GL7500 with AT&T and Kore SIM: Only the first connection attempt succeeds
I’ve got the GT7500 modem work reliably with Verizon, Rogers and AT&T, except for the AT&T with a Kore SIM. In that case the first TCP session works, but the second one fails to open, and the only fix is to reset or power-cycle the modem. Am I doing something wrong? Below is the summary of the interaction between the modem and the host.
==== successful first attempt ====
AT+KCNXCFG=1,“GPRS”,“C1.KOREM2M.COM” => OK
AT+CGREG? => +CGREG: 0,1
at+KTCPCFG=1,0,"<IP address>",<port> => +KTCPCFG: 1
AT+KTCPSTART=1 => +KCNX_IND: 1,4,1 +KCNX_IND: 1,1,0 +KTCP_IND: 1,1 CONNECT
ATH => OK +KTCP_DATA: 1,
AT+KTCPCLOSE=1,1 => OK
AT+KTCPDEL=1 => OK
==== second attempt fails ====
AT+KTCPSTART=1 => +KCNX_IND: 1,4,1 +KCNX_IND: 1,1,0 +KTCP_NOTIF: 1,5
ATH => OK
AT+KTCPCLOSE=1,1 => ERROR
AT+KTCPDEL=1 => OK
It looks like, while the PDP context “connected”, the second TCP session opening fails with a generic “TCP Error”. To emphasize, this exact command sequence works fine in all other setups.
Hi sslobodov,
Which firmware version are you using? If you are not on the latest firmware, please download the latest one and retry.
You can get it here AirPrime HL7588 Firmware
Please provide the output of below commands:
==== first attempt ====
ATI3
AT+CGDCONT?
AT+CGREG?
AT+CEREG?
AT+CGACT?
AT+CGPADDR
AT+KTCPCFG=1,0,"", => +KTCPCFG: 1
ATH
AT+KTCPDEL=1 => OK
==== second attempt ====
AT+CGDCONT?
AT+CGREG?
AT+CEREG?
AT+CGACT?
AT+CGPADDR
AT+KTCPCFG?
AT+KTCPSTART=1
Hi Donald,
Thank you for your reply. Here is the output of the commands requested. Is this the latest firmware, or do we need to update it?
AT+CGDCONT?
+CGDCONT: 1,“IP”,“c1.korem2m.com”,“0.0.0.0”,0,0,0,0,0,0
ATI3
GL7500.A.2.15.151600.201809201422.x7160_3
AT+CGREG?
+CGREG: 0,1
AT+CEREG?
+CEREG: 0,0
AT+CGACT?
+CGACT: 1,0
AT+CGPADDR
ERROR
at+KTCPCFG=1,0,“ip-address”,port ← actual IP & port not pasted here.
+KTCPCFG: 1
AT+KTCPSTART=1
+KCNX_IND: 1,4,1
+KCNX_IND: 1,1,0
+KTCP_NOTIF: 1,5
ATH
AT+KTCPCLOSE=1,1
ERROR
AT+KTCPDEL=1
Hi sslobodov,
Your steps are OK. That may be the issue of AT&T and KORE SIM.
