Have you seen this error before?
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
Please contact your system administrator.
Hello!
Are you seeing this error when attempting to SSH into a device? If so, have you SSH’d into another device using the same IP address? (i.e. another mangoh/fx30 over USB?)
If so, look at your ~/.ssh/known_hosts file and remove the line for the old device at that IP address (the default is 192.168.2.2).
-Tom
Thanks Tom that did the trick.
