Hi there ,
I am using MCP2515 based CAN IOT card . It was observed that there is a data loss if I try to send 10 DATA frames with different ID’s with a delay of 10ms . It was observed that out of 10 only 6-7 Data are received where as if i try to send only 4 Data Frames with 10ms of delay i don’t see any Data loss .
Note : Peak CAN is the master device which will send the CAN data and WP7608(MCP2515) is the slave device which will receive the CAN data . (CAN dump is used to receive CAN data )
Basically the SPI driver is not reading the messages from mcp2515 chip fast enough and it was observed that IRQ thread irq/259-mcp251x priority is 50 which is lower (That means the IRQ-Handler can be served or might not be served at the exact time of interrupt) . Is there a way to overcome this issue ? Is it possible to change the rtprio of the irq/259-mcp251x ?
Thanks & Regards
Akshay
