FX30S User LED example
Is there an example on how to use the USER LED GPIO47,GPIO48 on FX30S ?
the gpioService.le_gpioPin47 don’t seem to work ?
Aug 5 19:40:51 fx30s user.info Legato: INFO | gpioService[1552]/sysfsGpio T=main | gpioSysfs.c _sysfsGpio_COMPONENT_INIT() 9696 | Skipping starting GPIO Service for Pin 47 - pin not available or disabled by config
Aug 5 19:40:51 fx30s user.info Legato: INFO | gpioService[1552]/sysfsGpio T=main | gpioSysfs.c _sysfsGpio_COMPONENT_INIT() 9713 | Skipping starting GPIO Service for Pin 48 - pin not available or disabled by config
root@fx30s:/sys/class/gpio# cm info
Device: FX30S(WP7702)
IMEI: 354723090332155
IMEISV: 6
FSN: VU145400171210
Firmware Version: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
Bootloader Version: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
MCU Version: 002.009
PRI Part Number (PN): 9907957
PRI Revision: 001.000
Carrier PRI Name: GENERIC
Carrier PRI Revision: 001.071_001
SKU: 1103882
Last Reset Cause: Power Down
Resets Count: Expected: 20 Unexpected: 1
root@fx30s:/sys/class/gpio# ls -l
–w------- 1 root root 4096 Aug 5 13:36 export
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio2 → …/…/devices/1000000.pinctrl/gpio/gpio2
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio21 → …/…/devices/1000000.pinctrl/gpio/gpio21
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio22 → …/…/devices/1000000.pinctrl/gpio/gpio22
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio24 → …/…/devices/1000000.pinctrl/gpio/gpio24
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio25 → …/…/devices/1000000.pinctrl/gpio/gpio25
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio29 → …/…/devices/1000000.pinctrl/gpio/gpio29
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio32 → …/…/devices/1000000.pinctrl/gpio/gpio32
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio36 → …/…/devices/78b8000.i2c/i2c-4/4-003a/swimcu-gpio/gpio/gpio36
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio38 → …/…/devices/78b8000.i2c/i2c-4/4-003a/swimcu-gpio/gpio/gpio38
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio43 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio43
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio44 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio44
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio45 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio45
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio46 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio46
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio47 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio47
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio48 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio48
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio49 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio49
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio50 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio50
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio51 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio51
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio52 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio52
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio53 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio53
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio54 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio54
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio56 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio56
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio57 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio57
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio58 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio58
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio60 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio60
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio61 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio61
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio62 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpio62
lrwxrwxrwx 1 root root 0 Aug 5 13:36 gpio7 → …/…/devices/1000000.pinctrl/gpio/gpio7
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip0 → …/…/devices/1000000.pinctrl/gpio/gpiochip0
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip1 → …/…/devices/virtual/gpio/gpiochip1
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip1012 → …/…/devices/qpnp-pin-7/gpio/gpiochip1012
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip1018 → …/…/devices/qpnp-pin-6/gpio/gpiochip1018
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip200 → …/…/devices/78b8000.i2c/i2c-4/4-003a/swimcu-gpio/gpio/gpiochip200
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip796 → …/…/devices/soc:qcom,smp2pgpio-ssr-smp2p-1-out/gpio/gpiochip796
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip828 → …/…/devices/soc:qcom,smp2pgpio-ssr-smp2p-1-in/gpio/gpiochip828
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip860 → …/…/devices/soc:qcom,smp2pgpio-smp2p-1-out/gpio/gpiochip860
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip892 → …/…/devices/soc:qcom,smp2pgpio-smp2p-1-in/gpio/gpiochip892
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip924 → …/…/devices/soc:qcom,smp2pgpio-smp2p-15-out/gpio/gpiochip924
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip956 → …/…/devices/soc:qcom,smp2pgpio-smp2p-15-in/gpio/gpiochip956
lrwxrwxrwx 1 root root 0 Jan 1 1970 gpiochip988 → …/…/devices/78b8000.i2c/i2c-4/4-0022/gpio/gpiochip988
–w------- 1 root root 4096 Jan 1 1970 unexport
root@fx30s:/sys/class/gpio# microcom /dev/ttyAT
AT+WIOCFG?
+WIOCFG: 2,16,0,0,1,0,0
+WIOCFG: 4,3,0,0,1,0,0
+WIOCFG: 6,16,0,0,1,0,0
+WIOCFG: 7,16,0,0,1,0,0
+WIOCFG: 8,16,1,0,1,0,0
+WIOCFG: 13,16,0,0,1,0,0
+WIOCFG: 21,16,0,0,1,0,0
+WIOCFG: 22,16,0,0,1,0,0
+WIOCFG: 23,4,1,1,0,0,0
+WIOCFG: 24,16,0,0,1,0,0
+WIOCFG: 25,16,0,0,1,0,0
+WIOCFG: 28,16,0,0,1,0,0
+WIOCFG: 29,16,0,0,1,0,0
+WIOCFG: 30,16,0,0,1,0,0
+WIOCFG: 31,16,0,0,1,0,0
+WIOCFG: 32,16,0,0,1,0,0
+WIOCFG: 33,16,0,0,1,0,0
+WIOCFG: 35,16,0,0,1,0,0
+WIOCFG: 42,16,0,0,1,0,0
is it ok to control like the following?
echo 0 > /sys/class/gpio/gpio47/value
echo 1 > /sys/class/gpio/gpio47/value
Yes that works from the Device shell, but not from within the app with a system() call and the app is sandboxed: false
You can try this app with system() call:
Thanks I got it working after implementing the scripts I discovered I had a typo in the system()
but now the system(“echo 0 > /sys/class/gpio/gpio47/value”); works
