I’m porting some software to the Legato. Some of the software is built as a static library (for a number of reasons).
If I try to create a ‘New C++ project’ of type ‘Static Library’ (or Dynamic Library for that matter) using the ‘Legato Linux GCC’ toolchain, the wizard pops up an ‘Project cannot be created error’ box with a java.lang.NullPointerException message and the creation fails.
However, if I create a standard C++ project an then change the properties to be a static library, all is good.
Have you seen this? Can you reproduce this? Is this a SiWi problem, or a upstream CDT/Eclipse problem?
Just made the test, and reproducing it here…
This one is on our side; fortunately you have a workaround for it, but as soon as we have a fix, I’ll push a patch here.
