FTP close
I am using Q24plus,
I am transferring file from modem to server using wip_putfile() and wip_write().
After transferring file if i use wip_close() and wip_bearerstop() i am getting WIP_CEV_ERROR and module restrats.
bearer_hdlr()
ftp_WipHandle = wip_FTPCreateOpts( ftp_address, ftp_SessionHandler_ls_tp, NULL, WIP_COPT_USER, ftp_usrname, WIP_COPT_PASSWORD, ftp_passwd, WIP_COPT_PEER_PORT, 21, WIP_COPT_END);
ftp_sessionhandler()
ftp_WipDataHandle=wip_putFile(ftp_WipHandle,ftp_filename,ftp_DataHandler_ls_tp,NULL);
ftp_DataHandler_ls_tp()
wip_write( wip_channel, &recv_data_buf[ntimes], send_buff_size);
closeftpconnection()
wip_close( ftp_WipHandle);
wip_bearerStop(wip_bearer);
How to close safely the ftp connection after successfully transferring the full file?
Please give suggestions.
bearer_hdlr()
	ftp_WipHandle = wip_FTPCreateOpts( ftp_address, ftp_sessionhandler, NULL, WIP_COPT_USER, ftp_usrname, WIP_COPT_PASSWORD, ftp_passwd, WIP_COPT_PEER_PORT, 21, WIP_COPT_END);
ftp_sessionhandler(wip_event_t *ev, void *ctx)
	switch( ev->kind) {
	  case WIP_CEV_OPEN:
		  break;
	  case WIP_CEV_ERROR:
		  wip_close( ev->channel);
		  break;
	  case WIP_CEV_DONE:
		  wip_close(ev->channel);	// file transfer completed. close the control channel
		  break;
	  case WIP_CEV_PEER_CLOSE:
	  	//Ftp server closed the channel.
	  	break;
	  default:
		  break;
ftp_DataHandler_ls_tp( wip_event_t *ev, void *ctx)
	switch (ev->kind)
		case WIP_CEV_OPEN:
			break;
		case WIP_CEV_READ:
			break;
		case WIP_CEV_WRITE:
				//f_enterFS();
				if (//no more data to send)
					sRet = wip_close(ev->channel);
				else
					// ATTENTION: if your buffer is big, you have to send it in chunks
					wip_write(ev->channel, &recv_data_buf[ntimes], send_buff_size);
					break;
			break;
		case WIP_CEV_DONE:
				sRet = wip_close(ev->channel); // file transfer completed. close the data channel
			break;
			break;
		case WIP_CEV_ERROR:
			// error handling
			break;
		default:
			break;
Thanks Shekib.
I got the solution from WIP samples given in OpenAT suite.
it is working after modified as below
wip_close( ftp_WipDataHandle);
wip_close(ftp_WipHandle );
because ftp_WipDataHandle=wip_putFile(ftp_WipHandle,ftp_filename,ftp_DataHandler_ls_tp,NULL) will use tcp/ip channel to transfer file so we have to close first ftp connection and then close ev->channel
Have you checked because in my case giving wip_close(ev->channel) throws WIP_CEV_ERROR in ftp session handler?
wip_close( ftp_WipDataHandle) and wip_close(ftp_WipHandle ) working OK without restart
