Loading Open AT IDE…
Done.
Loading project settings…
done.
Building gcc_asd project…
Launch a full library or binary process
Get …/…/src/appli.c appli.c
Use YTPP
… Compiling appli.c
appli.c: In function ‘FCM_ControlHandler’:
appli.c:192: warning: case label value is less than minimum value for type
appli.c:196: warning: case label value is less than minimum value for type
appli.c:200: warning: case label value is less than minimum value for type
appli.c:225: warning: passing argument 2 of ‘adl_fcmSendData’ discards qualifiers from pointer target type
Copy all needed library and object files
Make links d:/OpenAT/OS/3.14.03/ADL/gcc_wmadl_3.14.0.3.0.lib …/out/gcc_wmadl_3.14.0.3.0.lib
Make links d:/OpenAT/Plug-ins/WIP/3.10.1030/WIP/gcc_wmwip_3.10.1030.lib …/out/gcc_wmwip_3.10.1030.lib
Make links d:/OpenAT/Plug-ins/WIP/3.10.1030/WIP/gcc_wmwipSoft_3.10.1030.lib …/out/gcc_wmwipSoft_3.10.1030.lib
… Link step in progress …
… Link gcc_asd.bin …
Extract gcc_asd.bin from gcc_asd.axf (or from gcc_asd.elf if Gcc ARM compiler is used)
Update symbol file -> ../out/s
Compress gcc_asd.bin to gcc_asd.wpb for DWLWIN application
… Make TMT directory …
Make links …/out/s …/out/tmt/symbolfiles/s
Create …/out/tmt/config/DiagnoseTips.ini
Create …/out/tmt/config/MokaWatches.ini
Create …/out/tmt/config/RemoteDefs.ini
Create …/out/tmt/gcc.wks
No remote trace file found
Create TMT archive file
ls: cannot access …/out/pro-lib.bin: No such file or directory
Make an archive file for TMT application
zip warning: name not matched: …/out/tmt/e2p_csn.cso
zip error: Nothing to do! (…/out/tmt/zip_tmt.zip)
zip warning: name not matched: …/out/tmt/backtraces64k.axf
zip warning: name not matched: …/out/tmt/symbolfiles/s64k
zip warning: name not matched: …/out/tmt/symbolfiles/e2p.h
adding: backtraces.axf (deflated 76%)
enter new zip file comment (end with .):
current zip file comment is:
[Binary Information]
Stack Version = Open-AT
Customer Version = gcc
Binary Name = pro-lib.bin
Size =
Date = 122909
Time = 00:00:00
adding: s (deflated 66%)
Size =
Date = 122909
Time = 00:00:00
Size =
Date = 122909
Time = 00:00:00
Size =
Date = 122909
Time = 00:00:00
adding: DiagnoseTips.ini (deflated 87%)
Size =
Date = 122909
Time = 00:00:00
adding: MokaWatches.ini (deflated 67%)
Size =
Date = 122909
Time = 00:00:00
adding: RemoteDefs.ini (deflated 74%)
Size =
Date = 122909
Time = 00:00:00
Rename …/out/tmt/zip_tmt.zip …/out/tmt/gcc.zip
Keep only the TMT archive file in …/out/tmt
Remove …/out/tmt/e2p_csn.cso
Remove …/out/tmt/sys_ftr.ho
Remove …/out/tmt/wm_ftr.ho
Remove …/out/tmt/remtrace.csv
Remove …/out/tmt/backtraces.axf
Remove …/out/tmt/backtraces64k.axf
Remove …/out/tmt/remtrace_full.csv
Remove …/out/tmt/symbolfiles directory
Remove …/out/tmt/config directory
… Create binary in X-MODEM format from gcc_asd.bin …
Add a checksum to gcc_asd.sgt
(AddCheck Version v2.0.4 Copyright © WAVECOM) [Feb 14 2003, 15:50:57]
Time modified : Tue Dec 29 12:25:32 2009
… Build gcc_asd.dwl …
genBin : Version v1a06 Copyright © WAVECOM
genBin : No Error
Cleaning temporary files (*.tmp / *.trc)
Generation done with SGT v1.2.12oat
Binary files created :
gcc_asd.bin
pro-dwl.bin
Binary files in Xmodem format :
gcc_asd.dwl
Compiler keyword : gcc_arm
Compiler release : GCC ARM
C compiler path : d:/OpenAT/IDE/GCC/4.0.1.0/bin/arm-elf-gcc
ASM compiler path : d:/OpenAT/IDE/GCC/4.0.1.0/bin/arm-elf-gcc
customer release : gcc
Name of the current directory : gcc
Log file : …/out/gcc_asd_status.log
Release of the environement : CYGWIN_NT-5.1 liu 1.5.23(0.156/4/2) 2006-12-19 10:52 i686 Cygwin
Build an X-MODEM binary : 'gcc_asd.wpb.dwl'
… Convert gcc_asd.wpb in X-MODEM format …
genBin : No Error
… Build gcc_asd.wpb.dwl …
AXFshrinker Version 1.0.0.1 ( Aug 23 2002 , 17:44:58 )
updating: backtraces.axf (deflated 76%)
Done.
Results
asd - 1 error(s), 8 warning(s)
why? how can i solve it??
I used vc++6.0
