FX30S 16.10.1.m3 WP85 GNSS time to first fix issues
Hi
  • WP8548 FX30S
  • The system has no IP network connection (SMS only)
  • The FX30S RTC is reset following POR (no battery is fitted to the FX30s)
  • A SIM was fitted during testing - the system time is correct at the start of testing - I think this is because it’s being set by cellular network time
  • I noticed that if I leave the SIM out the system time is not set even if the GNSS has time - I haven’t checked the impact on TTFF
I have noticed that in order to acheive fast time to first fix (TTFF) I need to issue a command line “poweroff” to the modem.
  1. Is this because “poweroff” triggers long term storage of the alamanac and / or ephemeris? or something else?
  2. Is there another way to trigger this other than “poweroff” ?
  3. Is documentation available for this behaviour and how to acheive good TTFF performance with the FX30S?
Some test results
After power on reset
TTFF start = 812 s
After "gnss restart cold"
TTFF start = 183 sec
TTFF start = 256 sec
After gnss fix and reboot from command line (no POR)
TTFF start = 11 sec
Following "poweroff" command and power cycle
TTFF start = 34 sec
TTFF start = 10 sec
Following "poweroff" command and after 24 hours powered down
TTFF start = 39 sec
John
Please refer to https://forum.legato.io/t/wp8548-fx30-16-10-3-4-gnss-gps-time-to-first-fix/4318/3
