Dear all,
I am building the Fx30-CatM R14 (Linux part) release swi-fx30-catm_3.0.0 without any modifications.
I have retreaved the linux sources with leaf, running the following command (on Ubuntu 18.04):
$> leaf setup fx30-catm -p swi-fx30-catm_3.0.0
$> leaf getsrc legato
$> leaf getsrc swi-linux
$> cd swi-linux
$> make MACH=mdm9x28 PROD=fx30
And I obtain several warning traces indicating a problem in the patches applications.
WARNING: linux-libc-headers-3.18.140-r0 do_patch:
Some of the context lines in patches were ignored. This can lead to incorrectly applied patches.
The context lines in the patches can be updated with devtool:
devtool modify <recipe>
devtool finish --force-patch-refresh <recipe> <layer_path>
Then the updated patches and the source tree (in devtool's workspace)
should be reviewed to make sure the patches apply in the correct place
and don't introduce duplicate lines (which can, and does happen
when some of the context is ignored). Further information:
http://lists.openembedded.org/pipermail/openembedded-core/2018-March/148675.html
https://bugzilla.yoctoproject.org/show_bug.cgi?id=10450
Details:
Applying patch 0001-if_ether-move-muslc-ethhdr-protection-to-uapi-file.patch
patching file include/uapi/linux/if_ether.h
Hunk #1 succeeded at 141 with fuzz 2 (offset 4 lines).
Now at patch 0001-if_ether-move-muslc-ethhdr-protection-to-uapi-file.patch
Details:
Applying patch 0004-Avoid-in6_addr-redefinition.patch
patching file include/uapi/linux/if_bridge.h
Hunk #1 succeeded at 15 with fuzz 2.
patching file include/linux/netfilter.h
Hunk #1 succeeded at 5 (offset 1 line).
Now at patch 0004-Avoid-in6_addr-redefinition.patch
WARNING: system-core-1.0-r1 do_patch:
Details:
Applying patch fix-big-endian-build.patch
patching file adb/usb_linux_client.c
Hunk #1 succeeded at 35 with fuzz 2 (offset 1 line).
Now at patch fix-big-endian-build.patch
WARNING: alsa-intf-1.0-r1 do_patch:
Details:
Applying patch 0006-Wait-for-Audio-stream-to-end.patch
patching file libalsa-intf/aplay.c
Hunk #1 succeeded at 604 with fuzz 2 (offset 60 lines).
Now at patch 0006-Wait-for-Audio-stream-to-end.patch
Should I be worried by those warnings?
Regards, Christian.
