Hi
When ever build application in target mode 3 error occure. I have attached the build error below.
Make an archive file for TMT application
zip warning: name not matched: …/out/tmt/e2p_csn.cso
zip error: Nothing to do! (…/out/tmt/zip_tmt.zip)
zip warning: name not matched: …/out/tmt/backtraces.axf
zip warning: name not matched: …/out/tmt/backtraces64k.axf
zip warning: name not matched: …/out/tmt/symbolfiles/s64k
zip warning: name not matched: …/out/tmt/symbolfiles/e2p.h
adding: s (176 bytes security) (deflated 66%)
enter new zip file comment (end with .):
current zip file comment is:
[Binary Information]
Stack Version = Open-AT
Customer Version = gcc
Binary Name = pro-lib.bin
Size =
Date = Thu Dec 18 2008
Time = 00:00:00
Size =
Time = 00:00:00
adding: DiagnoseTips.ini (176 bytes security) (deflated 87%)
Size =
Time = 00:00:00
adding: MokaWatches.ini (176 bytes security) (deflated 67%)
Size =
Time = 00:00:00
adding: RemoteDefs.ini (176 bytes security) (deflated 74%)
Size =
Time = 00:00:00
Rename …/out/tmt/zip_tmt.zip …/out/tmt/gcc.zip
Keep only the TMT archive file in …/out/tmt
Remove …/out/tmt/e2p_csn.cso
Remove …/out/tmt/sys_ftr.ho
Remove …/out/tmt/wm_ftr.ho
Remove …/out/tmt/remtrace.csv
Remove …/out/tmt/backtraces.axf
Remove …/out/tmt/backtraces64k.axf
Remove …/out/tmt/remtrace_full.csv
Remove …/out/tmt/symbolfiles directory
Remove …/out/tmt/config directory
… Create binary in X-MODEM format from gcc_Sampletest_H.bin …
Add a checksum to gcc_Sampletest_H.sgt
(AddCheck Version v2.0.4 Copyright © WAVECOM) [Feb 14 2003, 15:50:57]
Time modified : Thu Dec 18 11:59:30 2008
… Build gcc_Sampletest_H.dwl …
genBin : Version v1a06 Copyright © WAVECOM
genBin : No Error
Cleaning temporary files (*.tmp / *.trc)
Generation done with SGT v1.2.12oat
Binary files created :
pro-dwl.bin
Binary files in Xmodem format :
Compiler keyword : gcc_arm
Compiler release : GCC ARM
C compiler path : D:/OpenAT/IDE/GCC/4.0.1.0/bin/arm-elf-gcc
ASM compiler path : D:/OpenAT/IDE/GCC/4.0.1.0/bin/arm-elf-gcc
customer release : gcc
Name of the current directory : gcc
Log file : …/out/gcc_Sampletest_H_status.log
Release of the environement : CYGWIN_NT-5.1 Bespoke-8500 1.5.10(0.116/4/2) 2004-05-25 22:07 i686 unknown unknown Cygwin
Build an X-MODEM binary : 'gcc_Sampletest_H.wpb.dwl'
… Convert gcc_Sampletest_H.wpb in X-MODEM format …
genBin : No Error
… Build gcc_Sampletest_H.wpb.dwl …
AXFshrinker Version 1.0.0.1 ( Aug 23 2002 , 17:44:58 )
adding: backtraces.axf (deflated 74%)
Done.
Sampletest - 3 error(s), 545 warning(s)
I could not understand why this type of error occur. Any one help me to figure out this issue.
Vanee
