Help with MC7455 in OpenWRT router
Ah, right. That makes sense. And should be the default for MBIM, IMHO. DHCP support is not mandatory, and there are many MBIM devices without.
There is no luci protocol for MBIM (yet?) so you won’t see anything in the web interface. But that won’t matter, it can connect just as fine.
Best way to check what ports are available is to boot your router, then connect your modem. Then use dmesg to check what new device has been found. There should be something like “… ttyUSBx” 2 or 3 times. 3 times if GPS is enabled, 2 otherwise.
So if I boot with the modem connected, I will never get any ttyUSBx at all? …cause I have yet to see it. I’m thinking I should see a ttyUSBx in /dev if I’ve done everything as instructed.
One more thing…and maybe this is my problem…maybe not . I haven’t put my sim card in yet. I wanted to make sure I had everything else working before I removed it from my other router and swapped devices on my account. The kids can’t live without their Internet for very long! :unamused: But I would think there should still be a ttyUSBx even without a sim card.
I’m super appreciative for all the help. I never would have been able to get this far on my own!
Of course you will get ttyUSB also with attached device on boot. It is just for debugging now.
But I have yet to get that so I wonder if I’m doing something wrong. I haven’t gotten “attached device” yet in dmesg. Maybe there are USB packages I didn’t get installed?
Post your output, nobody can help you otherwise.
Boot your device.
Attach the modem
Post dmesg output.
I was going to do that yesterday but ran out of time. I’m out of town today but I will post my output tomorrow when I get home. Thanks for your help! Happy Thanksgiving.
You have the exact same thing as me. Put the mc7455 into mbim mode and just flash the v9 firmware in the link I provided for the linksys and do the uci commands and your done. You probably won’t even need to swap the mbim. I didn’t and the one in the firmware worked just fine. Those firmwares have it already in it. It took me literally 4 min to do it. After that you have internet conection. Then you will be able to ssh into the router and you can use screen to get to your mc7455 and add bands and switch bands and everything else.
I was initially trying to use the latest stable release of Chaos Calmer. Maybe I didn’t have all the packages loaded or something. When I loaded the v9 software as instructed above, I immediately got a ttyUSB0 and ttyUSB1. However, I am at a standstill now because I just learned the sim card in my Netgear 6100D is not compatible with the Sierra Wireless AirPrime. None of my local Sprint stores carries one so I had to order from customer support. Now I wait… :frowning:
Why should they be incompatible? Have you tried it?
I can’t try it until Sprint swaps my devices. They will need to associate my sim card with the IMEI of the Airprime before I can access internet, right? I don’t believe you can just swap the sim and have it work. Maybe I’m wrong, but before when I had a second Netgear 6100D I was testing, I had to call customer service and swap devices each time I wanted to test one.
Youre making this much more complicated than it needs to be. Just use the generic firmware on the mc7455. Do not use the sprint firmware. It should be on generic if you didn’t switch to sprint. And you can swap the sprint sim into the airprime with no problem. If it’s a different size sim just get the sim adapters. I guess if you want you can go through the hassle of swapping devices with sprint. If you go that route you will probably need to use the sprint firmware instead. That is if sprint will provision the mc7455. They wouldn’t for me as I have an unlimited plan so I hide it and use generic firmware.
I have not changed the firmware on the MC7455…it is still the generic. If it will still work without swapping devices that would be great. How does Sprint associate my sim with the new IMEI on the AirPrime? I have the unlimited plan also. I did put my sim into the AirPrime and it didn’t work. I followed every step of your directions and everything seemed to work up until actually getting connected to the internet. That’s why I thought I needed to swap devices. When I put my sim into the wwan to usb adapter and power on the router, nothing happens. It never gives me an internet connection. Is there a step in the gui that I’m missing to connect to the internet? That would be awesome if I could get this connected today.
Thanks for all your help!
They don’t do it on your device but on their network.
Without seeing a log I would just be guessing. But did you add the apn to the mc7455? Did you hit reboot from within luci after you plugged everything in? Have you ran at!gstatus? To see if you have a signal? Are you locked into a band that you know you can get? There are so many variables. I need to see a log and what your at!gstatus? is.
Plug it into your computer and use the skylight drivers and see if it works there. That would eliminate some stuff.
It looks like it connected, but I never get an internet connection on my pc. How do I know if Sprint is issuing me an IP?
https://1drv.ms/i/s!ApbV613MLH_k1SLjcEcIV3JBDJ45
https://1drv.ms/i/s!ApbV613MLH_k1SFTDo6MVDBJXpiu
https://1drv.ms/i/s!ApbV613MLH_k1SB4KYDpFn2t8gZP
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Booting Linux on physical CPU 0x0
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000] Linux version 4.4.15 (fs@ubuntu-freenas) (gcc version 5.4.0 (LEDE GCC 5.4.0 r1114) ) #4 SMP Mon Jul 25 16:37:53 UTC 2016
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Machine model: Linksys WRT1900ACS
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Memory policy: Data cache writealloc
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.000000] On node 0 totalpages: 131072
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.000000] free_area_init_node: node 0, pgdat c05c9ec0, node_mem_map dfbf9000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.000000]   Normal zone: 1024 pages used for memmap
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.000000]   Normal zone: 0 pages reserved
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] PERCPU: Embedded 12 pages/cpu @dfbcf000 s17984 r8192 d22976 u49152
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.000000] pcpu-alloc: s17984 r8192 d22976 u49152 alloc=12*4096
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0 [0] 1
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock5 ro rootdelay=1 rootfstype=jffs2 earlyprintk mtdparts=armada-nand:2048K(uboot)ro,256K(u_env),256K(s_env),1m@9m(devinfo),40m@10m(kernel),34m@16m(rootfs),40m@50m(alt_kernel),34m@56m(alt_rootfs),80m@10m(ubifs),-@90m(syscfg)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Memory: 513224K/524288K available (4083K kernel code, 171K rwdata, 1528K rodata, 256K init, 295K bss, 11064K reserved, 0K cma-reserved, 0K highmem)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000] Virtual kernel memory layout:
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]       .text : 0xc0008000 - 0xc05831e8   (5613 kB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]       .init : 0xc0584000 - 0xc05c4000   ( 256 kB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]       .data : 0xc05c4000 - 0xc05eee34   ( 172 kB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.000000]        .bss : 0xc05eee34 - 0xc0638a6c   ( 296 kB)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Hierarchical RCU implementation.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    0.000000] mvebu_mbus: [Firmware Warn]: deprecated mbus-mvebu Device Tree, suspend/resume will not work
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] L2C-310 enabling early BRESP for Cortex-A9
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] L2C-310 D prefetch enabled, offset 1 lines
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000000] Switching to timer-based delay loop, resolution 40ns
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000003] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000009] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000114] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000120] pid_max: default: 32768 minimum: 301
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000155] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000160] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000355] CPU: Testing write buffer coherency: ok
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000452] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000476] Setting up static identity map for 0x8280 - 0x82d8
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000554] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.000631] mvebu-pmsu: Initializing Power Management Service Unit
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.001021] Booting CPU 1
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.001180] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.001206] Brought up 2 CPUs
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.001212] SMP: Total of 2 processors activated (100.00 BogoMIPS).
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.001215] CPU: All CPU(s) started in SVC mode.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.002884] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.002958] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.002997] pinctrl core: initialized pinctrl subsystem
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.003304] NET: Registered protocol family 16
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.003795] DMA: preallocated 256 KiB pool for atomic coherent allocations
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.015938] cpuidle: using governor ladder
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    0.018360] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    0.018368] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.028347] reg-fixed-voltage xhci0-vbus: could not find pctldev for node /soc/internal-regs/pinctrl@18000/xhci0-vbus-pins, deferring probe
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.028494] SCSI subsystem initialized
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.028640] libata version 3.00 loaded.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.028757] usbcore: registered new interface driver usbfs
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.028781] usbcore: registered new interface driver hub
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.028803] usbcore: registered new device driver usb
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.029318] clocksource: Switched to clocksource armada_370_xp_clocksource
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.029728] NET: Registered protocol family 2
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.029945] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.029969] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.030003] TCP: Hash tables configured (established 4096 bind 4096)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.030025] UDP hash table entries: 256 (order: 1, 8192 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.030037] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.030102] NET: Registered protocol family 1
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.030124] PCI: CLS 0 bytes, default 64
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.030490] futex hash table entries: 512 (order: 3, 32768 bytes)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.033888] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.033898] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.034539] io scheduler noop registered
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.034545] io scheduler deadline registered (default)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.034928] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035227] irq: Cannot allocate irq_descs @ IRQ44, assuming pre-allocated
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035361] irq: Cannot allocate irq_descs @ IRQ76, assuming pre-allocated
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035647] mvebu-pcie soc:pcie-controller: PCI host bridge to bus 0000:00
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035654] pci_bus 0000:00: root bus resource [io  0x1000-0xfffff]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035659] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035663] pci_bus 0000:00: root bus resource [bus 00-ff]
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.035677] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.035766] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035844] PCI: bus0: Fast back to back transfers disabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035849] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.035855] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.035914] pci 0000:01:00.0: [11ab:2a55] type 00 class 0x020000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.035941] pci 0000:01:00.0: reg 0x10: [mem 0x40000000-0x400fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.035952] pci 0000:01:00.0: reg 0x18: [mem 0x40100000-0x401fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036002] pci 0000:01:00.0: supports D1 D2
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036007] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036067] PCI: bus1: Fast back to back transfers disabled
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036073] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036131] pci 0000:02:00.0: [11ab:2a55] type 00 class 0x020000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036165] pci 0000:02:00.0: reg 0x10: [mem 0x42000000-0x420fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036178] pci 0000:02:00.0: reg 0x18: [mem 0x42100000-0x421fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036244] pci 0000:02:00.0: supports D1 D2
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036248] pci 0000:02:00.0: PME# supported from D0 D1 D3hot D3cold
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036314] PCI: bus2: Fast back to back transfers disabled
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    0.036319] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036366] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe01fffff]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036371] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe03fffff]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036378] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe00fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036388] pci 0000:01:00.0: BAR 2: assigned [mem 0xe0100000-0xe01fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036397] pci 0000:00:01.0: PCI bridge to [bus 01]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036402] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xe01fffff]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036409] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe02fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036420] pci 0000:02:00.0: BAR 2: assigned [mem 0xe0300000-0xe03fffff 64bit pref]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036429] pci 0000:00:02.0: PCI bridge to [bus 02]
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.036434] pci 0000:00:02.0:   bridge window [mem 0xe0200000-0xe03fffff]
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.036525] mv_xor f1060800.xor: Marvell shared XOR driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.057760] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.057841] mv_xor f1060900.xor: Marvell shared XOR driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.077739] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.077874] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.078132] console [ttyS0] disabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.098197] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 21, base_baud = 12500000) is a 16550A
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.808237] console [ttyS0] enabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.812074] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.821174] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.830576] scsi host0: ahci-mvebu
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.834148] scsi host1: ahci-mvebu
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.837662] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 41
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.845619] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 41
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    0.853959] pxa3xx-nand f10d0000.flash: This platform can't do DMA on this device
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.861773] nand: device found, Manufacturer ID: 0x01, Chip ID: 0xf1
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.868161] nand: AMD/Spansion S34ML01G2
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.872103] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.879709] pxa3xx-nand f10d0000.flash: ECC strength 16, ECC step size 2048
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.886891] Bad block table found at page 65472, version 0x01
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.893003] Bad block table found at page 65408, version 0x01
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.899039] 10 ofpart partitions found on MTD device pxa3xx_nand-0
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.905251] Creating 10 MTD partitions on "pxa3xx_nand-0":
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.910765] 0x000000000000-0x000000200000 : "u-boot"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.916049] 0x000000200000-0x000000240000 : "u_env"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.921231] 0x000000240000-0x000000280000 : "s_env"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.926393] 0x000000900000-0x000000a00000 : "devinfo"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.931756] 0x000000a00000-0x000003200000 : "kernel1"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.937138] 0x000001000000-0x000003200000 : "ubi"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.942149] 0x000003200000-0x000005a00000 : "kernel2"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.947500] 0x000003800000-0x000005a00000 : "rootfs2"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.952855] 0x000005a00000-0x000008000000 : "syscfg"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    0.958141] 0x000000280000-0x000000900000 : "unused_area"
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.964265] libphy: Fixed MDIO Bus: probed
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.968484] libphy: orion_mdio_bus: probed
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.972751] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.981662] mvneta f1034000.ethernet eth0: Using random mac address 26:0e:35:6f:b1:ae
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.990684] mvneta f1070000.ethernet eth1: Using hardware mac address 14:91:82:b8:24:d7
Sun Nov 27 18:48:11 2016 kern.info kernel: [    0.998789] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.005359] ehci-pci: EHCI PCI platform driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.009856] ehci-platform: EHCI generic platform driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.015193] ehci-orion: EHCI orion driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.019291] orion-ehci f1058000.usb: EHCI Host Controller
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.024730] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.032391] orion-ehci f1058000.usb: irq 36, io mem 0xf1058000
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.049319] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.055503] hub 1-0:1.0: USB hub found
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.059287] hub 1-0:1.0: 1 port detected
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.063595] usbcore: registered new interface driver usb-storage
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.069775] armada38x-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.077434] i2c /dev entries driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.092428] orion_wdt: Initial timeout 171 sec
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.100272] marvell-cesa f1090000.crypto: CESA device successfully registered
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.107945] NET: Registered protocol family 10
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.112855] NET: Registered protocol family 17
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.117346] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.130016] 8021q: 802.1Q VLAN Support v1.8
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.134285] Registering SWP/SWPB emulation handler
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.139848] xhci-hcd f10f8000.usb3: xHCI Host Controller
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.145210] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 2
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.152835] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.161425] xhci-hcd f10f8000.usb3: irq 43, io mem 0xf10f8000
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.167476] hub 2-0:1.0: USB hub found
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.171290] hub 2-0:1.0: 1 port detected
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.175332] xhci-hcd f10f8000.usb3: xHCI Host Controller
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.180680] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 3
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.188219] ata1: SATA link down (SStatus 0 SControl 300)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.193668] ata2: SATA link down (SStatus 0 SControl 300)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.199124] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.207447] hub 3-0:1.0: USB hub found
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.211228] hub 3-0:1.0: 1 port detected
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.215503] UBI: auto-attach mtd5
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.218665] ubi0: attaching mtd5
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.314224] ubi0: scanning is finished
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.322397] ubi0: attached mtd5 (name "ubi", size 34 MiB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.327828] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.334736] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.341555] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.348547] ubi0: good PEBs: 272, bad PEBs: 0, corrupted PEBs: 0
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.354579] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.361833] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1165497949
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.371006] ubi0: available PEBs: 0, total reserved PEBs: 272, PEBs reserved for bad PEB handling: 20
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.380286] usb 1-1: new full-speed USB device number 2 using orion-ehci
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.381315] ubi0: background thread "ubi_bgt0d" started, PID 553
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.393446] block ubiblock0_0: created from ubi0:0(rootfs)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    1.398975] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.406169] mvsw61xx 10.mvsw61xx: Found MV88E6176 at f1072004.mdio-mi:10
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.412907] mvsw61xx 10.mvsw61xx: Using direct addressing
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.418381] armada38x-rtc f10a3800.rtc: setting system clock to 2106-02-07 04:10:35 UTC (4294959035)
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.428322] Waiting 1 sec before mounting root device...
Sun Nov 27 18:48:11 2016 kern.info kernel: [    1.629316] usb 1-1: new high-speed USB device number 3 using orion-ehci
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    1.772879] usb 1-1: config 1 has an invalid interface number: 12 but max is 3
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    1.780140] usb 1-1: config 1 has an invalid interface number: 13 but max is 3
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    1.787401] usb 1-1: config 1 has an invalid interface number: 13 but max is 3
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    1.794656] usb 1-1: config 1 has no interface number 1
Sun Nov 27 18:48:11 2016 kern.warn kernel: [    1.799907] usb 1-1: config 1 has no interface number 2
Sun Nov 27 18:48:11 2016 kern.info kernel: [    2.439064] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
Sun Nov 27 18:48:11 2016 kern.info kernel: [    2.446377] Freeing unused kernel memory: 256K (c0584000 - c05c4000)
Sun Nov 27 18:48:11 2016 user.info kernel: [    2.702982] init: Console is alive
Sun Nov 27 18:48:11 2016 user.info kernel: [    2.706486] init: - watchdog -
Sun Nov 27 18:48:11 2016 user.info kernel: [    3.011844] init: - preinit -
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    3.228845] random: procd urandom read with 119 bits of entropy available
Sun Nov 27 18:48:11 2016 user.info kernel: [    6.288213] mount_root: loading kmods from internal overlay
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.348217] random: nonblocking pool is initialized
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.384532] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 645
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.413006] UBIFS (ubi0:1): recovery needed
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.465613] UBIFS (ubi0:1): recovery completed
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.470113] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "rootfs_data"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.477982] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.487942] UBIFS (ubi0:1): FS size: 25649152 bytes (24 MiB, 202 LEBs), journal size 1269760 bytes (1 MiB, 10 LEBs)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.498423] UBIFS (ubi0:1): reserved for root: 1211472 bytes (1183 KiB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.505068] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 978BABC0-C675-4CA8-8FCC-DF24A3FC565B, small LPT model
Sun Nov 27 18:48:11 2016 user.info kernel: [    6.518697] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
Sun Nov 27 18:48:11 2016 user.info kernel: [    6.528405] block: extroot: not configured
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.541369] UBIFS (ubi0:1): un-mount UBI device 0
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.546109] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" stops
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.553991] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 648
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.611449] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "rootfs_data"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.619321] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.629281] UBIFS (ubi0:1): FS size: 25649152 bytes (24 MiB, 202 LEBs), journal size 1269760 bytes (1 MiB, 10 LEBs)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.639761] UBIFS (ubi0:1): reserved for root: 1211472 bytes (1183 KiB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.646405] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 978BABC0-C675-4CA8-8FCC-DF24A3FC565B, small LPT model
Sun Nov 27 18:48:11 2016 user.info kernel: [    6.717153] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
Sun Nov 27 18:48:11 2016 user.info kernel: [    6.726554] block: extroot: not configured
Sun Nov 27 18:48:11 2016 user.info kernel: [    6.742191] mount_root: switching to jffs2 overlay
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.780097] ubi1: attaching mtd8
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.884017] ubi1: scanning is finished
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.892107] ubi1: attached mtd8 (name "syscfg", size 38 MiB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.897803] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.904711] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.911531] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.918524] ubi1: good PEBs: 296, bad PEBs: 8, corrupted PEBs: 0
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.924557] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.931811] ubi1: max/mean erase counter: 5/2, WL threshold: 4096, image sequence number: 1384725880
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.940984] ubi1: available PEBs: 0, total reserved PEBs: 296, PEBs reserved for bad PEB handling: 12
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.950251] ubi1: background thread "ubi_bgt1d" started, PID 658
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    6.961194] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 662
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    7.015024] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "syscfg"
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    7.022462] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    7.032423] UBIFS (ubi1:0): FS size: 34283520 bytes (32 MiB, 270 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    7.042904] UBIFS (ubi1:0): reserved for root: 1619295 bytes (1581 KiB)
Sun Nov 27 18:48:11 2016 kern.notice kernel: [    7.049550] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID AF01C743-0B07-4F0E-880D-87E713FDC6C9, small LPT model
Sun Nov 27 18:48:11 2016 user.warn kernel: [    7.062400] urandom-seed: Seeding with /etc/urandom.seed
Sun Nov 27 18:48:11 2016 user.info kernel: [    7.094205] procd: - early -
Sun Nov 27 18:48:11 2016 user.info kernel: [    7.097121] procd: - watchdog -
Sun Nov 27 18:48:11 2016 user.info kernel: [    7.646454] procd: - ubus -
Sun Nov 27 18:48:11 2016 user.info kernel: [    7.718721] procd: - init -
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.797274] tun: Universal TUN/TAP device driver, 1.6
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.802367] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.809677] sit: IPv6 over IPv4 tunneling driver
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.816645] ip6_tables: (C) 2000-2006 Netfilter Core Team
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.824608] Loading modules backported from Linux version wt-2016-06-20-0-gbc17424
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.832244] Backport generated by backports.git backports-20160216-7-g5735958
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.848938] <<Marvell 802.11ac Wireless Network Driver version 10.3.0.17-20160617>>
Sun Nov 27 18:48:11 2016 kern.info kernel: [    7.856500] pci 0000:00:01.0: enabling device (0140 -> 0142)
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    7.862447] ieee80211 phy0: priv->iobase0 = e1080000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    7.862461] ieee80211 phy0: priv->iobase1 = e1200000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    7.862495] ieee80211 phy0: priv->pcmd_buf = dddfc000  priv->pphys_cmd_buf = 1ddfc000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    7.889324] ieee80211 phy0: fw download start
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.005615] ieee80211 phy0: FwSize = 117828 downloaded Size = 117828 curr_iteration 65496
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.877314] ieee80211 phy0: fw download complete
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.878369] ieee80211 phy0: pcmd = dddfc000
Sun Nov 27 18:48:11 2016 kern.info kernel: [    8.896324] ieee80211 phy0: firmware version: 0x7020902
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924417] ieee80211 phy0: regdomain: FCC
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924424] ieee80211 phy0: Channel: 36: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924431] ieee80211 phy0: 12 12 12 12 12 12 12 12 10 10 10 10 f f f f
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924435] ieee80211 phy0: Channel: 40: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924441] ieee80211 phy0: 16 16 16 16 16 16 16 16 16 16 16 16 f f f f
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924445] ieee80211 phy0: Channel: 44: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924451] ieee80211 phy0: 16 16 16 16 16 16 16 16 16 16 16 16 f f f f
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924455] ieee80211 phy0: Channel: 48: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924461] ieee80211 phy0: 16 16 16 16 16 16 16 16 16 16 16 16 f f f f
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924465] ieee80211 phy0: Channel: 52: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924471] ieee80211 phy0: 11 11 11 11 10 10 10 10 12 12 12 12 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924475] ieee80211 phy0: Channel: 56: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924481] ieee80211 phy0: 11 11 11 11 10 10 10 10 12 12 12 12 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924485] ieee80211 phy0: Channel: 60: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924491] ieee80211 phy0: 11 11 11 11 10 10 10 10 12 12 12 12 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924495] ieee80211 phy0: Channel: 64: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924501] ieee80211 phy0: 11 11 11 11 10 10 10 10 12 12 12 12 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924505] ieee80211 phy0: Channel: 100: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924511] ieee80211 phy0: 10 10 10 10 11 11 11 11 12 12 12 12 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924515] ieee80211 phy0: Channel: 104: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924521] ieee80211 phy0: 11 11 11 11 10 10 10 10 12 12 12 12 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924525] ieee80211 phy0: Channel: 108: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924531] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924535] ieee80211 phy0: Channel: 112: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924541] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924545] ieee80211 phy0: Channel: 116: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924551] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924555] ieee80211 phy0: Channel: 120: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924561] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924565] ieee80211 phy0: Channel: 124: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924571] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924574] ieee80211 phy0: Channel: 128: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924581] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924584] ieee80211 phy0: Channel: 132: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924590] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924594] ieee80211 phy0: Channel: 136: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924600] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924604] ieee80211 phy0: Channel: 140: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924610] ieee80211 phy0: 11 11 11 11 10 10 10 10 11 11 11 11 10 10 10 10
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924614] ieee80211 phy0: Channel: 149: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924620] ieee80211 phy0: 16 16 16 16 16 16 16 16 15 15 15 15 15 15 15 15
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924624] ieee80211 phy0: Channel: 153: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924630] ieee80211 phy0: 16 16 16 16 15 15 15 15 15 15 15 15 15 15 15 15
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924634] ieee80211 phy0: Channel: 157: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924640] ieee80211 phy0: 16 16 16 16 15 15 15 15 15 15 15 15 15 15 15 15
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924644] ieee80211 phy0: Channel: 161: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924650] ieee80211 phy0: 16 16 16 16 15 15 15 15 15 15 15 15 15 15 15 15
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924653] ieee80211 phy0: Channel: 165: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.924659] ieee80211 phy0: 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15
Sun Nov 27 18:48:11 2016 kern.info kernel: [    8.925289] ieee80211 phy0: 2G disabled, 5G enabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    8.930213] ieee80211 phy0: 4 TX antennas, 4 RX antennas
Sun Nov 27 18:48:11 2016 kern.info kernel: [    8.935631] pci 0000:00:02.0: enabling device (0140 -> 0142)
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.941380] ieee80211 phy1: priv->iobase0 = e1380000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.941392] ieee80211 phy1: priv->iobase1 = e1500000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.941426] ieee80211 phy1: priv->pcmd_buf = ddb38000  priv->pphys_cmd_buf = 1db38000
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    8.945330] ieee80211 phy1: fw download start
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.062084] ieee80211 phy1: FwSize = 117828 downloaded Size = 117828 curr_iteration 65511
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.921314] ieee80211 phy1: fw download complete
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.922333] ieee80211 phy1: pcmd = ddb38000
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.940323] ieee80211 phy1: firmware version: 0x7020902
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965402] ieee80211 phy1: regdomain: FCC
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965408] ieee80211 phy1: Channel: 1: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965414] ieee80211 phy1: 17 10 10 10 f f f f e e e e 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965418] ieee80211 phy1: Channel: 2: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965425] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965429] ieee80211 phy1: Channel: 3: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965435] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965439] ieee80211 phy1: Channel: 4: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965445] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965449] ieee80211 phy1: Channel: 5: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965455] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965459] ieee80211 phy1: Channel: 6: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965465] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965469] ieee80211 phy1: Channel: 7: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965475] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965479] ieee80211 phy1: Channel: 8: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965485] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965489] ieee80211 phy1: Channel: 9: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965495] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965499] ieee80211 phy1: Channel: 10: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965505] ieee80211 phy1: 18 16 16 16 16 16 16 14 11 11 11 11 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965509] ieee80211 phy1: Channel: 11: 0x0 0x0 0xf
Sun Nov 27 18:48:11 2016 kern.debug kernel: [    9.965515] ieee80211 phy1: 17 12 12 12 13 13 13 13 f f f f 0 0 0 0
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.966130] ieee80211 phy1: 2G enabled, 5G disabled
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.971059] ieee80211 phy1: 4 TX antennas, 4 RX antennas
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.978732] u32 classifier
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.981467]     input device check on
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.985144]     Actions configured
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.989000] Mirror/redirect action on
Sun Nov 27 18:48:11 2016 kern.info kernel: [    9.994137] nf_conntrack version 0.5.0 (8023 buckets, 32092 max)
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.006522] usbcore: registered new interface driver cdc_wdm
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.013174] ip_tables: (C) 2000-2006 Netfilter Core Team
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.063950] usbcore: registered new interface driver usbserial
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.069856] usbcore: registered new interface driver usbserial_generic
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.076442] usbserial: USB Serial support registered for generic
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.089493] xt_time: kernel timezone is -0000
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.094208] usbcore: registered new interface driver cdc_eem
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.100374] usbcore: registered new interface driver cdc_ether
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.106912] usbcore: registered new interface driver cdc_ncm
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.112895] usbcore: registered new interface driver cdc_subset
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.119136] usbcore: registered new interface driver huawei_cdc_ncm
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.128149] PPP generic driver version 2.4.2
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.132841] NET: Registered protocol family 24
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.137770] usbcore: registered new interface driver qmi_wwan
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.144036] usbcore: registered new interface driver rndis_host
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.150326] usbcore: registered new interface driver sierra
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.155963] usbserial: USB Serial support registered for Sierra USB modem
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.163260] usbcore: registered new interface driver sierra_net
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.172098] cdc_mbim 1-1:1.12: cdc-wdm0: USB WDM device
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.177748] cdc_mbim 1-1:1.12 wwan0: register 'cdc_mbim' at usb-f1058000.usb-1, CDC MBIM, aa:3c:33:01:dd:48
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.187634] usbcore: registered new interface driver cdc_mbim
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.194532] usbcore: registered new interface driver option
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.200217] usbserial: USB Serial support registered for GSM modem (1-port)
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.208599] usbcore: registered new interface driver qcserial
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.214427] usbserial: USB Serial support registered for Qualcomm USB modem
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.221644] qcserial 1-1:1.0: Qualcomm USB modem converter detected
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.228053] usb 1-1: Qualcomm USB modem converter now attached to ttyUSB0
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.235146] qcserial 1-1:1.3: Qualcomm USB modem converter detected
Sun Nov 27 18:48:11 2016 kern.info kernel: [   10.241593] usb 1-1: Qualcomm USB modem converter now attached to ttyUSB1
Sun Nov 27 18:48:12 2016 user.notice : 'radio0' is disabled
Sun Nov 27 18:48:12 2016 user.notice : 'radio1' is disabled
Sun Nov 27 18:48:12 2016 daemon.err block: /dev/ubi0_1 is already mounted
Sun Nov 27 18:48:12 2016 cron.info crond[1320]: crond (busybox 1.24.2) started, log level 8
Sun Nov 27 18:48:12 2016 authpriv.info dropbear[1344]: Not backgrounding
Sun Nov 27 18:48:12 2016 daemon.err insmod: module is already loaded - xt_multiport
Sun Nov 27 18:48:12 2016 daemon.err insmod: module is already loaded - xt_comment
Sun Nov 27 18:48:12 2016 daemon.err insmod: module is already loaded - xt_length
Sun Nov 27 18:48:12 2016 kern.info kernel: [   12.517547] device eth1 entered promiscuous mode
Sun Nov 27 18:48:12 2016 kern.info kernel: [   12.527352] br-lan: port 1(eth1) entered forwarding state
Sun Nov 27 18:48:12 2016 kern.info kernel: [   12.532819] br-lan: port 1(eth1) entered forwarding state
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'lan' is enabled
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'lan' is setting up now
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'lan' is now up
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'loopback' is enabled
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'loopback' is setting up now
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'loopback' is now up
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'wan' is setting up now
Sun Nov 27 18:48:12 2016 kern.info kernel: [   12.548778] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'wan6' is enabled
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Bridge 'br-lan' link is up
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'lan' has link connectivity
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Network device 'lo' link is up
Sun Nov 27 18:48:12 2016 daemon.notice netifd: Interface 'loopback' has link connectivity
Sun Nov 27 18:48:12 2016 daemon.notice netifd: wan (1574): mbim[1574] Reading capabilities
Sun Nov 27 18:48:13 2016 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sun Nov 27 18:48:13 2016 user.notice : setting up led WAN
Sun Nov 27 18:48:13 2016 user.notice : setting up led USB2
Sun Nov 27 18:48:13 2016 user.notice : setting up led USB3
Sun Nov 27 18:48:13 2016 daemon.info procd: - init complete -
Sun Nov 27 18:48:13 2016 daemon.notice netifd: Bridge 'br-lan' link is down
Sun Nov 27 18:48:13 2016 daemon.notice netifd: Interface 'lan' has link connectivity loss
Sun Nov 27 18:48:13 2016 kern.info kernel: [   13.509340] br-lan: port 1(eth1) entered disabled state
Sun Nov 27 18:48:14 2016 kern.info kernel: [   14.513324] mvneta f1070000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
Sun Nov 27 18:48:14 2016 kern.info kernel: [   14.521204] br-lan: port 1(eth1) entered forwarding state
Sun Nov 27 18:48:14 2016 kern.info kernel: [   14.526641] br-lan: port 1(eth1) entered forwarding state
Sun Nov 27 18:48:14 2016 daemon.notice netifd: Network device 'eth1' link is up
Sun Nov 27 18:48:14 2016 daemon.notice netifd: Bridge 'br-lan' link is up
Sun Nov 27 18:48:14 2016 daemon.notice netifd: Interface 'lan' has link connectivity
Sun Nov 27 18:48:14 2016 kern.info kernel: [   14.545321] mvneta f1034000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Sun Nov 27 18:48:14 2016 kern.info kernel: [   14.553195] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sun Nov 27 18:48:14 2016 daemon.notice netifd: Network device 'eth0' link is up
Sun Nov 27 18:48:14 2016 daemon.notice netifd: Interface 'wan6' has link connectivity
Sun Nov 27 18:48:14 2016 daemon.notice netifd: Interface 'wan6' is setting up now
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   devicetype: 0003 - remote
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   cellularclass: 0001
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   voiceclass: 0001 - no-voice
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   simclass: 0002
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   dataclass: 003C
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   smscaps: 0003
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   controlcaps: 0001
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   maxsessions: 0008
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   deviceid: 359072060388721
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   firmwareinfo: SWI9X30C_02.08.02.00
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   hardwareinfo: MC7455
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): mbim[1574] Checking subscriber
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   readystate: 0001 - initialized
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   simiccid: 89011200000424438348
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   subscriberid: 310120042443834
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   number: 2087241580
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): mbim[1574] Register with network
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   nwerror: 0000 - unknown
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   registerstate: 0003 - home
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   registermode: 0001 - automatic
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   availabledataclasses: 0020 - lte
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   currentcellularclass: 0001 - gsm
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   provider_id: 310120
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   provider_name: Sprint
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   roamingtext: (null)
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): mbim[1574] Attach to network
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   packetservicestate: 0002 - attached
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   uplinkspeed: 50000000
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   downlinkspeed: 300000000
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): mbim[1574] Connect to network
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   sessionid: 0
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   activationstate: 0001 - activated
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   voicecallstate: 0000 - none
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574):   iptype: 0001 - ipv4
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): mbim[1574] Get IP config
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): 255.255.255.248
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): IP: 173.130.6.148 255.255.255.248
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): GW: 173.130.6.149
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): DNS: 66.1.28.132
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): mbim[1574] Connected, setting IP
Sun Nov 27 18:48:15 2016 daemon.notice netifd: Interface 'wan' is now up
Sun Nov 27 18:48:15 2016 daemon.notice netifd: Network device 'wwan0' link is up
Sun Nov 27 18:48:15 2016 kern.info kernel: [   15.435531] 8021q: adding VLAN 0 to HW filter on device wwan0
Sun Nov 27 18:48:15 2016 daemon.notice netifd: wan (1574): Interface wwan0 not found
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: started, version 2.76 cachesize 150
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: DNS service limited to local subnets
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq-dhcp[2173]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: using local addresses only for domain lan
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: reading /tmp/resolv.conf.auto
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: using nameserver 66.1.28.132#53
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: read /etc/hosts - 4 addresses
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq[2173]: read /tmp/hosts/dhcp - 2 addresses
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq-dhcp[2173]: read /etc/ethers - 0 addresses
Sun Nov 27 18:48:16 2016 user.notice upnp daemon: external interface not found, not starting
Sun Nov 27 18:48:16 2016 user.notice firewall: Reloading firewall due to ifup of wan (wwan0)
Sun Nov 27 18:48:16 2016 kern.info kernel: [   16.529325] br-lan: port 1(eth1) entered forwarding state
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq-dhcp[2173]: DHCPREQUEST(br-lan) 192.168.1.188 68:05:ca:2d:66:0a
Sun Nov 27 18:48:16 2016 daemon.info dnsmasq-dhcp[2173]: DHCPACK(br-lan) 192.168.1.188 68:05:ca:2d:66:0a Win10Office
Sun Nov 27 18:48:16 2016 user.notice ddns-scripts[2440]: myddns_ipv4: PID '2440' started at 2016-11-27 18:48
Sun Nov 27 18:48:16 2016 user.warn ddns-scripts[2440]: myddns_ipv4: Service section disabled! - TERMINATE
Sun Nov 27 18:48:16 2016 user.warn ddns-scripts[2440]: myddns_ipv4: PID '2440' exit WITH ERROR '1' at 2016-11-27 18:48
Sun Nov 27 18:50:00 2016 cron.info crond[1320]: USER root pid 3860 cmd /sbin/fan_ctrl.sh
It’s up and running fine. We need to see at!gstatus? Just ssh into your router then type “screen /dev/ttyUSBx” without quotes and x=1 or 2. Then “at!gstatus?” Without quotes.
I bet you dont have a signal. This may be a dumb question but you do have antennas on the mc7455 correct?
Show us your
At!band?
At!gstatus?
Please see the first link in my last post
Ok sorry. I overlooked the links. Your close. Try using the other mbim.sh. If that doesn’t work try v8 with the mbim.sh.
When connecting the USB adapter to my PC and using the Skylight drivers, it worked immediately. I was able to get on the internet through MC7455.
Not sure why I’m not quite getting there on the Linksys, though. I think I tried changing the mbim.sh but I’ll try again. It should work with the v9 software is that’s what you’re using and we have the exact same setup. Are there any versions of the Rooter software that work with the Linksys WRT1900ACS?
