What functions handle TCP/IP connection failures?
I´m using ed_lib for this matter and whenever I lose connection with the service provider, I would like to restablish the connection.
Best Regards,
Henrique
Best Regards,
Henrique
You have to watch for events in event handlers You subscribed in
ed_DialupConnectionStart and
ed_SocketTCPStart, if You use TCP socket
Be prepared to handle all events such as: ED_ERR_GPRS_SESSION_LOST, ED_OK_TCP_CLOSED, ED_ERR_DISTANT_TCP_CLOSED_BY_PEER, ED_ERR_DISTANT_NO_RESP etc.
Action depends on event detected and Your application may need different response to different error events on different situation/internal state.
Hi, thanks for the previous help.
Here´s what I got:
I have 2 servers with different IPs. It may happen that one of the server be down. So I would like to try a connection with the other one.
When the event before happens, I get the following answer:
I´m already attached to the service provider and I got a valid IP.
What function should I use to restablish the connection to a working server?
Here´s what I´m trying to do:
case ED_ERR_DISTANT_OPEN:
TRACE((1, "ED_ERR_DISTANT_OPEN"));
FreeIP = FALSE;
exchangeIP();
th=(adl_tmr_t *)adl_tmrSubscribe(FALSE, timeout_period, ADL_TMR_TYPE_100MS, (adl_tmrHandler_t) Timer_FreeIP);
break;
void Timer_FreeIP(u8 Id)
s8 sReturn = ERROR;
s8 ipsubReturn;
u16 timeout_period=30;
adl_tmr_t *th;
TRACE((1, "**Timer FreeIP**"));
ipsubReturn = ed_SocketLTCPStop (ED_ID_TCPSOCKET_1,(ed_ResponseCbk_f)tcp_Stop_pfResponseCbk);
ed_SocketTCPStart (ED_ID_TCPSOCKET_1, 0,(ed_ResponseCbk_f)tcp_pfResponseCbk, (ed_DataHandler_f)tcp_pfDataHnd, (ed_DataRequest_f)tcp_pfDataRequest);
if(FreeIP==FALSE)
TRACE((1, "**FreeIP: Problems, trying again...**"));
But this way I never get re-connected again…
As I never get reconnected again, the Timer subscribed is called everytime trying to do something that it´s supposed to do.
What should I do?
Best Regards,
Henrique
Hi Henrique,
what does the program do? does it connect to a server or is it the server?? If it is not the server, you should not use the function ed_SocketLTCPStop() -this would stop a listening connection- which you would not have on the client side!
Best Regards,
Jan
Do you suggest any proceedings to force connection failures?
Like: removing the atenna, shutting the server…
Best Regards,
Henrique
