Hello.
our module is M1306B
I need to send the fax on some phone number
In open AT sample applications i did n’t find the example.
but notes,about this feature, have been in ad docs
Hi Bulat,
I would guess it uses the standard fax commands… If somebody could confirm this? If the standard commands are used, Wavecom does not need to give you an example or explain to you how those commands are used… You should read the specification and literature that explains this…
Best Regards,
Jan
