DOTA is sucessful but system restarts twice
I am not sure if that is the problem but it sounds like it could be. I suggest try and run that adl_atCmdCreate 2 seconds after startup…
strange. i remember reading it, but i can’t find it anymore :question:
Don’t you just hate it when that happens!
:laughing:
Even this does not works. Getting same problem.
	 poweron_timer_ptr=adl_tmrSubscribe(FALSE, 50, ADL_TMR_TYPE_100MS, (adl_tmrHandler_t) poweron_tmrhdl);
	 gbl_InitType=InitType;
Installing New Applcation
DOTA SUCCESS
Inside A and D Handler
+WIND: 3
+WIND: 13
+CGEV: ME CLASS “B”
+CGREG: 0
+WIND: 1
+WIND: 3
+WIND: 13
+CGEV: ME CLASS “B”
+CGREG: 0
+WIND: 1
INSIDE power timer
If find the problem.
It is due to our Hardware Watchdog.
http://forum.sierrawireless.com/viewtopic.php?f=118&t=4369&start=15#p17539
Let me guess:
  1. you do the adl_adInstall, but you don’t “kick” your watchdog;
  2. the time it takes to install the new app & restart is close to your watchdog timeout (especially if the adl_adInstall happened near the end of a Watchdog period);
  3. so the watchdog “bites” before the new application has got as far as its first “kick” of the watchdog;
  4. this time, the module restarts more quickly (doesn’t have to do the install) so the application’s first “kick” of the watchdog comes in plenty of time;
  5. Hence the adl_adInstall appears to have caused a double restart.
Is that about it?
But this doesn’t appear to acount for charlvz’s problem - does it?
Nope its not, I believe the data from my GPS is causing multiple resets. I have seen how after a reset the modem keeps on resetting until I fisically remove the GPS from UART1…that gives the indication that the data going in on UART1 while the unit is resetting is causing multiple resets.
Would this help as a workaound:
Have the version number embedded in the application somehow; eg,
ascii version_string[] = "v1.2.3";
Have your apllication write this version number into the module’s Flash.
When the application starts, it checks the version recorded in Flash against its own version; if they differ, it knows that an update has occurred - and can act accordingly…
I have considered it, but the real problem was that the module kept on resetting if the GPS was constantly sending data. I solved this by polling for GPS info instead of having the GPS send data on a 1second interval. The module is only resetting once now.
or stop the unsolicited responses when you start the upgrade process?
Hi Guys,
Sorry for late reply. I was in vacation and in remote place so i could not able to access internet.
My problem was due to H/W watchdog. This is solved now.
yes, Charlvz’s problem seems to be something different.
Awneil,Charlvz,Madouc
Was it as I surmised:
That is Absolutely right.
