Because I cannot run file on python3 and it get same error with python.
I have ask the wfx company they said have to fix “Could not find platform dependent libraries <exec_prefix> Consider setting $PYTHONHOME to [:<exec_prefix>]” first.
and I think it have only surface cuz’ when I press up-arrow I got “^]]A”. It should get the command before right?
does this help?
I already tried. it same result.
it sets like this:
Here is my testing:
root@fx30:~# python3
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
Python 3.5.5 (default, Dec 22 2021, 17:41:21)
[GCC 7.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> exit
Use exit() or Ctrl-D (i.e. EOF) to exit
>>> exit()
root@fx30:~# pwd
/home/root
root@fx30:~# export PYTHONHOME=/usr/lib/python3.5/
root@fx30:~# export PYTHONPATH=/usr/lib/python3.5/
still get Error while import python3 file
wfx_test_dut.py.txt (26.4 KB)
root@swi-mdm9x28-wp:~# cd wfx-common-tools/test-feature
root@swi-mdm9x28-wp:~/wfx-common-tools/test-feature# python3
Python 3.5.5 (default, Mar 31 2022, 03:43:27)
>>> from wfx_test_dut import *
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "/home/root/wfx-common-tools/test-feature/wfx_test_dut.py", line 133
nb_text = f"{points} points: open_loop"
SyntaxError: invalid syntax
no idea as I am not python expert.
Currently the python3 can be run already, so this is out of the scope.
it have a command that have to use with python version3.6 upper.
So have can I install python3 version3.6 or upper in wp76 module
I have no experience on this…
Maybe you change that command to be usable in python3.5.5 will be easier
I want to import logging to using with my code. I have found the file in “./yocto/build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/packages-split/python3-logging” and tried to copy it in to wp76 module but still cannot import.
How can I do??
>>> import logging
ImportError: No module named 'logging'
you need to do the following two commands
scp -r ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/python3.5/logging/ root@192.168.2.2:/usr/lib/python3.5
scp -r ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/python3.5/collections/ root@192.168.2.2:/usr/lib/python3.5
>>> import logging
how about “import argparse”?
I don’t know, seems already having the struct.py…
Just found that you can do this:
scp ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/python3.5/lib-dynload/_struct.cpython-35m-arm-linux-gnueabi.so root@192.168.2.2:/usr/lib/python3.5
>>> import argparse
“from distutils.version import StrictVersion”
still missing module please help , thank you
File "/home/root/wfx-common-tools/test-feature/wfx_test_dut.py", line 6, in <module>
from wfx_test_target import *
File "/home/root/wfx-common-tools/test-feature/wfx_test_target.py", line 15, in <module>
from wfx_pds_tree import *
File "/home/root/wfx-common-tools/test-feature/wfx_pds_tree.py", line 21, in <module>
ImportError: No module named 'distutils'
ImportError: No module named 'StrictVersion'
to import distutils:
scp -r ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/python3.5/distutils/ root@192.168.2.2:/usr/lib/python3.5/
no idea for StrictVersion…
