my device : Model FX30 generic Lte S/N VU911670630810
We were using the FX30S as a serial modem. We would want to use the FX30 as a modem through the RJ45 connector and not through the serial connection.
-Does the FX30 handle PPPoE protocol ?
During my testing I change the static eth0 IP using the web interface at 192.168.2.2 to one within my range and I have been able to connect the FX30 through ssh using this new static IP.
In order to quickly configure my Sim I used cm command. Once my sim was configured the last command I used was cm data connect. After that I power off the FX30 and I have never been able to connect through ssh again within Ethernet (at the static IP) neither USB (at 192.168.2.2).
PING 192.168.2.2 (192.168.2.2) 56(84) bytes of data.
From xxx icmp_seq=1 Destination Port Unreachable
From xxx icmp_seq=2 Destination Port Unreachable
From xxx icmp_seq=3 Destination Port Unreachable
23: usb0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether c2:df:6a:b7:a5:14 brd ff:ff:ff:ff:ff:ff
I tried to add an IP to usb0 : ip a add 192.168.2.3 dev usb0
inet 192.168.2.3 /32 scope global usb0
valid_lft forever preferred_lft forever
and even « ip link set usb0 up » but no more luck on the ping
Then I thought I maybe did something wrong so I reset the FX30 (I enable the reset from the AT command) without more success. Finally I download and flash the following firmware
FX30_WP77xx_full_R11.0.0.007-generic_gcf-SWI9X06Y_02.22.12.00.cwe
./swiflash -m wp77xx -i ./FX30_WP77xx_full_R11.0.0.007-generic_gcf-SWI9X06Y_02.22.12.00.cwe
Detecting USB of the target
DONE
Communicating with the target
DONE
Switching to firmware download mode
…DONE
Downloading the firmware
…DONE
Rebooting the module
…DONE
Firmware Download SUCCESS
Everything looks fine but I still have no ping at 192.168.2.2
- Anything that I didn’t try to get back a ssh connection ?
I am still able to send AT command using minicom through ttyUSB2
Thanks for your time and help,
Simon
