Is the EM7511 supported for Ubuntu 18.04 LTS? I think there is an issue with the qmi_wwan driver, but I’m not sure where to get the proper set of drivers.
First - I noticed that modem manager wasn’t starting:
Aug 28 12:17:01 matt-lts-VirtualBox ModemManager[10541]: [1567012621.445671] [plugin manager] loaded plugin ‘ZTE’
Aug 28 12:17:01 matt-lts-VirtualBox ModemManager[10541]: [1567012621.445839] [plugin manager] successfully loaded 33 plugins
Aug 28 12:17:01 matt-lts-VirtualBox ModemManager[10541]: [1567012621.446376] [sleep-monitor] taking systemd sleep inhibitor
Aug 28 12:17:01 matt-lts-VirtualBox ModemManager[10541]: [1567012621.448787] Could not acquire the ‘org.freedesktop.ModemManager1’ service name
Aug 28 12:17:01 matt-lts-VirtualBox ModemManager[10541]: [1567012621.448910] Stopping connection in object manager server
Aug 28 12:17:01 matt-lts-VirtualBox ModemManager[10541]: [1567012621.454266] ModemManager is shut down
Aug 28 12:17:01 matt-lts-VirtualBox ModemManager[10541]: [1567012621.454487] disposing MMSleepMonitor singleton (0x22ac060)
But the USB drivers seemed to be installed:
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ohci-pci/12p, 12M
|__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 8, If 2, Class=Vendor Specific Class, Driver=qcserial, 12M
|__ Port 2: Dev 8, If 0, Class=Vendor Specific Class, Driver=qcserial, 12M
|__ Port 2: Dev 8, If 3, Class=Vendor Specific Class, Driver=qcserial, 12M
|__ Port 2: Dev 8, If 8, Class=Vendor Specific Class, Driver=qmi_wwan, 12M
Then I checked dmesg which is completely filled with:
[19075.461975] qmi_wwan 1-2:1.8: nonzero urb status received: -84
[19075.481129] qmi_wwan 1-2:1.8: nonzero urb status received: -84
[19075.499713] qmi_wwan 1-2:1.8: nonzero urb status received: -84
[19075.517936] qmi_wwan 1-2:1.8: nonzero urb status received: -84
[19075.537038] qmi_wwan 1-2:1.8: nonzero urb status received: -84
12M? There is something seriously screwed up here. Does this USB port support USB2.0 High Speed? I don’t know if the modem will work all that good on a Full Speed bus.
Never seen that error before, but then I haven’t seen many such modems connected to OHCI controllers either. 84 is EILSEQ, which if I understand the ohci-driver correctly, will be returned for two transfer status codes: CRC Error or Data Toggle, ref:
But whatever this means, it looks like your USB bus is completely screwed up. Are other USB devices working on this port? Does the EM7511 work when connected to other USB ports and/or hosts?
Thanks - yes, I believe you’re correct that my USB is screwed up. I hate to blame the hardware when I can’t get the software to work, but in this case I think it’s justified.
