I’m using qmicli commands to connect 2 EM7565 on the same Linux machine.
Everything is going well (I’m getting a connection from both of the cards and able to ping 8.8.8.8) until I’m looking at the routing table and see only 1 default route to the first card that gets the connection.
If I’m adding the default route of the second card manually everything works fine, I would like to know why this happens. Is there a way to make it automatically?
I got another answer form you support and they advised me to add a default route manually as I did.
So the problem is fixed, I just wanted to confirm this is the right way to handle it.
