The tool we use is:
smstools3.kekekasvi.com/
the version:
smstools-3.1.14-9
With other kind of model on the same OS we never get this problem.
The configuration:
[GSM1]
device = /dev/ttyS0
baudrate = 115200
mode = new
incoming = yes
cs_convert = yes
report = no
regular_run_interval = 60
regular_run_cmd = AT+CREG?;+CSQ;+COPS?
here the piece of smstools log where a sms is sent and then the serial connection to the modem became unavailable:
2012-06-28 05:21:45,6, GSM1: Pre-initializing modem
2012-06-28 05:21:45,7, GSM1: -> ATE0+CMEE=1;+CREG=2
2012-06-28 05:21:45,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:21:45,7, GSM1: <- OK
2012-06-28 05:21:46,7, GSM1: -> AT+CSQ
2012-06-28 05:21:46,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:21:46,7, GSM1: <- +CSQ: 22,0 OK
2012-06-28 05:21:46,6, GSM1: Signal Strength Indicator: (22,0) -69 dBm (Excellent), Bit Error Rate: less than 0.2 %
2012-06-28 05:21:46,6, GSM1: Checking if Modem is registered to the network
2012-06-28 05:21:46,7, GSM1: -> AT+CREG?
2012-06-28 05:21:46,7, GSM1: <- +CREG: 2,1,“4E76”,“0187” OK
2012-06-28 05:21:46,6, GSM1: Modem is registered to the network
2012-06-28 05:21:46,6, GSM1: Selecting PDU mode
2012-06-28 05:21:47,7, GSM1: -> AT+CMGF=0
2012-06-28 05:21:47,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:21:47,7, GSM1: <- OK
2012-06-28 05:21:47,6, GSM1: Checking memory size
2012-06-28 05:21:47,7, GSM1: -> AT+CPMS?
2012-06-28 05:21:48,7, GSM1: <- +CPMS: “SM”,0,50,“SM”,0,50,“SM”,0,50 OK
2012-06-28 05:21:48,6, GSM1: Used memory is 0 of 50
2012-06-28 05:21:48,6, GSM1: No SMS received
2012-06-28 05:21:59,5, smsd: Moved file /var/spool/sms/outgoing/send_Wh6608 to /var/spool/sms/checked
2012-06-28 05:21:59,6, GSM1: I have to send 1 short message for /var/spool/sms/checked/send_Wh6608
2012-06-28 05:21:59,6, GSM1: Sending SMS from to 393351214750
2012-06-28 05:21:59,6, GSM1: Checking if modem is ready
2012-06-28 05:21:59,7, GSM1: -> AT
2012-06-28 05:21:59,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:21:59,5, smsd: Moved file /var/spool/sms/outgoing/send_eG6634 to /var/spool/sms/checked
2012-06-28 05:21:59,7, GSM1: <- OK
2012-06-28 05:21:59,6, GSM1: Pre-initializing modem
2012-06-28 05:21:59,7, GSM1: -> ATE0+CMEE=1;+CREG=2
2012-06-28 05:22:00,7, GSM1: <- OK
2012-06-28 05:22:00,7, GSM1: -> AT+CSQ
2012-06-28 05:22:00,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:22:00,7, GSM1: <- +CSQ: 22,0 OK
2012-06-28 05:22:00,6, GSM1: Signal Strength Indicator: (22,0) -69 dBm (Excellent), Bit Error Rate: less than 0.2 %
2012-06-28 05:22:00,6, GSM1: Checking if Modem is registered to the network
2012-06-28 05:22:01,7, GSM1: -> AT+CREG?
2012-06-28 05:22:01,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:22:01,7, GSM1: <- +CREG: 2,1,“4E76”,“0187” OK
2012-06-28 05:22:01,6, GSM1: Modem is registered to the network
2012-06-28 05:22:01,6, GSM1: Selecting PDU mode
2012-06-28 05:22:01,7, GSM1: -> AT+CMGF=0
2012-06-28 05:22:02,7, GSM1: <- OK
2012-06-28 05:22:02,7, GSM1: -> ATE1+CMGS=136
2012-06-28 05:22:02,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:22:02,7, GSM1: <- >
2012-06-28 05:22:02,7, GSM1: -> 0011000C919333151274050000FF8BCE32BD982F835A20A8F42964169BA016283985828A75F9DB9EA6A7412D90B83E4FBBCBF379042E7F8FCBF379790E6A8162B29B0BE682B962A01668284D5293C32013D402C9702D98AD2583C56420584D278BE96836500B24ACCFD3EEF27C0E82CADFE3F27C0E1A4A93D4E430C8D481925328A85897BFED697A1A
2012-06-28 05:23:00,5, smsd: Moved file /var/spool/sms/outgoing/send_D16063 to /var/spool/sms/checked
2012-06-28 05:23:00,5, smsd: Moved file /var/spool/sms/outgoing/send_h16037 to /var/spool/sms/checked
2012-06-28 05:23:03,7, GSM1: put_command expected (OK)|(ERROR), timeout occurred. 1.
2012-06-28 05:23:03,7, GSM1: <- 0011000C919333151274050000FF8BCE32BD982F835A20A8F42964169BA016283985828A75F9DB9EA6A7412D90B83E4FBBCBF379042E7F8FCBF379790E6A8162B29B0BE682B962A01668284D5293C32013D402C9702D98AD2583C56420584D278BE96836500B24ACCFD3EEF27C0E82CADFE3F27C0E1A4A93D4E430C8D481925328A85897BFED697A1A
2012-06-28 05:23:03,5, GSM1: Verify PDU: OK
2012-06-28 05:23:04,7, GSM1: -> ATE0
2012-06-28 05:23:04,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:23:09,7, GSM1: put_command expected (OK)|(ERROR), timeout occurred. 2.
2012-06-28 05:23:09,7, GSM1: <- ATE0 >
2012-06-28 05:23:09,3, GSM1: The modem answer was not OK: 0011000C919333151274050000FF8BCE32BD982F835A20A8F42964169BA016283985828A75F9DB9EA6A7412D90B83E4FBBCBF379042E7F8FCBF379790E6A8162B29B0BE682B962A01668284D5293C32013D402C9702D98AD2583C56420584D278BE96836500B24ACCFD3EEF27C0E82CADFE3F27C0E1A4A93D4E430C8D481925328A85897BFED697A1A
2012-06-28 05:23:09,5, GSM1: Waiting 10 sec. before retrying
2012-06-28 05:23:19,6, GSM1: Checking if modem is ready
2012-06-28 05:23:19,7, GSM1: -> AT
2012-06-28 05:23:19,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:23:24,7, GSM1: put_command expected (OK)|(ERROR), timeout occurred. 3.
2012-06-28 05:23:24,7, GSM1: <- AT >
2012-06-28 05:23:25,7, GSM1: ->
2012-06-28 05:23:25,7, GSM1: Command is sent, waiting for the answer
2012-06-28 05:23:30,7, GSM1: put_command expected (OK)|(ERROR), timeout occurred. 4.
2012-06-28 05:23:30,7, GSM1: <-
2012-06-28 05:23:30,7, GSM1: -> AT
Thanks for the help!
