I add a recipes into source then compile it.
how about you delete the file in module and then upgrade your yocto image?
my test shows that if i delete /mnt/flash/ufs/etc/init.d/startlegato.sh, it will back to the one in the image
Hi @jyijyi ,
The result is in here.
then no idea, maybe you downgrade to R12 and back to R16 as workaround
Yes, I think so, but I think it’s too complicated a step.
Hi @jyijyi ,
I want to use swicwe to combine image to spk file.
But I got error when I down image.
swicwe log is below:
swicwe -o R16_mangoh.spk -c 9999999_9907152_SWI9X07Y_02.37.03.00_00_GENERIC_002.095_003.spk yocto_wp76xx.4k.cwe legato-image.wp76xx.cwe
input image type is SPKG
input image type is APPL
Parsing input file 9999999_9907152_SWI9X07Y_02.37.03.00_00_GENERIC_002.095_003.spk
Type Size(Exclude Header) Product Compress Version
*SPKG 28666674 Y921 0 9999999_9907152_SWI9X07Y_02.37.03.00_00_GENERIC_002.095_003
*BOOT 420864 Y921 0 SWI9X07Y_02.37.10.00 5718ef CARMD-EV-SIGN01 2021/08/03 19:35:14
HASH 6480 9X28 0 SWI9X07Y_02.37.10.00 5718ef CARMD-EV-SIGN01 2021/08/03 19:35:14
SBL1 413584 9X28 0 SWI9X07Y_02.37.10.00 5718ef CARMD-EV-SIGN01 2021/08/03 19:35:14
*MODM 28216140 Y921 0 SWI9X07Y_02.37.03.00 73df45 CARMD-EV-SIGN01 2020/04/08 17:11:15
HASH 6560 9X28 0 SWI9X07Y_02.37.03.00 73df45 CARMD-EV-SIGN01 2020/04/08 17:11:15
TZON 522748 9X28 0 SWI9X07Y_02.37.03.00 73df45 CARMD-EV-SIGN01 2020/04/08 17:11:15
QRPM 160112 9X28 0 SWI9X07Y_02.37.03.00 73df45 CARMD-EV-SIGN01 2020/04/08 17:11:15
DSP2 27525120 9X28 0 SWI9X07Y_02.37.03.00 73df45 CARMD-EV-SIGN01 2020/04/08 17:11:15
*FILE 28470 Y921 0 9999999_9907152_SWI9X07Y_02.37.03.00_00_GENERIC_002.095_003
Parsed image is SPKG, finding components
Found BOOT component
Found MODM component
Found FILE component
Parsing input file yocto_wp76xx.4k.cwe
*APPL 39372944 Y921 0 SWI9X07Y_02.37.10.02 2023/06/15 06:06:33
SYST 29622272 9X28 0 SWI9X07Y_02.37.10.02 2023/06/15 06:06:33
APPS 9749872 9X28 0 3.18.140 20230515060356
3.18.140 20230515063041
3.18.140 20230515065308
3.18.140 20206/15/23
Parsed image is Legato/Linux
Parsing input file legato-image.wp76xx.cwe
*APPL 6291856 Y921 0 19.11.2_a3145c8f7625d08aa33298c0ae6ecec1
USER 6291456 9X28 0 19.11.2_a3145c8f7625d08aa33298c0ae6ecec1
Concatenating images
CWE Header Generator 3.01. Copyright Sierra Wireless, Inc., 2012
Output CWE Header File /tmp/temp.mbn.hdr
Image size 0x46e3872, crc32 0xf10bd5e2
Console log: (CRC32 check error (0X89),STATUS=FAIL)
B - 576450 - ssmem_release: region 20 not exists
B - 580994 - ssmem_get: region 20 not exists
B - 588467 - smart recovery counter cleared
B - 589321 - DWL-ety: rea=1 rcv=0
B - 25185131 - Sahara over USB
B - 25400705 - Sahara: Hello pkt sent
B - 57616421 - BOOT_HOLD=3,DOWNLOADER=boot,VERSION=9999999_9907152_SWI9X07Y_02.37.03.00_00_GENERIC_002.095_003,TYPE=SPKG,ERROR=Verfication after download failed: CRC32 check error (0X89),STATUS=FAIL
What should I do?
how about downloading one by one?
This can make sure the images are ok
Or you can try to combine yocto and legato image first and see if the image can be downloaded
Hi @jyijyi ,
you mean use swicwe command to combine yocto and legato image?
yes
as from your log, it has problem to download modem image
Hi @jyijyi ,
I combine yocto and legato to spk
combine command
test@test-virtual-machine:~/workspace$ swicwe -o R16_rootfs.spk -c yocto_wp76xx.4k.cwe legato-image.wp76xx.cwe input image type is APPL
Image size 0x2b8cd40, crc32 0xe22a8c13
and I use fdt2 to download spk
.\fdt2.exe -d wpspk -fd E:\wp_linux_image\R16\ -f R16_rootfs.spk -force
but I got error
FDT version: 2.0.2012.0
Awaiting adapter ...
Setting images preference ...
Disabling selective suspend ...
Firmware download failed.
Primary error code: 51 - Failed to switch device to BOOT&HOLD mode.
Secondary error code: 209 - Invalid image preference string in SPK header.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId: 002.095_003
BuildId: 02.37.03.00_GENERIC
Configuration:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
how about just “fdt2.exe -f xxx.spk”
Hi @jyijyi ,
It’s worked both include modem.spk or not when I remove “-d wpspk”.
Hi @jyijyi ,
I saw R17 version, Do you know R17 can do reset ?
please open a new topic for WP76 discussion
