pavel
March 2, 2021, 11:21am
1
Hello
I’m trying to mount an ext4 formatted SD Card and I get:
mount: unknown filesystem type 'ext4'
And sure enough ext4 is not supported
# cat /proc/filesystems
nodev sysfs
nodev rootfs
nodev ramfs
nodev bdev
nodev proc
nodev cgroup
nodev cpuset
nodev tmpfs
nodev devtmpfs
nodev debugfs
nodev securityfs
nodev sockfs
nodev pipefs
nodev rpc_pipefs
nodev configfs
nodev devpts
squashfs
vfat
nodev nfs
nodev nfs4
nodev overlay
nodev mqueue
nodev smackfs
nodev mtd_inodefs
nodev ubifs
nodev functionfs
It is present in /etc/filesystems however
# cat /etc/filesystems
ext4
ext3
ext2
vfat
fat
btrfs
minix
How do I enable Ext4 filesystem support on a WP76xx module?
So far I’ve tried adding it with IMAGE_FSTYPES += " ext4" in my image.inc file but doesn’t appear to do anything.
Thanks!
pavel
March 2, 2021, 11:54am
3
Thanks, though not quite, I am able to use mkfs.ext4 and format the SD card but my issue is mounting it. I can read/write it ok on a desktop machine so can confirm it’s correctly formatted and partitioned.
jyijyi
March 2, 2021, 12:21pm
4
I just see the menuconfig on FW R13 yocto source, I saw there is EXT4 related flag in it, you can try to enable it.
# cd yocto
# make dev
build_bin# bitbake linux-quic -c menuconfig
pavel
March 2, 2021, 3:31pm
5
Thanks, however due to the way we’ve set our workspace, I can’t use bitbake or not easily at least. Can you advice what changes the flag does or which packages I need to add?
jyijyi
March 2, 2021, 3:40pm
6
I never tried before, but I saw that inside meunuconfig search, there is ext4 related flag, you can see here:
ext4.txt (7.1 KB)
so it worths a try to add those flags in menuconfig
jyijyi
March 3, 2021, 7:57am
7
I just tried to enable in menuconfig
filesystem → The Extended 4 (ext4) filesystem
After that recompile the yocto image, now I can see:
root@swi-mdm9x28-wp:~# cat /proc/filesystems
nodev sysfs
nodev rootfs
nodev ramfs
nodev bdev
nodev proc
nodev cgroup
nodev cpuset
nodev tmpfs
nodev devtmpfs
nodev debugfs
nodev securityfs
nodev sockfs
nodev pipefs
nodev rpc_pipefs
nodev configfs
nodev devpts
ext3
ext2
ext4
squashfs
vfat
nodev nfs
nodev nfs4
nodev overlay
nodev mqueue
nodev smackfs
nodev mtd_inodefs
nodev ubifs
nodev functionfs
root@swi-mdm9x28-wp:~# cat /etc/filesystems
ext4
ext3
ext2
vfat
fat
btrfs
minix
root@swi-mdm9x28-wp:~# cm info
Device: WP7607-1
IMEI: 359780080500170
IMEISV: 6
FSN: V2842570321010
Firmware Version: SWI9X07Y_02.28.03.03 000000 jenki[ 241.643193] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its powered: msgs(n:1 cur:0 tx) bc(rx:0 tx:2) mode:FIFO slv_addr:0x3a MSTR_STS:0x0c1300c8 OPER:0x00000090
ns 2019/05/21 03:33:04
Bootloader Version: SWI9X07Y_[ 241.662671] i2c-msm-v2 78b8000.i2c: NACK: slave not responding, ensure its powered: msgs(n:1 cur:0 tx) bc(rx:0 tx:2) mode:FIFO slv_addr:0x3a MSTR_STS:0x0c1300c8 OPER:0x00000090
02.28.03.03 000000 jenkins 2019/05/21 03:33:04
MCU Version: 002.011
PRI Part Number (PN): 9908645
PRI Revision: 001.001
Carrier PRI Name: GENERIC
Carrier PRI Revision: 002.068_000
SKU: 1104186
Last Reset Cause: Reset, User Requested
Resets Count: Expected: 148 Unexpected: 0
pavel
March 3, 2021, 1:52pm
8
Thanks, that’s what I’m after. Is there a way to enable the feature without using menuconfig and by directly modifying the kernel settings?
jyijyi
March 3, 2021, 3:48pm
9
You can go to yocto/kernel/arch/arm/configs/mdm9607_defconfig
and add CONFIG_EXT4_FS=y
After that you can build the yocto image and try.
pavel
March 3, 2021, 4:18pm
10
Sorry, should’ve clarified. I already tried adding to mdm9607_defconfig but it didn’t work
Edit:
after the change the config option is still unset:
# zcat /proc/config.gz | grep CONFIG_EXT4_FS
# CONFIG_EXT4_FS is not set
pavel
March 3, 2021, 5:03pm
11
Appologies again, found a typo in my changes. It works now
