Nothing is ever sent or received on the DB9 serial port.
I followed manual instructions to enable serial for DB9 RS232
[code]root@fx30s:~# microcom -E /dev/ttyAT
AT!MAPUART=17,1
AT!MAPUART?
!MAPUART: 17,0
root@fx30s:~# reboot
root@fx30s:~# ./rs485.py /sys/devices/platform/msm_serial_hsl.0/rs_mode 0
RS232
root@fx30s:~# reboot[/code]
Manual suggest using null modem adapter since i am try to talk to a DCE.
My adaptor uses two DB9 male connectors with the following wiring:
root@fx30s:~# microcom -s 115200 -E /dev/ttyHSL0
#1,N?;
The ASCII command #1,N?; should respond with a the device serial string from the DCE, which I have confirmed with other devices computers.
I have also tried the same instructions for UART2/ttyHSL1 but from what I can gather that is wired internally to the IoT board which I don’t have.
If I do a logread command, part of the boot message hints at a failure
Mar 2 01:24:49 fx30s user.info kernel: [ 1.139539] msm_serial: driver initialized
Mar 2 01:24:49 fx30s user.info kernel: [ 1.139783] ttyHS0, function 0 is not valid on application processor.
Mar 2 01:24:49 fx30s user.warn kernel: [ 1.139813] msm_serial_hs: probe of msm_serial_hs.0 failed with error -1
Mar 2 01:24:49 fx30s user.info kernel: [ 1.139966] msm_serial_hs module loaded
Please let me know if I missed a step or i am doing something wrong, or if the failure message indicates broken hardware.
Since this was asked for in a previous question here are the ATI and AT8 details
[code]AT8
ERROR
ATI
Model: FX30S
Revision: SWI9X15Y_07.11.22.00 r33729 CARMD-EV-FRMWR1 2017/01/11 18:04:06
MEID: 35398408007841
ESN: 12807114230, 806C8DF6
IMEI: 353984080078411
IMEI SV: 43
FSN: LL709600521610
+GCAP: +CGSM,+DS,+ES
ATI8
Legato Ver: 16.10.1_eea67704afa1ebc0450d230baa84ac28
Yocto Ver: SWI9X15Y_07.11.21.00 2017-04-19_15:57:04
OS Ver: Linux version 3.14.29ltsi-a00e464379_c5f87a778d (jenkins@CAKEL-EV-ALBLD2) (gcc version 4.9.1 (GCC) ) #2 PREEMPT Wed Apr 19 15:36:04 PDT 2017
LK Ver: 1.3.0_b12d0630d0
RootFS Ver: SWI9X15Y_07.11.21.00 2017-04-19_15:57:04
UserFS Ver: unknown
MCU Ver: 001.011
OK[/code]
