driver windows for MC8792V
Hallo,
I have a great problem with your MC8792V previously installed in our electronic board. We have a lot of pieces (about 1000 pcs) returned from the field: the module seems working but does not communicate.
We decided to try to re-upload the last FW, before considering the module KO because we can see one or more COM.
The FW was supplied by the FAE, K2.0-Release26_K2_0_7_40BT_K2_0_7_53BAP and we try to re-upload it by means of air development kit but the procedure does not work.
The procedure does not work with a MC8792V working well, also!!! The second firmware module cannot be uploaded.
Probably there is a problem with the driver used to work with the development kit (we use watcher for MC8795V, build 3830 and build 2350 and an Air Development Kit just bought) because the MC8795V supplied with the development kit has been reprogrammed well.
PLEASE, send me the correct driver to speak with MC8792V by means of air development kit or help me in using your development kit:
I know that the module is discontinued, I know I should have to send this request by the FAE but NO ANSWER ARRIVED FROM FAE + SIERRA till now. Now, we decided to check the Sierra forum…
ALSO, is inacceptable that you does not hold on your site documentation from discontinued products!!!
NOW, WE ARE DEFINING THE NEW VERSION OF OUR BOARD: OBVIOUSLY, IF NO ANSWERS FROM SIERRA WILL BE RECEIVED, SIERRA WILL NOT BE USED ANYMORE…
Let me know, thanks in advance.
Carlo Martinelli
Engineering Manager
INSIS SPA
Topic moved to the correct section
Regards,
Moderator
