Could you please provide any documentation or example for writing the device tree node for RC7620 which has both UART and USB3 interface
what do you mean by device tree node?
What are you writing the device node?
Do you mean you want to connect the RC76 module to a linux machine?
Yes.Dts file entry for RC7620 module connected with linux machine
does this help?
BTW, you can install the linux driver which supports RC76 module:
I need the device tree entry for RC7620,not driver file.
Not quite sure what it is, can you give some example on device tree entry?
You might also see the gobiserial driver source code and see if there is related information.
No idea then…
You might see the gobiserial driver source code and see if there is related information.
