We notice, that after freshly booting our HL7692 module (has RHL769x.2.23.172400.201706231140.x7120m_1 firmware, that it came with), sometimes (maybe 1 time in 4), the first AT+WMTXPOWER command that we issue, does not elicit an OK response, and indeed is not acted upon (no RF transmission observed on Spectrum Analyser).
The second command, with perhaps different settings, is fine (OK response, and RF transmission observed on Spectrum Analyser). And if for the third command, we repeat the first command, that third command is now fine. We can then toggle, ad infintum, between those two commands. And all are fine. Here’s an example sequence:
AT+WMTXPOWER=1,3,19575,368,0
AT+WMTXPOWER=1,8,21625,368,0
We do of course acknowledge that the manual (AirPrime_HL76xx_AT_Commands_Interface_Guide_Rev12_1.pdf) page 326 says the following about the AT+WMTXPOWER command: ‘The module must be restarted after using this command.’ That statement doesn’t actually appear to be true, in so far as subsequent commands elicit an OK response, and are acted upon (RF transmission observed on Spectrum Analyser). The key issue here, though, is that the first command after HL7692 boot, sometimes fails. Infact, sometimes, the first two commands fail.
The same happens if we boot and then issue an AT+WMRXPOWER command. Likewise, the first one or sometimes two AT+WMRXPOWER commands, fail. But subsequent ones are fine. Even, when we try the same command as that first failing one or two commands. Here’s an AT+WMRXPOWER command example sequence:
AT+WMRXPOWER=1,900,62,-109
AT+WMRXPOWER=1,1800,699,-108
+WMRXPOWER: -85.6
+WMRXPOWER: -84.4
+WMRXPOWER: -85.6
+WMRXPOWER: -84.4
+WMRXPOWER: -85.6
Is this all a bug perhaps, with the 2.23 firmware ? A known one ? That is fixed in a later firmware version ? We see the latest presently is 2.27. The 2.27 release note makes no mention of the AT+WMTXPOWER or AT+WMRXPOWER commands. But what about other firmware versions, between 2.23 and 2.27 ? They are not available on the Sierra website, nor their releases notes. So who knows ?
If a bug with 2.23 firmware, is there some workaround ? We’ve tried, prior to issuing that first one or two AT+WMTXPOWER or AT+WMRXPOWER command,s the following, none worked: 1) Issuing a AT+WMTXPOWER=0 command. 2) Issuing a AT+WMRXPOWER=0 command. 3) Issuing both. 4) Issuing an ATI command. 5) Issuing an AT command. 6) Issuing just a carriage return.
Best regards,
David
