Hi all,
We try to create a TCP / IP server on the Fastrack to create a communication between him and our environment on a LAN server. But for this we need to define a Bearer and configure network settings of Fastrack. We chose the Bearer Ethernet to communicate with the module channel.
We come to create the Bearer and dynamically configured using DHCP network settings in the template we based TCP Server provided in the IDE. However, the IP address must be Fastrack statically configured. And it is at this level that it blocks.
We are good at creating the Bearer and calling the wip_bearerSetOpts function does not return an error. However, the network parameters applied are not those that we have provided.
Here the dynamic and static configurations we conducted and the results of program execution:
Dynamic :
ret = wip_bearerSetOpts ( Bearer_Handle,
WIP_BOPT_ETH_ADDR, &mac_addr,
WIP_BOPT_IP_DHCP, TRUE,
WIP_BOPT_END );
Result: Ethernet bearer started
Applied settings: Local: 192.168.0.209 Netmask: 255.255.255.0 Default gateway: 192.168.0.1 DNS1: 194.2.0.20 DNS2: 194.2.0.50
Server created and listening on port 2000
Static :
wip_in_addr_t static_ip_addr = 0xFA00A8C0; // ip address 250.0.168.192
wip_in_addr_t static_subnet = 0x00FFFFFF; // subnet mask 0.255.255.255
wip_in_addr_t static_gw = 0x0100A8C0; // Default gateway 1.0.168.192
wip_in_addr_t static_dns1 = 0x140002C2; // DNS 1 20.0.2.194
wip_in_addr_t static_dns2 = 0x320002C2; // DNS 2 50.0.2.194
wip_in_addr_t static_dst = 0x0100A8C0; // Default gateway 1.0.168.192
WIP_BOPT_IP_DHCP, FALSE,
WIP_BOPT_IP_ADDR, &static_ip_addr,
WIP_BOPT_IP_NETMASK, &static_subnet,
WIP_BOPT_IP_GW, &static_gw,
/*WIP_BOPT_IP_DST_ADDR, &static_dst,*/
WIP_BOPT_IP_DNS1, &static_dns1,
WIP_BOPT_IP_DNS2, &static_dns2,
WIP_BOPT_IP_SETDNS, FALSE,
WIP_BOPT_IP_SETGW, FALSE,
WIP_BOPT_END );
Provided settings: Net mask: 255.255.255.0, IP: 192.168.0.250, GW: 92.168.0.1 ,DNS1: 194.2.0.20, DNS2: 194.2.0.50
Showing configuration
Applied setings: Local: 0.0.0.0 Netmask: 0.0.0.0 default gateway: 112.8.16.2 DNS1: 116.8.16.24 DNS2: 120.8.16.24
Is there a special option to apply a static address that we would have missed?
Thank you
