We are using Sierra-based SL Series Modems (Open AT) for our energy meters to communicate data to a RabbitMQ Broker Queue. The data is received as RF Zigbee payload and then sent to RabbitMQ Queue . The modem performs several steps on power-up to establish a GPRS connection, including SIM registration and GPRS Barrier configuration. However, we are facing a recurring issue with the modems failing to obtain a SIM network IP, resulting in a GPRS Connection Failure with error number -36
Observations:
- Error Description:
- The modem is unable to get a SIM network IP.
- Error: GPRS Connection Failure, Error Code: -36.
- Field Deployment:
- 229 devices installed across various locations.
- Approximately 10-15 devices go out of network weekly.
- Devices often return to the network after a power reset or SIM replacement.
- Diagnostic Observations:
- Device A fails at location A but works when moved to location B.
- Device B consistently works at its location and does not face network issues.
- Issue persists despite multiple soft resets; sometimes resolves with a hard reset.
- Devices with new SIM cards reconnected successfully within 72 hours.
Request for Assistance:
- Potential Causes:
- What could be the underlying cause of the GPRS connection failure and the error code -36?
- Troubleshooting Steps:
- Are there any recommended steps for further diagnosing the issue?
- Would firmware or hardware modifications potentially resolve these intermittent connectivity issues?
Please do the needful.
Thanks in Advance!
