Hi Community,
I want to disable or want to configure the EM7455 modem in the LPM during driver suspend,
I have check the driver and found that during driver suspend mode EM7455 modem is not going in LPM,
However, I am able to assert the W_DISABLE line of the modem manually through gpio and also modem is going in LPM but after that i throw a two commands,
echo auto > ./1-1.1/power/control
echo 1 > /sys/bus/usb/devices/x-x/power/autosuspend_delay
And found that device is not going in proper sleep and it can take around 25 to 30 seconds for sleep,
And now i just throw two commands, this time W_DISABLE signal is not asserted,
(EM7455 modem is not in LPM but suspended)
By just above two commands device is going in sleep suddenly.
It look like after issuing W_DISABLE assert signal if i throw auto-suspend command device is not going in sleep suddenly and doing some process,
Can you please help me on this issue i want to configure the EM4755 modem in LPM during suspend mode and also device should go in sleep mode suddenly.
Thanks in advance,
Kevil
