I don’t see problem with EM7455 to have USB3.0:
[117630.137678] usb 4-1: Product: EM7455
[117630.137684] usb 4-1: Manufacturer: Sierra Wireless, Incorporated
[117630.138977] usb 4-1: Enable of device-initiated U1 failed.
[117630.139285] usb 4-1: Enable of device-initiated U2 failed.
[117630.139515] usb 4-1: Disable of device-initiated U1 failed.
[117630.139656] usb 4-1: Disable of device-initiated U2 failed.
[117630.140010] usb 4-1: Enable of device-initiated U1 failed.
[117630.140339] usb 4-1: Enable of device-initiated U2 failed.
[117630.140528] usb 4-1: Disable of device-initiated U1 failed.
[117630.140665] usb 4-1: Disable of device-initiated U2 failed.
[117630.141195] GobiSerial 4-1:1.0: GobiSerial converter detected
[117630.141460] usb 4-1: GobiSerial converter now attached to ttyUSB0
[117630.141834] usb 4-1: Enable of device-initiated U1 failed.
[117630.142090] usb 4-1: Enable of device-initiated U2 failed.
[117630.142334] usb 4-1: Disable of device-initiated U1 failed.
[117630.142468] usb 4-1: Disable of device-initiated U2 failed.
[117630.142778] usb 4-1: Enable of device-initiated U1 failed.
[117630.143030] usb 4-1: Enable of device-initiated U2 failed.
[117630.143149] usb 4-1: Disable of device-initiated U1 failed.
[117630.143251] usb 4-1: Disable of device-initiated U2 failed.
[117630.143726] GobiSerial 4-1:1.2: GobiSerial converter detected
[117630.143909] usb 4-1: GobiSerial converter now attached to ttyUSB1
[117630.144203] usb 4-1: Enable of device-initiated U1 failed.
[117630.144458] usb 4-1: Enable of device-initiated U2 failed.
[117630.144654] usb 4-1: Disable of device-initiated U1 failed.
[117630.144756] usb 4-1: Disable of device-initiated U2 failed.
[117630.145032] usb 4-1: Enable of device-initiated U1 failed.
[117630.145272] usb 4-1: Enable of device-initiated U2 failed.
[117630.145395] usb 4-1: Disable of device-initiated U1 failed.
[117630.145490] usb 4-1: Disable of device-initiated U2 failed.
[117630.146005] GobiSerial 4-1:1.3: GobiSerial converter detected
[117630.146193] usb 4-1: GobiSerial converter now attached to ttyUSB2
[117630.146425] usb 4-1: Enable of device-initiated U1 failed.
[117630.146662] usb 4-1: Enable of device-initiated U2 failed.
[117630.146832] usb 4-1: Disable of device-initiated U1 failed.
[117630.146942] usb 4-1: Disable of device-initiated U2 failed.
[117630.147797] GobiNet 4-1:1.8 eth1: register ‘GobiNet’ at usb-0000:00:14.0-1, GobiNet Ethernet Device, 32:28:d5:57:f8:98
[117630.148399] USB Speed : USB 3.0
[117630.148684] usb 4-1: Enable of device-initiated U1 failed.
[117630.148950] usb 4-1: Enable of device-initiated U2 failed.
[117642.315718] creating qcqmi0
[117642.315962] RawIP mode
owner@CNHKG-EX-001367:~/legato/packages/legato.framework.18.6.4.wp85-wp750x-201811231214/resources/legato$ ls /dev/ttyUSB*
/dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2
owner@CNHKG-EX-001367:~/legato/packages/legato.framework.18.6.4.wp85-wp750x-201811231214/resources/legato$ lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=GobiSerial, 5000M
|__ Port 1: Dev 3, If 2, Class=Vendor Specific Class, Driver=GobiSerial, 5000M
|__ Port 1: Dev 3, If 3, Class=Vendor Specific Class, Driver=GobiSerial, 5000M
|__ Port 1: Dev 3, If 8, Class=Vendor Specific Class, Driver=GobiNet, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/15p, 480M
|__ Port 7: Dev 2, If 0, Class=Vendor Specific Class, Driver=, 12M
|__ Port 11: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 11: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 12: Dev 4, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 12: Dev 4, If 1, Class=Video, Driver=uvcvideo, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
