Q2406B connected to the appliance microprocessor, which transmits data from the ADC via the RS232
The issue of harmonization of data rates. The microprocessor transmits data at speeds of 9600
How to configure Q2406B at the same speed. Thanks/
Hiya,
Use the AT command AT+IPR to fix the DTE data rate. You may also need to issue an AT&W command to save the setting to EPROM.
Check out the AT commands guide for your modem - available on the Wavecom Developer site.
ciao, Dave
