BX310x Activating Legacy Pairing PIN Feature using SPP under Windows
We currently have a product using legacy Bluetooth (PIN mode) pairing to
prevent unauthorized users from pairing with our device. This mode uses a
4-digit PIN.
The microcontroller on our product programs a “secret 4-digit PIN” into the
BT module, based on user input. The product presently uses a BT module from
another company, but we want to change it to the BX3105.
I am using the BX3105 DEV KIT_6001182 for to verify that the BX3105 can
perform the required functions.
I am using the following two documents to provide configuration information:
-BX310x_AT_Command_Ref r6.pdf
-AirPrime - BX310x - AT Command Reference - R7.0.pdf
I looked on your web site and did not find any examples how to configure the
product in SPP mode. I also did not find information on activating legacy
pairing PIN feature.
I did read Your list of commands. I successfully configured SPP mode.
On the Personal computers with windows 7 and 10, with 32 bit and 64 bit
processors, the BX3105 was detected, paired and assigned to a serial COM
PORT.
Terra Term found it and worked right away. PERFECT!!!
Now I am trying to activate the legacy pairing PIN feature.
I found command: “legacy pairing PIN feature”
It looks amazing, you have more options than our current module, if it
works.
THE PROBLEM:
I don’t know how to activate the "legacy pairing PIN feature ".
SRBLESECPARAMS is at its default value 3.
Any other option for SRBLESECPARAMS activates random 6-digit automatic
generation on the PC side, and I cannot use it in our product.
From Your Forum, I saw 2 discussions in which the customer asked for this
feature, but because they are not using SPP, you didn’t tell them how to
I am using SPP. It looks like the “legacy pairing PIN feature” is there.
Please help!
The text below is how I am configuring the device, based on what I
understand from your list of commands.
I am definitely missing something. Please help!
How do I activate the legacy pairing PIN feature in SPP mode under Windows?
NOTE: No support for cellphone connection is required for now!
ATI0
BX310x
AT+FMR
BX310x.2.7.3
AT&F
Sierra Wireless Copyright 2018
BX310x.2.7.3
READY
AT+SRBTSYSTEM=0
AT+RST
BX310x.2.7.3
READY
AT+SRBTSYSTEM=2
+SRBTC_IND: 0
AT+SRBTNAME=“MPM-BT Classic-BX3105”
AT+SRBTCPROFILES=1
+SRBTC_IND: 12
AT+SRBTCPINCFG=1,5867
AT+SRBTCTXPWR=4,7
AT+SRBTSTATE=1,2
+SRBTPAIR: “e8:4e:06:7f:c7:17”,1
AT+SRBTCSECPARAMS?
+SRBTCSECPARAMS: 3
Eng. Milen Moussakov
