I have tried connecting to a Holux M-1200E BT GPS device but recieve the following:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff80b8,len:8
load:0x3fff80c0,len:460
ho 0 tail 12 room 4
load:0x40078000,len:16040
ho 0 tail 12 room 4
load:0x40080000,len:296
entry 0x40080060
READY
+SRBTINQ: “00:1b:c1:07:d9:7e”,001f00,-71
+SRBTSTATE: 1,2,1
+SRBTCFG: 1,0,“00:1b:c1:07:d9:7e”,SPP,0
+SRBTPAIR: “00:1b:c1:07:d9:7e”,0,34
Looking this up the is a failure to pair with HCI code I assume 0x34 “Reserved Slot Violation”.
I am able to connect to a Garmin GLO using this same command sequency just fine. I am able to connect to this same Holux M-1200E just fine from other BT devices. So it seems there is some incompatability between the BX3105 and the Holux M-1200E? The Holux is an old BT Classic 1.2 device, perhaps this is a hint as to the issue?
Any suggestions for how to connect to the Holux greatly appreciated. I am new to the BX3105 and may well be doing daft things …
