maybe you need to use “sudo”
Thanks am successfully flashed the firmware, in my console continuously i am getting the below logs.
[ 98.072126] PM: Some devices failed to suspend, or early wake event detected
[ 99.124636] msm_hsic_host 7c00000.hsic_host: Unable to resume USB. Reset the hsic
[ 99.211848] msm_hsic_host 7c00000.hsic_host: ulpi_write: timeout ULPI_VIEWPORT: 603300ff
[ 99.211879] msm_hsic_host 7c00000.hsic_host: PORTSC: 8c000000 USBCMD: 00010005 FRINDEX: 000008e8
[ 99.212035] msm_hsic_host 7c00000.hsic_host: ulpi_write: FRINDEX: 000008e8
[ 99.286353] msm_hsic_host 7c00000.hsic_host: ulpi_write: timeout ULPI_VIEWPORT: 603000a8
[ 99.286380] msm_hsic_host 7c00000.hsic_host: PORTSC: 8c000000 USBCMD: 00010005 FRINDEX: 00000b38
[ 99.286536] msm_hsic_host 7c00000.hsic_host: ulpi_write: FRINDEX: 00000b38
[ 99.360756] msm_hsic_host 7c00000.hsic_host: ulpi_write: timeout ULPI_VIEWPORT: 60310001
[ 99.360783] msm_hsic_host 7c00000.hsic_host: PORTSC: 8c000000 USBCMD: 00010005 FRINDEX: 00000d88
[ 99.360939] msm_hsic_host 7c00000.hsic_host: ulpi_write: FRINDEX: 00000d90
[ 99.435985] msm_hsic_host 7c00000.hsic_host: ulpi_write: timeout ULPI_VIEWPORT: 60090010
[ 99.436012] msm_hsic_host 7c00000.hsic_host: PORTSC: 8c000000 USBCMD: 00010005 FRINDEX: 00000fe8
[ 99.436168] msm_hsic_host 7c00000.hsic_host: ulpi_write: FRINDEX: 00000fe8
it is not going to sleep?
if you still can enter command in uart console, that means it is not sleeping.
i am not giving any command in console,but in console i am getting some logs
if I connect an other usb port below logs are getting .
[ 390.990652] gbam_disconnect_work: gbam_disconnect_work: Bam channel is not opened
[ 391.297300] gbam_connect_work: gbam_connect_work: Bam channel is not ready
**root@swi-mdm9x28-wp:~# **
If it is in sleep mode, it will not respond to your enter key.
any changes are required , I need to give any AT commands to go sleep, Please let me know?
No, i did not enter any special AT command.
IS any senario’s is there to go hibernation mode?
Seems now the only difference is the mangoh red board…
Actually my project requirement is implementing hibernation mode for that we selected mangOH red board. could Please tell me any alternative in these board to enable the hibernation mode?
Please try another hardware board and module and see if this is hardware problem
How to enable the sleep in wp7608?
Pls read above first.
