Could you specify the exact file I should download please?
have you followed the steps to run python3 in RAM ?
have you followed the steps here?
You can follow the steps below to run python3:
- download the yocto source and go to ./meta-swi/meta-swi-mdm9x28/recipes-core/images/mdm9x28-image.inc
- add the following line:
IMAGE_INSTALL_append = " python3"- go to ./meta-swi/meta-swi-mdm9x28/conf/machine/swi-mdm9x28.conf
change UBI_ROOTFS_SIZE ?= “48MiB”- Make the yocto image ( there will be error to make the image, but we can build the binary of python3)
- on PC, type :
sudo ifconfig usb0 192.168.2.3- on module, type :
mkdir /tmp/tmp_usr_bin/;mkdir /tmp/tmp_usr_bin_wr;
mount -t overlay overlay /usr/bin -o lowerdir=/usr/bin,upperdir=/tmp/tmp_usr_bin,workdir=/tmp/tmp_usr_bin_wr;
mkdir /tmp/tmp_usr_include/;mkdir /tmp/tmp_usr_include_wr;
mount -t overlay overlay /usr/include -o lowerdir=/usr/include,upperdir=/tmp/tmp_usr_include,workdir=/tmp/tmp_usr_include_wr;
mkdir /tmp/tmp_usr_lib/;mkdir /tmp/tmp_usr_lib_wr;
cp -rf /usr/lib/* /tmp/tmp_usr_lib/
mount -t overlay overlay /usr/lib -o lowerdir=/usr/lib,upperdir=/tmp/tmp_usr_lib,workdir=/tmp/tmp_usr_lib_wr;
mkdir /usr/lib/python3.5- on PC, type :
scp -r ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/include/* root@192.168.2.2:/usr/include
scp -r ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/bin/* root@192.168.2.2:/usr/bin
scp ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/libpython3.5m.so ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/libpython3.5m.so.1.0 ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/libpython3.so root@192.168.2.2:/usr/lib
scp -r ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/pkgconfig root@192.168.2.2:/usr/lib
scp -r ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/python3.5/encodings/ root@192.168.2.2:/usr/lib/python3.5
scp ./build_bin/tmp/work/armv7a-neon-poky-linux-gnueabi/python3/3.5.5-r1.0/image/usr/lib/python3.5/*.py root@192.168.2.2:/usr/lib/python3.5- now on module, you can use python3:
root@swi-mdm9x28-wp:~# python3
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to [:<exec_prefix>]
Python 3.5.5 (default, Oct 24 2019, 07:42:55)
[GCC 7.3.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
Do you mean this one??
yes, have you tried that?
wp7605 has stoped while copied file in no.7
are you testing on R13.3?
I don’t see problem
Why does it stop?
Is it not enough memory?
then you need to debug it, it can already run python3
I think it because I haven’t install this one yet. Then how can I install it to wp7605 module?
install.txt (556 Bytes)
I don’t know, never try that before
I only tried python3 before
you can google the answer
it not work ![]()
root@swi-mdm9x28-wp:~# export PYTHONHOME='usr/bin/python3'
Fatal Python error: Py_Initialize: Unable to get the locale encoding
ImportError: No module named 'encodings'
Current thread 0xb6cc8010 (most recent call first):
Aborted
this is different error message…
did you transfer this library?
seems problem starts after you type
export PYTHONHOME=‘usr/bin/python3’
yes,I was. python also cannot use. I have to reboot the module and install again.
still get “Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to [:<exec_prefix>]”
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
Python 3.5.5 (default, Mar 31 2022, 03:43:27)
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
root@swi-mdm9x28-wp:~# export $PYTHONHOME='/usr/lib/python3.5'
-sh: export: : bad variable name
root@swi-mdm9x28-wp:~# export PYTHONHOME='/usr/lib/python3.5'
Current thread 0xb6d5a010 (most recent call first):
Aborted
ImportError: No module named site
what is the actual problem of getting “Could not find platform dependent libraries <exec_prefix>
