I am using BX3105 module for one of my project. In that, I used AT+KTCPSTART=1 to start direct flow communication with server. After starting this mode I'm not able to use AT commands. So, I need to exit from that mode. But I have tried many way to get out from direct data flow mode after connecting to server, I don't know how to disconnect from server. Only after resetting the module, I can able to use AT commands. Is there any way to disconnect from that direct data flow.
Finally got the answer. Using escapes sequence, we can exit from Direct data mode. By sending “+++” without double codes and without carriage return, it will exit from that mode.
