Debug output
Hi all!
I’m new to GR64, so I have a question… In the last GR47, I used UART2 to receive the output of prtf function. In this new module, where I can read debug info?? on the usb?
Please help me, thanks!
Hi mate,
on GR64 debug port is UART2 or they call it UART3
GR64 has 2 UARTs and a USB
one is primary UART which you use to send AT commands and used to upload the scripts. other one is debug port. and it is speed is 115200bps
also use prs(0); method to disable other GSM debug data. that will help you to get your debug data.
I hope you got a clear idea
Good luck
Asiri
csspl.com.au
