EM7565 Connection Speeds
I am using an EM7565 module connected to a board running ubuntu 24.04 with kernel 6.8.0-87. I’m using a T-Mobile SIM card. I am able to connect the modem to Network Manager using the following two commands.
nmcli con add type gsm ifname /dev/ttyUSB2 con-name lte-modem apn fast.t-mobile.com connection.autoconnect yes connection.autoconnect-retries 0
sudo nmcli con up lte-modem
When I go to speedtest.net and run a speed test, I am only able to get ~25 Mbps Download/~30 Mbps Upload speeds. I also have a ublox LARA-L6 CAT4 module that I ran speed tests on and I was able to get ~60Mbps Download/30 Mbps Upload from the same location in my office.
I have updated to the latest Firmware Generic SWI9X50C_01.14.22.00: https://source.sierrawireless.com/resources/airprime/minicard/75xx/em_mc75xx-approved-fw-packages/#sthash.Kf0SkdgE.foIJ5TAh.dpbs
using the SDK and Drivers for EM7565: Mobile Broadband Package for Linux (SDK, Drivers, Documentation)
Why is this happening when the EM7565 has CAT12 capabilities? I would expect this to perform at the same speed or higher speeds compared to the ublox cat4 module. I am using the same antenna. The only difference is that the EM7565 requires an adapter cable to go from IPEX to SMA. With the board the ublox module is on, I can screw in the antenna directly to SMA ports. The connector cable has a 50 Ohm Impedance, which is what the specifications recommend.
Antenna Used:
Cable Used:
Thanks for any help anyone can offer :slightly_smiling_face:
Jacob
After trying out the SWI9X50C_01.14.02.00 Firmware with T-mobile this greatly improved download speeds to 90 Mbps. Why is the Generic Firmware not as performant? If possible I would like for the device to work well with any SIM that is paired with it.
It is my understanding that the BUILD_ID of the Firmware Images must match up with the PRI Image BUILD_ID. So if I use the Generic SWI9X50C_01.14.02.00 Firmware Image and have 01.14.02.00_TMO, 01.14.02.00_ATT, 01.14.02.00_GENERIC, and 01.14.02.00_ROGERS PRI Images, then I would be able to put any of those 4 cell carriers SIM cards in and it connect with good speeds right? Would I be limited to those 4 carriers unless I flashed new firmware/changed the active FW Image?
If TMO sim card is used, probably you need to use the TMO certified firmware
To see what PRI and firmware have been downloaded to module, you can check at!image?
