DHCPINFORM(br-lan) 192.168.1.182 ec:f4:bb:22:98:8f
Tue Mar  7 06:37:12 2017 daemon.info dnsmasq-dhcp[1300]: DHCPACK(br-lan) 192.168.1.182 ec:f4:bb:22:98:8f GHG-VA-8R3VXZ1
Tue Mar  7 06:37:12 2017 daemon.info dnsmasq-dhcp[1300]: DHCPINFORM(br-lan) 192.168.117.1 56:f1:79:ff:64:13
Tue Mar  7 06:37:12 2017 daemon.info dnsmasq-dhcp[1300]: DHCPACK(br-lan) 192.168.117.1 56:f1:79:ff:64:13 GHG-VA-8R3VXZ1
Tue Mar  7 06:37:12 2017 daemon.info dnsmasq-dhcp[1300]: DHCPINFORM(br-lan) 192.168.232.1 00:50:56:c0:00:08
Tue Mar  7 06:37:12 2017 daemon.info dnsmasq-dhcp[1300]: DHCPACK(br-lan) 192.168.232.1 00:50:56:c0:00:08 GHG-VA-8R3VXZ1
Tue Mar  7 06:37:15 2017 daemon.notice netifd: Interface 'wan6' is now down
Tue Mar  7 06:37:15 2017 daemon.notice netifd: Interface 'wan6' is disabled
Tue Mar  7 06:37:15 2017 daemon.warn dnsmasq[1300]: no servers found in /tmp/resolv.conf.auto, will retry
Tue Mar  7 06:37:15 2017 daemon.notice netifd: VLAN 'eth0.2' link is down
Tue Mar  7 06:37:15 2017 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Tue Mar  7 06:37:16 2017 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Tue Mar  7 06:37:16 2017 user.notice root: Interface wan successful restarted
Tue Mar  7 06:37:16 2017 user.notice root: LTE-Watchdog ended
Tue Mar  7 06:37:16 2017 daemon.notice netifd: wan (1376): mbim[1376] Stopping network
Tue Mar  7 06:37:17 2017 daemon.notice netifd: Interface 'wan' is now down
Tue Mar  7 06:37:17 2017 daemon.notice netifd: Interface 'wan' is setting up now
Tue Mar  7 06:37:17 2017 daemon.notice netifd: wan (1389): mbim[1389] Reading capabilities
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   devicetype: 0003 - remote
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   cellularclass: 0001
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   voiceclass: 0001 - no-voice
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   simclass: 0002
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   dataclass: 003C
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   smscaps: 0003
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   controlcaps: 0001
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   maxsessions: 0008
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   deviceid: 353990070991463
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   firmwareinfo: SWI9X30C_02.20.03.00
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   hardwareinfo: EM7455
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): mbim[1389] Checking subscriber
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   readystate: 0001 - initialized
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   simiccid: 89011201002225290349
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   subscriberid: 310120222529034
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): mbim[1389] Register with network
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   nwerror: 0000 - unknown
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   registerstate: 0003 - home
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   registermode: 0001 - automatic
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   availabledataclasses: 0020 - lte
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   currentcellularclass: 0001 - gsm
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   provider_id: 310120
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   provider_name: Sprint
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   roamingtext: (null)
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): mbim[1389] Attach to network
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   packetservicestate: 0002 - attached
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   uplinkspeed: 50000000
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   downlinkspeed: 300000000
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): mbim[1389] Connect to network
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   sessionid: 0
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   activationstate: 0001 - activated
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   voicecallstate: 0000 - none
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389):   iptype: 0003 - ipv4v6
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): mbim[1389] Get IP config
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): IP: 173.153.231.141
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): MASK: 255.255.255.252
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): GW: 173.153.231.142
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): DNS: 68.28.31.30
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): mbim[1389] Connected, setting IP
Tue Mar  7 06:37:20 2017 daemon.notice netifd: Interface 'wan' is now up
Tue Mar  7 06:37:20 2017 daemon.notice netifd: Network device 'wwan0' link is up
Tue Mar  7 06:37:20 2017 kern.info kernel: [   60.571750] 8021q: adding VLAN 0 to HW filter on device wwan0
Tue Mar  7 06:37:20 2017 daemon.info dnsmasq[1300]: reading /tmp/resolv.conf.auto
Tue Mar  7 06:37:20 2017 daemon.info dnsmasq[1300]: using local addresses only for domain lan
Tue Mar  7 06:37:20 2017 daemon.info dnsmasq[1300]: using nameserver 68.28.31.30#53
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): iptables: No chain/target/match by that name.
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): Loopback created for IP: 173.153.231.141
Tue Mar  7 06:37:20 2017 daemon.notice netifd: wan (1389): LTE-Watchdog started
What version of lede are you using?
40 down and .01 up sounds like something is messed up with your antenna setup possibly. This happened to me when I was using the auxiliary antenna port only and not the main. You are not mismatching RP-SMA and SMA fittings are you?
I am using 17.01.0 found in the list lede-project.org/toh/views/toh_fwdownload
I’ll try the newer version
the antenna connector should be correct, when connect to computer it’s uploading at 10+ mbps.
even on speedtest it shows 0.01 upload, it still upload at 10+mbps to google drive
I had this problem when using Sprint…but now I’ve switched to Verizon and it doesn’t happen anymore. I wonder if it just depends on what tower we’re on.
On another note, here is my biggest problem…and I hope someone can help me cause it’s driving me absolutely mad! If I ever need to restart the router, I have a hell of a time getting connected to the internet again. After every reboot, the router reverts back to a previous date/time. I can sync the date/time with my browser but this never helps. The router has to somehow get it on its own. I don’t know if this is the actual problem, or just contributing. Right now, this is really my only problem. It happened when I had Sprint, and it happens now that I have Verizon. Seems to me like it is either software/hardware related…maybe a timing issue. I spent 45 minutes yesterday rebooting the router over and over and watching the logs until it finally got the right date/time and gave me an internet connection. Very frustrating. Here is the log from when it happened back in December when I had Sprint. I don’t know linux so I can’t tell if there are any clues here as to why the WAN keeps going down. I have the modem plugged into a powered USB adapter so I don’t believe it’s a power issue.
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   registermode: 0001 - automatic
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   availabledataclasses: 0020 - lte
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   currentcellularclass: 0001 - gsm
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   provider_id: 310120
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   provider_name: Sprint
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   roamingtext: (null)
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): mbim[2538] Attach to network
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   nwerror: 0000 - unknown
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   packetservicestate: 0002 - attached
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   uplinkspeed: 50000000
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   downlinkspeed: 300000000
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): mbim[2538] Connect to network
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   sessionid: 0
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   activationstate: 0001 - activated
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   voicecallstate: 0000 - none
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538):   iptype: 0001 - ipv4
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): mbim[2538] Get IP config
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): IP: 184.223.217.137
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): MASK: 255.255.255.252
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): GW: 184.223.217.138
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): DNS: 66.1.20.132
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): mbim[2538] Connected, setting IP
Wed Dec 21 11:48:22 2016 kern.info kernel: [   49.479027] 8021q: adding VLAN 0 to HW filter on device wwan0
Wed Dec 21 11:48:22 2016 daemon.notice netifd: Interface 'wan' is now up
Wed Dec 21 11:48:22 2016 daemon.notice netifd: Network device 'wwan0' link is up
Wed Dec 21 11:48:22 2016 daemon.info dnsmasq[2348]: reading /tmp/resolv.conf.auto
Wed Dec 21 11:48:22 2016 daemon.info dnsmasq[2348]: using local addresses only for domain lan
Wed Dec 21 11:48:22 2016 daemon.info dnsmasq[2348]: using nameserver 66.1.20.132#53
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): Loopback created for IP: 184.223.217.137
Wed Dec 21 11:48:22 2016 daemon.notice netifd: wan (2538): LTE-Watchdog started
Wed Dec 21 11:48:22 2016 user.notice firewall: Reloading firewall due to ifup of wan (wwan0)
Wed Dec 21 20:58:17 2016 cron.err crond[1333]: time disparity of 550 minutes detected
Wed Dec 21 21:53:08 2016 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Wed Dec 21 21:53:08 2016 daemon.warn dnsmasq[2348]: no servers found in /tmp/resolv.conf.auto, will retry
Wed Dec 21 21:53:08 2016 daemon.notice netifd: wan (3345): mbim[3345] Stopping network
Wed Dec 21 21:53:08 2016 user.notice root: Interface wan successful restarted
Wed Dec 21 21:53:08 2016 user.notice root: LTE-Watchdog ended
Wed Dec 21 21:53:08 2016 kern.debug kernel: [ 3378.094048] ieee80211 phy0: change: 0x60
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3378.202676] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:09 2016 daemon.notice netifd: Network device 'wlan0' link is down
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.215890] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.319835] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3378.367683] ieee80211 phy1: change: 0x40
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3378.459660] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.483974] device wlan0 left promiscuous mode
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.488453] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:09 2016 daemon.notice netifd: Network device 'wlan1' link is down
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.543897] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.575990] device wlan1 left promiscuous mode
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.580472] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio0 (3437): command failed: Not supported (-95)
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio0 (3437): Configuration file: /var/run/hostapd-phy0.conf
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3378.767651] ieee80211 phy0: change: 0xffffffff
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio0 (3437): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio0 (3437): wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3378.882867] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3378.890450] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio1 (3472): command failed: Not supported (-95)
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3378.902676] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio1 (3472): Configuration file: /var/run/hostapd-phy1.conf
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3379.043659] ieee80211 phy1: change: 0xffffffff
Wed Dec 21 21:53:09 2016 kern.debug kernel: [ 3379.119644] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio1 (3472): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:09 2016 daemon.notice netifd: radio1 (3472): Using interface wlan1 with hwaddr 16:91:82:b8:24:d8 and ssid "LINKSYS2.4"
Wed Dec 21 21:53:09 2016 kern.info kernel: [ 3379.143855] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Dec 21 21:53:10 2016 kern.debug kernel: [ 3379.206229] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:10 2016 kern.debug kernel: [ 3379.217667] ieee80211 phy1: change: 0x42
Wed Dec 21 21:53:10 2016 kern.debug kernel: [ 3379.335634] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.379726] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Dec 21 21:53:10 2016 kern.debug kernel: [ 3379.435635] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:10 2016 daemon.notice netifd: radio0 (3437): Using interface wlan0 with hwaddr 16:91:82:b8:24:d9 and ssid "LINKSYS5N"
Wed Dec 21 21:53:10 2016 daemon.notice netifd: radio1 (3472): wlan1: interface state COUNTRY_UPDATE->ENABLED
Wed Dec 21 21:53:10 2016 daemon.notice netifd: radio1 (3472): wlan1: AP-ENABLED
Wed Dec 21 21:53:10 2016 kern.debug kernel: [ 3379.547656] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:10 2016 kern.debug kernel: [ 3379.559621] ieee80211 phy0: change: 0x42
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.763635] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Dec 21 21:53:10 2016 daemon.notice netifd: radio0 (3437): wlan0: interface state HT_SCAN->ENABLED
Wed Dec 21 21:53:10 2016 daemon.notice netifd: radio0 (3437): wlan0: AP-ENABLED
Wed Dec 21 21:53:10 2016 daemon.notice netifd: Network device 'wlan1' link is up
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.925714] device wlan1 entered promiscuous mode
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.930519] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.936068] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:10 2016 kern.debug kernel: [ 3379.941960] ieee80211 phy0: change: 0x20
Wed Dec 21 21:53:10 2016 daemon.notice netifd: Network device 'wlan0' link is up
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.965294] device wlan0 entered promiscuous mode
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.970105] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:10 2016 kern.info kernel: [ 3379.975647] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:11 2016 daemon.notice netifd: wan (3345):   sessionid: 0
Wed Dec 21 21:53:11 2016 daemon.notice netifd: wan (3345):   activationstate: 0003 - deactivated
Wed Dec 21 21:53:11 2016 daemon.notice netifd: wan (3345):   voicecallstate: 0000 - none
Wed Dec 21 21:53:11 2016 daemon.notice netifd: wan (3345):   nwerror: 0000 - unknown
Wed Dec 21 21:53:11 2016 daemon.notice netifd: wan (3345):   iptype: 0000 - default
Wed Dec 21 21:53:11 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:11 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:11 2016 daemon.notice netifd: wan (3608): mbim[3608] Reading capabilities
Wed Dec 21 21:53:12 2016 kern.info kernel: [ 3381.939541] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:12 2016 kern.info kernel: [ 3381.979536] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:13 2016 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Wed Dec 21 21:53:13 2016 daemon.notice netifd: wan (3623): mbim[3623] Stopping network
Wed Dec 21 21:53:13 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:13 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:13 2016 daemon.notice netifd: wan (3633): mbim[3633] Reading capabilities
Wed Dec 21 21:53:14 2016 user.notice root: Interface wan successful restarted
Wed Dec 21 21:53:14 2016 user.notice root: LTE-Watchdog ended
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3383.194677] ieee80211 phy0: change: 0x60
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3383.302508] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:14 2016 daemon.notice netifd: Network device 'wlan0' link is down
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.315742] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.411649] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3383.459502] ieee80211 phy1: change: 0x40
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3383.547489] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.571784] device wlan0 left promiscuous mode
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.576265] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:14 2016 daemon.notice netifd: Network device 'wlan1' link is down
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.619684] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.647813] device wlan1 left promiscuous mode
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.652297] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:14 2016 daemon.notice netifd: radio0 (3691): command failed: Not supported (-95)
Wed Dec 21 21:53:14 2016 daemon.notice netifd: radio0 (3691): Configuration file: /var/run/hostapd-phy0.conf
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3383.847483] ieee80211 phy0: change: 0xffffffff
Wed Dec 21 21:53:14 2016 daemon.notice netifd: radio0 (3691): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:14 2016 daemon.notice netifd: radio0 (3691): wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Dec 21 21:53:14 2016 kern.info kernel: [ 3383.962694] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3383.970319] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3383.982516] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:14 2016 daemon.notice netifd: radio1 (3722): command failed: Not supported (-95)
Wed Dec 21 21:53:14 2016 daemon.notice netifd: radio1 (3722): Configuration file: /var/run/hostapd-phy1.conf
Wed Dec 21 21:53:14 2016 kern.debug kernel: [ 3384.127475] ieee80211 phy1: change: 0xffffffff
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3384.195484] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:15 2016 daemon.notice netifd: radio1 (3722): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:15 2016 daemon.notice netifd: radio1 (3722): Using interface wlan1 with hwaddr 16:91:82:b8:24:d8 and ssid "LINKSYS2.4"
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3384.230698] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3384.292903] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3384.305975] ieee80211 phy1: change: 0x42
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3384.411466] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3384.463525] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3384.518472] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:15 2016 daemon.notice netifd: radio0 (3691): Using interface wlan0 with hwaddr 16:91:82:b8:24:d9 and ssid "LINKSYS5N"
Wed Dec 21 21:53:15 2016 daemon.notice netifd: radio1 (3722): wlan1: interface state COUNTRY_UPDATE->ENABLED
Wed Dec 21 21:53:15 2016 daemon.notice netifd: radio1 (3722): wlan1: AP-ENABLED
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3384.639487] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3384.651452] ieee80211 phy0: change: 0x42
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3384.855470] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Dec 21 21:53:15 2016 daemon.notice netifd: radio0 (3691): wlan0: interface state HT_SCAN->ENABLED
Wed Dec 21 21:53:15 2016 daemon.notice netifd: radio0 (3691): wlan0: AP-ENABLED
Wed Dec 21 21:53:15 2016 daemon.notice netifd: Network device 'wlan1' link is up
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3385.021692] device wlan1 entered promiscuous mode
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3385.026544] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3385.032092] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:15 2016 kern.debug kernel: [ 3385.037856] ieee80211 phy0: change: 0x20
Wed Dec 21 21:53:15 2016 daemon.notice netifd: wan (3835): mbim[3835] Stopping network
Wed Dec 21 21:53:15 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:15 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:15 2016 daemon.notice netifd: Network device 'wlan0' link is up
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3385.059458] device wlan0 entered promiscuous mode
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3385.064294] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:15 2016 kern.info kernel: [ 3385.069857] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:15 2016 daemon.notice netifd: wan (3845): mbim[3845] Reading capabilities
Wed Dec 21 21:53:17 2016 kern.info kernel: [ 3387.035371] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:17 2016 kern.info kernel: [ 3387.071368] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:19 2016 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Wed Dec 21 21:53:19 2016 daemon.notice netifd: wan (3860): mbim[3860] Stopping network
Wed Dec 21 21:53:19 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:19 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:19 2016 daemon.notice netifd: wan (3870): mbim[3870] Reading capabilities
Wed Dec 21 21:53:19 2016 kern.debug kernel: [ 3388.287360] ieee80211 phy0: change: 0x60
Wed Dec 21 21:53:19 2016 user.notice root: Interface wan successful restarted
Wed Dec 21 21:53:19 2016 user.notice root: LTE-Watchdog ended
Wed Dec 21 21:53:19 2016 kern.debug kernel: [ 3388.394345] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:19 2016 daemon.notice netifd: Network device 'wlan0' link is down
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3388.407576] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3388.503475] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3388.523611] device wlan0 left promiscuous mode
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3388.528103] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:19 2016 kern.debug kernel: [ 3388.595335] ieee80211 phy1: change: 0x40
Wed Dec 21 21:53:19 2016 kern.debug kernel: [ 3388.687320] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:19 2016 daemon.notice netifd: radio0 (3927): command failed: Not supported (-95)
Wed Dec 21 21:53:19 2016 daemon.notice netifd: Network device 'wlan1' link is down
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3388.727483] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3388.767621] device wlan1 left promiscuous mode
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3388.772101] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:19 2016 daemon.notice netifd: radio0 (3927): Configuration file: /var/run/hostapd-phy0.conf
Wed Dec 21 21:53:19 2016 kern.debug kernel: [ 3388.911320] ieee80211 phy0: change: 0xffffffff
Wed Dec 21 21:53:19 2016 daemon.notice netifd: radio0 (3927): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:19 2016 daemon.notice netifd: radio0 (3927): wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Dec 21 21:53:19 2016 kern.info kernel: [ 3389.026533] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Dec 21 21:53:19 2016 kern.debug kernel: [ 3389.035111] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:19 2016 kern.debug kernel: [ 3389.047345] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:19 2016 daemon.notice netifd: radio1 (3985): command failed: Not supported (-95)
Wed Dec 21 21:53:19 2016 daemon.notice netifd: radio1 (3985): Configuration file: /var/run/hostapd-phy1.conf
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.195305] ieee80211 phy1: change: 0xffffffff
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.263307] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:20 2016 daemon.notice netifd: radio1 (3985): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:20 2016 daemon.notice netifd: radio1 (3985): Using interface wlan1 with hwaddr 16:91:82:b8:24:d8 and ssid "LINKSYS2.4"
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3389.295514] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.357361] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.370318] ieee80211 phy1: change: 0x42
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.475298] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3389.527356] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.583303] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:20 2016 daemon.notice netifd: radio0 (3927): Using interface wlan0 with hwaddr 16:91:82:b8:24:d9 and ssid "LINKSYS5N"
Wed Dec 21 21:53:20 2016 daemon.notice netifd: radio1 (3985): wlan1: interface state COUNTRY_UPDATE->ENABLED
Wed Dec 21 21:53:20 2016 daemon.notice netifd: radio1 (3985): wlan1: AP-ENABLED
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.704202] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3389.715302] ieee80211 phy0: change: 0x42
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3389.887306] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Dec 21 21:53:20 2016 daemon.notice netifd: Network device 'wlan1' link is up
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3390.090635] device wlan1 entered promiscuous mode
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3390.095431] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3390.100969] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:20 2016 daemon.notice netifd: radio0 (3927): wlan0: interface state HT_SCAN->ENABLED
Wed Dec 21 21:53:20 2016 daemon.notice netifd: radio0 (3927): wlan0: AP-ENABLED
Wed Dec 21 21:53:20 2016 kern.debug kernel: [ 3390.113658] ieee80211 phy0: change: 0x20
Wed Dec 21 21:53:20 2016 daemon.notice netifd: wan (4069): mbim[4069] Stopping network
Wed Dec 21 21:53:20 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:20 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:20 2016 daemon.notice netifd: Network device 'wlan0' link is up
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3390.133209] device wlan0 entered promiscuous mode
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3390.138036] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:20 2016 kern.info kernel: [ 3390.143588] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:20 2016 daemon.notice netifd: wan (4077): mbim[4077] Reading capabilities
Wed Dec 21 21:53:22 2016 kern.info kernel: [ 3392.103208] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:23 2016 kern.info kernel: [ 3392.147202] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:24 2016 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Wed Dec 21 21:53:24 2016 daemon.notice netifd: wan (4096): mbim[4096] Stopping network
Wed Dec 21 21:53:24 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:24 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:24 2016 daemon.notice netifd: wan (4103): mbim[4103] Reading capabilities
Wed Dec 21 21:53:24 2016 user.notice root: Interface wan successful restarted
Wed Dec 21 21:53:24 2016 user.notice root: LTE-Watchdog ended
Wed Dec 21 21:53:24 2016 kern.debug kernel: [ 3393.403216] ieee80211 phy0: change: 0x60
Wed Dec 21 21:53:24 2016 kern.debug kernel: [ 3393.510176] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:24 2016 daemon.notice netifd: Network device 'wlan0' link is down
Wed Dec 21 21:53:24 2016 kern.info kernel: [ 3393.523409] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:24 2016 kern.info kernel: [ 3393.619318] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:24 2016 kern.debug kernel: [ 3393.667169] ieee80211 phy1: change: 0x40
Wed Dec 21 21:53:24 2016 kern.debug kernel: [ 3393.759154] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:24 2016 kern.info kernel: [ 3393.783457] device wlan0 left promiscuous mode
Wed Dec 21 21:53:24 2016 kern.info kernel: [ 3393.787938] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:24 2016 daemon.notice netifd: Network device 'wlan1' link is down
Wed Dec 21 21:53:24 2016 kern.info kernel: [ 3393.831356] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:24 2016 kern.info kernel: [ 3393.859452] device wlan1 left promiscuous mode
Wed Dec 21 21:53:24 2016 kern.info kernel: [ 3393.863936] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:24 2016 daemon.notice netifd: radio0 (4163): command failed: Not supported (-95)
Wed Dec 21 21:53:24 2016 daemon.notice netifd: radio0 (4163): Configuration file: /var/run/hostapd-phy0.conf
Wed Dec 21 21:53:24 2016 daemon.notice netifd: radio1 (4193): command failed: Not supported (-95)
Wed Dec 21 21:53:24 2016 kern.debug kernel: [ 3394.059148] ieee80211 phy0: change: 0xffffffff
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio0 (4163): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio0 (4163): wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Dec 21 21:53:25 2016 kern.info kernel: [ 3394.174360] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.182237] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.195302] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio1 (4193): Configuration file: /var/run/hostapd-phy1.conf
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.315142] ieee80211 phy1: change: 0xffffffff
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.407137] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio1 (4193): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio1 (4193): Using interface wlan1 with hwaddr 16:91:82:b8:24:d8 and ssid "LINKSYS2.4"
Wed Dec 21 21:53:25 2016 kern.info kernel: [ 3394.418319] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.480400] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.492484] ieee80211 phy1: change: 0x42
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.627134] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:25 2016 kern.info kernel: [ 3394.647189] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.734141] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio1 (4193): wlan1: interface state COUNTRY_UPDATE->ENABLED
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio0 (4163): Using interface wlan0 with hwaddr 16:91:82:b8:24:d9 and ssid "LINKSYS5N"
Wed Dec 21 21:53:25 2016 daemon.notice netifd: radio1 (4193): wlan1: AP-ENABLED
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.839180] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:25 2016 kern.debug kernel: [ 3394.851125] ieee80211 phy0: change: 0x42
Wed Dec 21 21:53:25 2016 kern.info kernel: [ 3395.023140] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Dec 21 21:53:26 2016 daemon.notice netifd: radio0 (4163): wlan0: interface state HT_SCAN->ENABLED
Wed Dec 21 21:53:26 2016 daemon.notice netifd: radio0 (4163): wlan0: AP-ENABLED
Wed Dec 21 21:53:26 2016 kern.debug kernel: [ 3395.226298] ieee80211 phy0: change: 0x20
Wed Dec 21 21:53:26 2016 daemon.notice netifd: Network device 'wlan1' link is up
Wed Dec 21 21:53:26 2016 kern.info kernel: [ 3395.248909] device wlan1 entered promiscuous mode
Wed Dec 21 21:53:26 2016 kern.info kernel: [ 3395.254009] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:26 2016 kern.info kernel: [ 3395.259559] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:26 2016 daemon.notice netifd: Network device 'wlan0' link is up
Wed Dec 21 21:53:26 2016 kern.info kernel: [ 3395.267779] device wlan0 entered promiscuous mode
Wed Dec 21 21:53:26 2016 kern.info kernel: [ 3395.272671] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:26 2016 kern.info kernel: [ 3395.278213] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:26 2016 daemon.notice netifd: wan (4313): mbim[4313] Stopping network
Wed Dec 21 21:53:26 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:26 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:26 2016 daemon.notice netifd: wan (4317): mbim[4317] Reading capabilities
Wed Dec 21 21:53:28 2016 kern.info kernel: [ 3397.263039] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:28 2016 kern.info kernel: [ 3397.279036] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:29 2016 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Wed Dec 21 21:53:29 2016 daemon.notice netifd: wan (4332): mbim[4332] Stopping network
Wed Dec 21 21:53:29 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:29 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:29 2016 daemon.notice netifd: wan (4346): mbim[4346] Reading capabilities
Wed Dec 21 21:53:29 2016 user.notice root: Interface wan successful restarted
Wed Dec 21 21:53:29 2016 user.notice root: LTE-Watchdog ended
Wed Dec 21 21:53:29 2016 kern.debug kernel: [ 3398.507039] ieee80211 phy0: change: 0x60
Wed Dec 21 21:53:29 2016 kern.debug kernel: [ 3398.615003] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:29 2016 kern.info kernel: [ 3398.627239] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:29 2016 daemon.notice netifd: Network device 'wlan0' link is down
Wed Dec 21 21:53:29 2016 kern.info kernel: [ 3398.723138] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:29 2016 kern.info kernel: [ 3398.747285] device wlan0 left promiscuous mode
Wed Dec 21 21:53:29 2016 kern.info kernel: [ 3398.751765] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:29 2016 kern.debug kernel: [ 3398.819005] ieee80211 phy1: change: 0x40
Wed Dec 21 21:53:29 2016 kern.debug kernel: [ 3398.910991] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:29 2016 daemon.notice netifd: radio0 (4399): command failed: Not supported (-95)
Wed Dec 21 21:53:29 2016 daemon.notice netifd: Network device 'wlan1' link is down
Wed Dec 21 21:53:29 2016 kern.info kernel: [ 3398.951160] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:29 2016 kern.info kernel: [ 3398.979357] device wlan1 left promiscuous mode
Wed Dec 21 21:53:29 2016 kern.info kernel: [ 3398.983845] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:29 2016 daemon.notice netifd: radio0 (4399): Configuration file: /var/run/hostapd-phy0.conf
Wed Dec 21 21:53:29 2016 kern.debug kernel: [ 3399.126984] ieee80211 phy0: change: 0xffffffff
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio0 (4399): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio0 (4399): wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Dec 21 21:53:30 2016 kern.info kernel: [ 3399.242204] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.250070] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.262997] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio1 (4449): command failed: Not supported (-95)
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio1 (4449): Configuration file: /var/run/hostapd-phy1.conf
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.410975] ieee80211 phy1: change: 0xffffffff
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.474973] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio1 (4449): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio1 (4449): Using interface wlan1 with hwaddr 16:91:82:b8:24:d8 and ssid "LINKSYS2.4"
Wed Dec 21 21:53:30 2016 kern.info kernel: [ 3399.510198] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.572375] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.585439] ieee80211 phy1: change: 0x42
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.690967] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:30 2016 kern.info kernel: [ 3399.743031] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.802967] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio0 (4399): Using interface wlan0 with hwaddr 16:91:82:b8:24:d9 and ssid "LINKSYS5N"
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio1 (4449): wlan1: interface state COUNTRY_UPDATE->ENABLED
Wed Dec 21 21:53:30 2016 daemon.notice netifd: radio1 (4449): wlan1: AP-ENABLED
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.935910] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:30 2016 kern.debug kernel: [ 3399.948975] ieee80211 phy0: change: 0x42
Wed Dec 21 21:53:30 2016 kern.info kernel: [ 3400.118970] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Dec 21 21:53:31 2016 daemon.notice netifd: Network device 'wlan1' link is up
Wed Dec 21 21:53:31 2016 kern.info kernel: [ 3400.267100] device wlan1 entered promiscuous mode
Wed Dec 21 21:53:31 2016 kern.info kernel: [ 3400.271876] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:31 2016 kern.info kernel: [ 3400.277414] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:31 2016 daemon.notice netifd: wan (4534): mbim[4534] Stopping network
Wed Dec 21 21:53:31 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:31 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:31 2016 daemon.notice netifd: wan (4538): mbim[4538] Reading capabilities
Wed Dec 21 21:53:31 2016 daemon.notice netifd: radio0 (4399): wlan0: interface state HT_SCAN->ENABLED
Wed Dec 21 21:53:31 2016 daemon.notice netifd: radio0 (4399): wlan0: AP-ENABLED
Wed Dec 21 21:53:31 2016 kern.debug kernel: [ 3400.332898] ieee80211 phy0: change: 0x20
Wed Dec 21 21:53:31 2016 daemon.notice netifd: Network device 'wlan0' link is up
Wed Dec 21 21:53:31 2016 kern.info kernel: [ 3400.350267] device wlan0 entered promiscuous mode
Wed Dec 21 21:53:31 2016 kern.info kernel: [ 3400.355065] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:31 2016 kern.info kernel: [ 3400.360604] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:33 2016 kern.info kernel: [ 3402.278881] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:33 2016 kern.info kernel: [ 3402.362872] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:34 2016 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Wed Dec 21 21:53:34 2016 daemon.notice netifd: wan (4568): mbim[4568] Stopping network
Wed Dec 21 21:53:34 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:34 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:34 2016 daemon.notice netifd: wan (4579): mbim[4579] Reading capabilities
Wed Dec 21 21:53:34 2016 user.notice root: Interface wan successful restarted
Wed Dec 21 21:53:34 2016 user.notice root: LTE-Watchdog ended
Wed Dec 21 21:53:34 2016 kern.debug kernel: [ 3403.598879] ieee80211 phy0: change: 0x60
Wed Dec 21 21:53:34 2016 kern.debug kernel: [ 3403.705850] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:34 2016 daemon.notice netifd: Network device 'wlan0' link is down
Wed Dec 21 21:53:34 2016 kern.info kernel: [ 3403.719073] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:34 2016 kern.info kernel: [ 3403.815000] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:34 2016 kern.info kernel: [ 3403.839144] device wlan0 left promiscuous mode
Wed Dec 21 21:53:34 2016 kern.info kernel: [ 3403.843630] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:34 2016 kern.debug kernel: [ 3403.910879] ieee80211 phy1: change: 0x40
Wed Dec 21 21:53:34 2016 kern.debug kernel: [ 3404.002826] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:34 2016 daemon.notice netifd: radio0 (4635): command failed: Not supported (-95)
Wed Dec 21 21:53:34 2016 daemon.notice netifd: Network device 'wlan1' link is down
Wed Dec 21 21:53:34 2016 kern.info kernel: [ 3404.050996] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:34 2016 daemon.notice netifd: radio0 (4635): Configuration file: /var/run/hostapd-phy0.conf
Wed Dec 21 21:53:34 2016 kern.info kernel: [ 3404.079166] device wlan1 left promiscuous mode
Wed Dec 21 21:53:34 2016 kern.info kernel: [ 3404.083656] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.218822] ieee80211 phy0: change: 0xffffffff
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio0 (4635): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio0 (4635): wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Dec 21 21:53:35 2016 kern.info kernel: [ 3404.334038] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.342626] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.354856] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio1 (4701): command failed: Not supported (-95)
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio1 (4701): Configuration file: /var/run/hostapd-phy1.conf
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.502818] ieee80211 phy1: change: 0xffffffff
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.566809] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio1 (4701): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio1 (4701): Using interface wlan1 with hwaddr 16:91:82:b8:24:d8 and ssid "LINKSYS2.4"
Wed Dec 21 21:53:35 2016 kern.info kernel: [ 3404.602042] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.663772] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.676838] ieee80211 phy1: change: 0x42
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.782804] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:35 2016 kern.info kernel: [ 3404.835863] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3404.890806] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio1 (4701): wlan1: interface state COUNTRY_UPDATE->ENABLED
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio1 (4701): wlan1: AP-ENABLED
Wed Dec 21 21:53:35 2016 daemon.notice netifd: radio0 (4635): Using interface wlan0 with hwaddr 16:91:82:b8:24:d9 and ssid "LINKSYS5N"
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3405.015241] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:35 2016 kern.debug kernel: [ 3405.026804] ieee80211 phy0: change: 0x42
Wed Dec 21 21:53:36 2016 kern.info kernel: [ 3405.198809] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Dec 21 21:53:36 2016 daemon.notice netifd: Network device 'wlan1' link is up
Wed Dec 21 21:53:36 2016 kern.info kernel: [ 3405.397282] device wlan1 entered promiscuous mode
Wed Dec 21 21:53:36 2016 kern.info kernel: [ 3405.402139] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:36 2016 kern.info kernel: [ 3405.407709] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:36 2016 daemon.notice netifd: radio0 (4635): wlan0: interface state HT_SCAN->ENABLED
Wed Dec 21 21:53:36 2016 daemon.notice netifd: radio0 (4635): wlan0: AP-ENABLED
Wed Dec 21 21:53:36 2016 daemon.notice netifd: wan (4777): mbim[4777] Stopping network
Wed Dec 21 21:53:36 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:36 2016 kern.debug kernel: [ 3405.420397] ieee80211 phy0: change: 0x20
Wed Dec 21 21:53:36 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:36 2016 daemon.notice netifd: Network device 'wlan0' link is up
Wed Dec 21 21:53:36 2016 kern.info kernel: [ 3405.440052] device wlan0 entered promiscuous mode
Wed Dec 21 21:53:36 2016 kern.info kernel: [ 3405.444852] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:36 2016 kern.info kernel: [ 3405.450386] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:36 2016 daemon.notice netifd: wan (4785): mbim[4785] Reading capabilities
Wed Dec 21 21:53:38 2016 kern.info kernel: [ 3407.410714] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:38 2016 kern.info kernel: [ 3407.450709] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:39 2016 user.notice root: LTE-Watchdog said: LTE down!! Action: Restarting interface wan
Wed Dec 21 21:53:39 2016 daemon.notice netifd: wan (4804): mbim[4804] Stopping network
Wed Dec 21 21:53:39 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:39 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:39 2016 daemon.notice netifd: wan (4817): mbim[4817] Reading capabilities
Wed Dec 21 21:53:39 2016 kern.debug kernel: [ 3408.698720] ieee80211 phy0: change: 0x60
Wed Dec 21 21:53:39 2016 user.notice root: Interface wan successful restarted
Wed Dec 21 21:53:39 2016 user.notice root: LTE-Watchdog ended
Wed Dec 21 21:53:39 2016 daemon.info procd: Instance sessionhold.sh::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Wed Dec 21 21:53:39 2016 kern.debug kernel: [ 3408.805691] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:39 2016 daemon.notice netifd: Network device 'wlan0' link is down
Wed Dec 21 21:53:39 2016 kern.info kernel: [ 3408.818878] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:39 2016 kern.info kernel: [ 3408.914811] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:39 2016 kern.debug kernel: [ 3408.962678] ieee80211 phy1: change: 0x40
Wed Dec 21 21:53:39 2016 kern.debug kernel: [ 3409.054665] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:39 2016 kern.info kernel: [ 3409.078976] device wlan0 left promiscuous mode
Wed Dec 21 21:53:39 2016 kern.info kernel: [ 3409.083464] br-lan: port 3(wlan0) entered disabled state
Wed Dec 21 21:53:39 2016 daemon.notice netifd: Network device 'wlan1' link is down
Wed Dec 21 21:53:39 2016 kern.info kernel: [ 3409.126866] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:40 2016 kern.info kernel: [ 3409.154995] device wlan1 left promiscuous mode
Wed Dec 21 21:53:40 2016 kern.info kernel: [ 3409.159507] br-lan: port 2(wlan1) entered disabled state
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio0 (4871): command failed: Not supported (-95)
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio0 (4871): Configuration file: /var/run/hostapd-phy0.conf
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.354659] ieee80211 phy0: change: 0xffffffff
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio0 (4871): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio0 (4871): wlan0: interface state COUNTRY_UPDATE->HT_SCAN
Wed Dec 21 21:53:40 2016 kern.info kernel: [ 3409.469874] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.477568] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.490685] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio1 (4901): command failed: Not supported (-95)
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio1 (4901): Configuration file: /var/run/hostapd-phy1.conf
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.630650] ieee80211 phy1: change: 0xffffffff
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.702646] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio1 (4901): wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio1 (4901): Using interface wlan1 with hwaddr 16:91:82:b8:24:d8 and ssid "LINKSYS2.4"
Wed Dec 21 21:53:40 2016 kern.info kernel: [ 3409.730863] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.792788] ieee80211 phy1: change: 0x100
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.805657] ieee80211 phy1: change: 0x42
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3409.914643] ieee80211 phy0: change: 0x40
Wed Dec 21 21:53:40 2016 kern.info kernel: [ 3409.962700] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3410.025648] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio0 (4871): Using interface wlan0 with hwaddr 16:91:82:b8:24:d9 and ssid "LINKSYS5N"
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio1 (4901): wlan1: interface state COUNTRY_UPDATE->ENABLED
Wed Dec 21 21:53:40 2016 daemon.notice netifd: radio1 (4901): wlan1: AP-ENABLED
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3410.094804] ieee80211 phy0: change: 0x100
Wed Dec 21 21:53:40 2016 kern.debug kernel: [ 3410.106662] ieee80211 phy0: change: 0x42
Wed Dec 21 21:53:41 2016 daemon.notice netifd: radio0 (4871): wlan0: interface state HT_SCAN->ENABLED
Wed Dec 21 21:53:41 2016 daemon.notice netifd: radio0 (4871): wlan0: AP-ENABLED
Wed Dec 21 21:53:41 2016 kern.info kernel: [ 3410.523085] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Wed Dec 21 21:53:41 2016 kern.debug kernel: [ 3410.531553] ieee80211 phy0: change: 0x20
Wed Dec 21 21:53:41 2016 daemon.notice netifd: Network device 'wlan1' link is up
Wed Dec 21 21:53:41 2016 kern.info kernel: [ 3410.556360] device wlan1 entered promiscuous mode
Wed Dec 21 21:53:41 2016 kern.info kernel: [ 3410.561155] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:41 2016 kern.info kernel: [ 3410.566687] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:41 2016 daemon.notice netifd: Network device 'wlan0' link is up
Wed Dec 21 21:53:41 2016 kern.info kernel: [ 3410.574719] device wlan0 entered promiscuous mode
Wed Dec 21 21:53:41 2016 kern.info kernel: [ 3410.579492] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:41 2016 kern.info kernel: [ 3410.585020] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:41 2016 daemon.notice netifd: wan (5022): mbim[5022] Stopping network
Wed Dec 21 21:53:41 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:53:41 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:53:41 2016 daemon.notice netifd: wan (5026): mbim[5026] Reading capabilities
Wed Dec 21 21:53:43 2016 kern.info kernel: [ 3412.570551] br-lan: port 2(wlan1) entered forwarding state
Wed Dec 21 21:53:43 2016 kern.info kernel: [ 3412.586548] br-lan: port 3(wlan0) entered forwarding state
Wed Dec 21 21:53:56 2016 daemon.notice netifd: wan (5026): ERROR: mbim message timeout
Wed Dec 21 21:53:56 2016 daemon.notice netifd: wan (5026): mbim[5026] Failed to read modem caps
Wed Dec 21 21:53:56 2016 user.notice root: mbim bringup failed, retry in 5s
Wed Dec 21 21:54:01 2016 daemon.notice netifd: wan (5037): mbim[5037] Stopping network
Wed Dec 21 21:54:01 2016 daemon.notice netifd: Interface 'wan' is now down
Wed Dec 21 21:54:01 2016 daemon.notice netifd: Interface 'wan' is setting up now
Wed Dec 21 21:54:01 2016 daemon.notice netifd: wan (5041): mbim[5041] Reading capabilities
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   devicetype: 0003 - remote
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   cellularclass: 0001
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   voiceclass: 0001 - no-voice
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   simclass: 0002
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   dataclass: 003C
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   smscaps: 0003
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   controlcaps: 0001
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   maxsessions: 0008
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   deviceid: 359072060388721
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   firmwareinfo: SWI9X30C_02.08.02.00
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   hardwareinfo: MC7455
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): mbim[5041] Checking subscriber
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   readystate: 0001 - initialized
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   simiccid: 89011200000424438348
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   subscriberid: 310120042443834
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   number: 2087241580
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): mbim[5041] Register with network
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   nwerror: 0000 - unknown
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   registerstate: 0003 - home
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   registermode: 0001 - automatic
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   availabledataclasses: 0020 - lte
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   currentcellularclass: 0001 - gsm
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   provider_id: 310120
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   provider_name: Sprint
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   roamingtext: (null)
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): mbim[5041] Attach to network
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   packetservicestate: 0002 - attached
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   uplinkspeed: 50000000
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   downlinkspeed: 300000000
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): mbim[5041] Connect to network
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   sessionid: 0
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   activationstate: 0001 - activated
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   voicecallstate: 0000 - none
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041):   iptype: 0001 - ipv4
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): mbim[5041] Get IP config
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): IP: 184.223.217.137
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): MASK: 255.255.255.252
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): GW: 184.223.217.138
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): DNS: 66.1.20.132
Wed Dec 21 21:54:04 2016 daemon.notice netifd: wan (5041): mbim[5041] Connected, setting IP
Wed Dec 21 21:54:05 2016 kern.info kernel: [ 3434.151947] 8021q: adding VLAN 0 to HW filter on device wwan0
Wed Dec 21 21:54:05 2016 daemon.notice netifd: Interface 'wan' is now up
Wed Dec 21 21:54:05 2016 daemon.notice netifd: Network device 'wwan0' link is up
Wed Dec 21 21:54:05 2016 daemon.info dnsmasq[2348]: reading /tmp/resolv.conf.auto
Wed Dec 21 21:54:05 2016 daemon.info dnsmasq[2348]: using local addresses only for domain lan
Wed Dec 21 21:54:05 2016 daemon.info dnsmasq[2348]: using nameserver 66.1.20.132#53
Wed Dec 21 21:54:05 2016 daemon.notice netifd: wan (5041): Loopback created for IP: 184.223.217.137
Wed Dec 21 21:54:05 2016 daemon.notice netifd: wan (5041): LTE-Watchdog started
Wed Dec 21 21:54:05 2016 user.notice firewall: Reloading firewall due to ifup of wan (wwan0)
Wed Dec 21 22:25:36 2016 authpriv.info dropbear[2811]: Exit (root): Exited normally
Don’t use a powered USB connector. There might be a possibility that the device stays connected even if you reboot.
Alternatively use at!reset to force a “reconnect” via USB.
Before I got the powered hub, I would see the following in my log…so I was advised to get the hub.
Thu Dec 15 11:59:54 2016 kern.info kernel: [167756.206993] usb 1-1: USB disconnect, device number 2
I believe Westrem said he connected some wires from the USB adapter to the USB 3.0 port for additional power. Doing it that way would cause the power to cut out on the modem and force it to reboot whereas my way has constant external power. But yesterday I did have the adapter unplugged because I removed and reinserted the sim card. Maybe I didn’t unplug/reboot/reset in the correct order.
I will definitely try the at!reset though. Can that be added to a script that runs on reboot? Thanks.
Probably, although you need some time after the at!reset for it to happen.
check the comgt scripts at /etc/gcom. You can modify them to do the at!reset.
You can then run it this way:
comgt -d /dev/ttyUSB2 -s /etc/gcom/example.gcom
Make sure you are using a good usb y cable and use both usb ports. Look at your kernel logs, do you see the usb device connecting and disconecting?
hey,
i am looking for a way to know if the mbim link is down without actually using the link. (so pinging a host in the internet is not available)
is there no mbim event for that, so that the link will be set down? like when i pull the ethernet-cable?
thanks
How do I find out for sure if the MC7455 is in MBIM or QMI mode? I am asking because other sources on the net (SIGQUIT blog) indicated this modem only supports QMI, and I also see ModemManager exchanging QMI messages. Here I read though this device has an MBIM-mode, and there are other signs that MBIM-mode might be active for me, such as non-functional location support in MM.
And a second question, I saw in an earlier post in this thread how to switch to QMI mode. How do I switch to MBIM mode?
Thank you,
Karoly
