Recently i have integrated a Android Pie release for EM7455 on our platform, but it is now working correctly and showing following error in logcat, kindly please help us to solve this issue,
logcat -v time -b radio
01-01 01:34:44.242 D/RILD ( 838): RIL Daemon Started
01-01 01:34:44.243 D/RILD ( 838): RILd param count=7
01-01 01:34:44.328 W/RILD ( 838): RIL_SAP_Init not defined or exported in /vendor/lib64/libsierra-ril.so: undefined symbol: RIL_SAP_Init
01-01 01:34:44.328 D/RILD ( 838): RIL_Init argc = 6 clientId = 0
01-01 01:34:44.328 I/use-Rlog/RLOG-RIL( 838): Entering RIL_Init…
01-01 01:34:44.390 I/use-Rlog/RLOG-RIL( 838): Opening tty device automatically
01-01 01:34:44.390 I/use-Rlog/RLOG-RIL( 838): Using network interface wwan0 as primary data channel.
01-01 01:34:44.390 I/use-Rlog/RLOG-RIL( 838): Client id received 0
01-01 01:34:44.390 I/use-Rlog/RLOG-RIL( 838): RIL_Signalinit
01-01 01:34:44.390 I/use-Rlog/RLOG-RIL( 838): >>> voice feature enabled 1
01-01 01:34:44.390 I/use-Rlog/RLOG-RIL( 838): >>> persist.sierra.notification NOT set: debug radio notifcation disabled
01-01 01:34:44.391 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:44.405 E/use-Rlog/RLOG-RILQAPI( 881): 2 : SDK launch failed
01-01 01:34:45.400 I/use-Rlog/RLOG-RILQAPI( 838): SDK process startup failed
01-01 01:34:45.400 I/use-Rlog/RLOG-RIL( 838): SLQSStart failed… 2
01-01 01:34:46.400 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:46.406 E/use-Rlog/RLOG-RILQAPI( 929): 2 : SDK launch failed
01-01 01:34:47.408 I/use-Rlog/RLOG-RILQAPI( 838): SDK process startup failed
01-01 01:34:47.408 I/use-Rlog/RLOG-RIL( 838): SLQSStart failed… 2
01-01 01:34:48.114 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:48.156 E/use-Rlog/RLOG-RILQAPI( 1034): 2 : SDK launch failed
01-01 01:34:49.151 I/use-Rlog/RLOG-RILQAPI( 838): SDK process startup failed
01-01 01:34:49.151 I/use-Rlog/RLOG-RIL( 838): SLQSStart failed… 2
01-01 01:34:50.151 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:50.157 E/use-Rlog/RLOG-RILQAPI( 1301): 2 : SDK launch failed
01-01 01:34:51.159 I/use-Rlog/RLOG-RILQAPI( 838): SDK process startup failed
01-01 01:34:51.160 I/use-Rlog/RLOG-RIL( 838): SLQSStart failed… 2
01-01 01:34:52.160 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:52.165 E/use-Rlog/RLOG-RILQAPI( 1351): 2 : SDK launch failed
01-01 01:34:52.979 D/TelephonyManager( 982): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline (Permission denied)
01-01 01:34:52.979 D/TelephonyManager( 982): /proc/cmdline=
01-01 01:34:53.168 I/use-Rlog/RLOG-RILQAPI( 838): SDK process startup failed
01-01 01:34:53.168 I/use-Rlog/RLOG-RIL( 838): SLQSStart failed… 2
01-01 01:34:54.168 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:54.173 E/use-Rlog/RLOG-RILQAPI( 1367): 2 : SDK launch failed
01-01 01:34:55.176 I/use-Rlog/RLOG-RILQAPI( 838): SDK process startup failed
01-01 01:34:55.176 I/use-Rlog/RLOG-RIL( 838): SLQSStart failed… 2
01-01 01:34:56.176 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:56.183 E/use-Rlog/RLOG-RILQAPI( 1408): 2 : SDK launch failed
01-01 01:34:57.185 I/use-Rlog/RLOG-RILQAPI( 838): SDK process startup failed
01-01 01:34:57.185 I/use-Rlog/RLOG-RIL( 838): SLQSStart failed… 2
01-01 01:34:58.186 I/use-Rlog/RLOG-RILQAPI( 838): starting swi_osapisdkprocesscreate
01-01 01:34:58.191 E/use-Rlog/RLOG-RILQAPI( 1423): 2 : SDK launch failed
05-02 10:38:02.340 E/TelephonyManager( 1354): IMSI error: Subscriber Info is null
05-02 10:38:02.371 D/TelephonyManager( 983): No /proc/cmdline exception=java.io.FileNotFoundException: /proc/cmdline (Permission denied)
05-02 10:38:02.371 D/TelephonyManager( 983): /proc/cmdline=
