Drivers for EM7595
we also have current unit with EM7565 radio which uses gobiSerial and gobiNet driver. Will gibiSerial or GobiNet uses qmi and usb drivers ?
Qmicli should be good for your product
Gobiserial and gobinet are already the usb serial driver and qmi driver respectively
LinuxQMISDK
SLQS04.00.11
Thank you. Is there any issue with running all the drivers at the same time? gobiserial and gobinet for EM7565 and usb serial and qmi for EM7595?
Simon
you need to check the VID/PID of GobiSerial which is not duplicate to that in qcserial.
In addition, you need to check the VID/PID of GobiNet which is not duplicate to that in qmi_wwan..
I see PPP sessions are not starting with Em7565 with Gobinet and GobiSerial. Is that becasue of the VID/PID duplication in qmi_wwan ?
Do you mean ppp dial up via AT command port?
If yes, ppp dial up should not affect qmi_wwan because it uses AT command port only
