Hi Community,
I want to disable the GPS in EM7455 modem, can you please guide me how to disable it?
Thanks in advance,
Kevil
Hi Community,
Thanks in advance,
Kevil
Hi Kevil,
I think you can try stop the GPS engine first.
// to stop GPS engine
AT!GPSEND=0
// to disable GPS completely (reset to take effect)
AT!ENTERCND=“A710”
AT!CUSTOM=“GPSENABLE”,0
AT!RESET
Per understanding, when GPS is stopped, it will not consume power, but you may test to confirm it.
For more details, please refer to AT cmd guide:
https://source.sierrawireless.com/resources/airprime/minicard/74xx/4117727-airprime-em74xx-mc74xx-at-command-reference/
Hope it helps, and please mark resolved if this answer your questions.
Thx
Thanks for the quick support,
I am not able to run the
AT!ENTERCND=“A710”
AT!RESET
It showing ERR,
Modem is password protected,
What to do in this condition?
Kevil
Hi Kevil,
The default password should be same, are you copy and paste it?
Maybe the quote “A710” was changed, please try below:
AT!ENTERCND="A710"
AT!CUSTOM="GPSENABLE",0
AT!RESET
Thx
I am tried both things, but still not able to enter the command it is showing “ERR”,
And according to datasheet we can also disable the GPS by W_DISABLE signal,
I have tried with that but how to verify GPS is successfully disabled is there any “AT” command to check?
Kevil
Not sure why… strange…
To check the GPS status, can you try AT!GPSSTATUS? command?
But using W_DISABLE, it may disable radio also so it no longer register to network…
I found this in EM7455 product specification.
(W_DISABLE1# (Wireless Disable) and W_DISABLE2# (GNSS Disable))
I have tried both with W_DISABLE1#, i have turn off the radio services and also verified with the,
“AT!!PCINFO”
AT(19)< State: Low Power Mode
AT(19)< LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:1, IMSWITCH:0, BIOS:0, LWM2M:0, OMADM:0, FOTA:0
AT(19)< LPM persistence - None
AT(19)< OK
It shows W_DISABLE:1,
It means it is disabled,
Tried to check it with “AT!GPSSTATUS?” command but not showing useful information
AT(16)< Current time: 2020 02 21 4 09:18:20
AT(16)< 1980 01 06 6 00:00:00 Last Fix Status = FAIL, FAILCODE = 9
AT(16)< 1980 01 06 6 00:00:00 Fix Session Status = FAIL, FAILCODE = 9
AT(16)< No TTFF available
AT(16)< OK
is there any other way to check it?
Kevil
“FAILCODE = 9” = “user ended the session”, that means GPS is not running.
