I think you should first read some tutorial on building the android image.
Is there no way to build this driver separately?
I mean, I already have an android image, provided by the BSP seller.
I need to build a new one for integrating it? Do I need to build android from source?
Setup the build environment and go to the driver path and type mm.
Hum… I guess, after all this time, I got it!
I will try it!
Thanks!
Dear,
I finally created the sierra.ko and sierra_net.ko files.
However, when I try to install it on BSP (isnmod sierra_net.ko ) , it reports an error:
insmod: failed to load sierra_net.ko: Exec format error
The same happens for sierra.ko file.
I am trying to do it on at the BSP via ADB.
Any suggestion?
Probably build environment set wrongly…,
Topic unlisted per author request.
