In addition, I’ve tried to run a test OTA update, which returned “The selected firmware is not compatible with the current firmware on the device. Please check the name and type are consistent with the devices firmware ones”. EM7455B GENERIC Release 18 (MDM_SWI9X30C_02.24.03.00_PRI_9904609-002.021.000). It’s clear that the OTA firmware is older than the one installed, but the “not compatible” message is a bit confusing. Is it impossible to downgrade firmware versions via OTA, and is it possible to update the firmware version to the listed “approved firmware”?
So I am not too sure where the B part has come from, the unit is generally just an EM7455, indeed AV only allows you to register an EM7455, there is no B variant. I have looked for EM7455B on the server and there are some build packages on there which are quite old now but I think you need to just use the standard ones.
Thanks, Matt. I found the firmware after manually listing the EM7455 firmware. But even after OTA, it is still incorrectly reporting the "Application or firmware returned by this system is unknown from AirVantage [EM7455B…] error during sync. It’s not a huge problem since users can still find the correct firmware, but the default selection is evidently incorrect.
So looked a bit more, might also be because the EM7455B was a unit produced for a specific customer (I think) and as a result the server does not like it. I do not know what the difference between the standard product EM7455 and the variant EM7455B was but I don’t think it will have been a hardware variant as implied above.
The EM7455B that I found was in a Panasonic FZ-G2 MK1. When I talked to Panasonic we found that the modem should not even be in that series. The correct modem is EM7511 (build 5289). We changed out the the EM7455B (suspect FirstNet) for a EM7511 and was able to come up with only the standard drivers → wwan_2e36_build5289_9.0260.5289 from Pansonic.
