I want to permanently disable a BAND on EM7455. I have already tried user defined BAND set using AT!BAND.
Can I disable a band through Linux Gobinet/Gobiserial driver?
didn’t you can send AT!BAND command in GobiSerial driver?
AT!BAND requires creation of a new band set. I am unable to create a generic band set that will work for all operators.
example “All bands” mask is not constant
00, All bands 0002000007C00000 000000000000101A 0000000000000000
Can you provide an example of a generic band set mask that excludes any specific band (for example B30)?
you already disable B30 in LMask in your AT!BAND
“ALL BANDS” mask changes when I use a SIM from different operator or switch the firmware.
The previous instance does not have B30 enables.
Please check the following,
Index, Name, GW Band Mask L Band Mask TDS Band Mask
00, All bands 0002000007C00000 00000100030818DF 0000000000000000
00000100030818DF also disabled B30
This is to disable B20:
AT!entercnd=“A710”
at!band=11,“test”,00000100030018DF
Will it work for every firmware/operator?
for example the following one. (it has B30)
00, All bands, 0002000007C00000 00000100330818DF 0000000000000000
you can try:
at!band=11,“test”,00000100130818DF
