According to the FX30S user guide R6 IO3/Gpio56 can be used to drive a load of <400mA. The device is running Legato 18.06.
So from the diagram I assume that +5-+36V from the power connector to IO3 should be able to drive a relay.
It should also be done with pullups off according to the user guide.
I have tried this but the multimeter (Amp range) between IO3 and Pin1 in the power connector shows nothing, reagrdless of the state of gpio56.
With pull ups on I get a response from the pin sending out +/-5V, but the drained amps are still displaying 0.
Any clue what I am doing wrong?
Edit:
It should also be noted that when I try to set the GPIO to tristate/open drain or enable/disable resistors using the API I get errors:
Open Drain API not implemented in sysfs GPIO
Tri-State API not implemented in sysfs GPIO
Disabling the resistors is not supported
Though accessing Gpio54 directly allows med to control the reisistors.
