GSM testing
I have a question regarding the AT!SARBACKOFF command. I intend to use this command for GSM transmission. I understand there is a test procedure involving the following commands to assess our GSM transmission. If I set an offset of 9 in the SARBACKOFF, meaning my SAR limit is 23 dB, and in the test I set a power of 32 dB, what would be the output result, 23 dB or 32 dB? I’m using a WP7702 with firmware R14.1. Test command sequence is as follows:
AT!ENTERCND=“A710”
AT!DAFTMACT
AT!DASBAND=10
AT!DASCHAN=62
AT!DAGSTXFRAME=1,1,3200,0
AT!DASTXON
Hi @bilal.kassem,
In this topic, are you asking about the AT!SARBACKOFF command similar to the topic ‘SARBACKOFF Probleme’? I’ve left a comment in that topic for your reference.
