After update the firmware, I cannot run further updates or run modem commands like “cm info”. We believe the first update was with a partial image, so we would like to overcome the error message or reset to the original firmware and try again.
- Coworker set up a FX30 and updated successfully, who then instructed me
- I started with a fresh FX30 3G (PN:1103214)
- followed instructions to set up the leaf environment in a Ubuntu 18.04 followed instructions to set up the leaf environment. We added minor steps to stay in Python 2.
- obtained firmware image, “.leaf/wp85-modem-image_17/9999999_9904559_SWI9X15Y_07.14.01.00_00_GENERIC_001.042_000.spk”; firmware updated successfully
- “fwupdate query” shows up-to-date firmware and bootloader but factory versions of legato, linux, and fx30 (see info at the end)
- “fwupdate download {any file}” returns
Error in download, cat: write error: Broken pipe
- Similar results after transferring the file and running it inside ssh. Similar results unpacking the spk file into cwe files and trying one individually.
- We notice the spk file we initially used does not contain as many cwe files as “.leaf/fx30-3g-image_1.0.1/9999999_9904559_SWI9X15Y_07.14.01.00_00_GENERIC_001.042_000-full.spk”, so maybe the missing updates are causing the issue
- The Windows FDT2 tool command:
fdt2.exe -d wpspk -fd firmware GenericFull.spk -force -log firmware
returns:
Firmware download failed - firmware and PRI version mismatch.
- I noticed “at!image?” showed the active FW image is deleted (slot 255) and a different version than PRI, so I deleted both using “at!image=0,0”, but similar results.
Here is my modem info:
at
at!entercnd=“A710”
at!image?
FW 1 EMPTY 0 0 0
FW 2 EMPTY 0 0 0
FW 3 EMPTY 0 0 0
Max FW images: 3
Active FW image is at slot 255
Max PRI images: 50
at!pcinfo?
State: Online
LPM force flags - W_DISABLE:0, User:0, Temp:0, Volt:0, BIOS:0, GOBIIM:0
W_DISABLE: 0
Poweroff mode: 0
LPM Persistent: 0
at!gstatus?
!GSTATUS:
Current Time: 2324 Temperature: 25
Bootup Time: 0 Mode: ONLINE
System mode: GSM PS state: Not attached
GSM band: Unknown
GSM channel: 65535
GMM (PS) state:DEREGISTERED PLMN SEARCH
MM (CS) state: IDLE NO IMSI
Serving Cell: 0 (No band )
RX level (dBm):0.0 LAC: 0000 (0)
GPRS State: GPRS IDLE Cell ID: 00000000 (0)
IMS Reg State: UNKNOWN IMS Mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
fwupdate query
Firmware Version: SWI9X15Y_07.14.01.00 595652d jenkins 2018/10/26 08:34:29
Bootloader Version: SWI9X15Y_07.14.01.00 595652d jenkins 2018/10/26 08:48:35
Linux Version: 3.14.29ltsi-a00e464379_3f15cd39ad #2 PREEMPT Mon Feb 20 11:11:17 PST 2017
FX30 Version: R13.1.2.004
^Firmware and Bootloader are updated. Linux and FX30 are outdated.
legato version
16.10.1_f8947ec5fd286f5b9d2c25ebb9ad81a4
^Legato is outdated
