Delay function not working as desired
Hello All,
I am using FXT009 modem.
I am really struggling with this bit, any help is much appreciated.
I am trying to apply following logic but the delay is not being applied between steps 2 and 3, the main functions continues regardless of the delay and the delay only happens once the main function is finished. Why and is there another way of doing this?
For the delay I am using the following function;
adl_tmrSubscribe(FALSE, hysterisis_value, ADL_TMR_TYPE_100MS, (adl_tmrHandler_t) wait_for_hyst);
Send when something changes function
Step 1
Step 2
Go to delay check timer function
Step 3
Step 4
Go to delay function
Delay function
wait for a couple of seconds
Thanks in advance :slight_smile:
Calling
will start a timer that runs in the background, and will call the callback function after <hysterisis_value * 100ms>. Your code will still continue to run. You have 2 options when implementing a delay:
    Step 1
    Step 2
void wait_for_hyst (u8 Id, void * Context)
    Step 3
    Step 4
    Step 1
    Step 2
    adl_ctxSleep(ADL_TMR_S_TO_TICK(hysterisis_value) );
    Step 3
    Step 4
Thank you very much Tom.
cheers
Note that adl_ctxSleep() will not work if you have only one task.
Open-AT is Event-Driven - you should not be inserting inline delays :exclamation:
https://forum.sierrawireless.com/t/good-paper-on-event-driven-programming/3848/7
@Awneil: I am using one task and it worked for me however while downloading the application, if sleep time is > than the time out period then the modem gives timeout error but application download is successful.
