So I bought myself a WWAN card and as sierra has support for Linux I bought an em7355.
It arrived, I plugged it into my laptop, it is recognized, but I can’t use it (not even on Windows where I went through a driver hell to get it recognized.)
I can pass my PIN and unlock my SIM though.
I already dug around a bit. The serial ports are there, and I can talk to the using screen.
Using the Modem Manager CLI manually gives this error:
> mmcli -m any --simple-connect="apn=pinternet.interkom.de"
error: couldn't connect the modem: 'GDBus.Error:org.freedesktop.ModemManager1.Error.Core.Retry: Invalid transition'
This is all information mmcli gives me about the card:
> mmcli -m any
General | path: /org/freedesktop/ModemManager1/Modem/1
| device id: <redacted>
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: HP lt4111 LTE/EV-DO/HSPA+ Gobi 4G Module
| firmware revision: SWI9X15C_05.05.58.00
| h/w revision: EM7355
| supported: gsm-umts, lte
| cdma-evdo, lte
| lte
| cdma-evdo, gsm-umts, lte
| current: cdma-evdo, gsm-umts, lte
| equipment id: <redacted>
System | device: /sys/devices/pci0000:00/0000:00:14.0/usb1/1-8
| drivers: cdc_mbim, qcserial
| plugin: generic
| primary port: cdc-wdm0
| ports: cdc-wdm0 (mbim), ttyUSB0 (qcdm), ttyUSB2 (at),
| wwp0s20f0u8i12 (net)
Numbers | own: <redacted>
Status | unlock retries: sim-pin (3), sim-pin2 (3)
| state: disabled
| power state: low
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, pcs, g850, utran-1, utran-4, utran-5, utran-8,
| utran-2, eutran-2, eutran-4, eutran-5, eutran-13, eutran-17,
| eutran-25, cdma-bc0, cdma-bc1, cdma-bc10
| current: egsm, dcs, pcs, g850, utran-1, utran-4, utran-5, utran-8,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: <redacted>
| enabled locks: sim, fixed-dialing
3GPP EPS | ue mode of operation: csps-2
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/1
It looks like I got an HP-branded one. Would it help to remove the branding, if so, how?
My laptop is a Dell Precision 7510, currently running arch Linux (and Windows on an usb-hdd)
